C
csfricki
Hallo @ all
ich hab nen riesen problehm.
Es will bei SUSe Linux 10.1 einfach meinen Ati Treiber nicht richtig erkennen.
ICh weis dieses Thema wurde schon viel angeschprochen ich ahbe es jettzt aber schon viele male versucht mit verschiedenen Howtos aber er hat nicht funktioniert.
hier meine logs:
Xorg.0.log:
meine Xorg.conf
un zum schlusss noch fglrxinfo:
hier meine logs:
Xorg.0.log:
X Window System Version 6.9.0
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 6.9
Build Operating System: SuSE Linux [ELF] SuSE
Current Operating System: Linux linux 2.6.16.13-4-default #1 Wed May 3 04:53:23 UTC 2006 i686
Build Date: 02 May 2006
Before reporting problems, check [url]http://wiki.X.Org[/url]
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Jan 13 09:12:05 2007
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Layout[all]"
(**) |-->Screen "aticonfig-Screen[0]" (0)
(**) | |-->Monitor "aticonfig-Monitor[0]"
(**) | |-->Device "aticonfig-Device[0]"
(**) |-->Input Device "Keyboard[0]"
(**) |-->Input Device "Mouse[1]"
(WW) The directory "/usr/X11R6/lib/X11/fonts/Speedo" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/X11R6/lib/X11/fonts/PEX" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/latin2/misc" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/latin2/75dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/latin2/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/latin2/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/latin7/75dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/baekmuk" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/japanese" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/kwintv" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/ucs/misc" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/ucs/75dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/ucs/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/hellas/misc" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/hellas/75dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/hellas/100dpi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/hellas/Type1" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/misc/sgi" does not exist.
(WW) The directory "/usr/X11R6/lib/X11/fonts/xtest" does not exist.
(**) FontPath set to "/usr/X11R6/lib/X11/fonts/misc:unscaled,/usr/X11R6/lib/X11/fonts/local,/usr/X11R6/lib/X11/fonts/75dpi:unscaled,/usr/X11R6/lib/X11/fonts/100dpi:unscaled,/usr/X11R6/lib/X11/fonts/Type1,/usr/X11R6/lib/X11/fonts/URW,/usr/X11R6/lib/X11/fonts/truetype,/usr/X11R6/lib/X11/fonts/uni:unscaled,/usr/X11R6/lib/X11/fonts/CID,/opt/kde3/share/fonts"
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(**) Input device list set to "/dev/gpmdata,/dev/input/mice"
(==) ModulePath set to "/usr/X11R6/lib/modules/updates,/usr/X11R6/lib/modules"
(**) Option "AllowMouseOpenFail" "on"
(**) Option "Xinerama" "off"
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.2
X.Org Video Driver: 0.8
X.Org XInput driver : 0.5
X.Org Server Extension : 0.2
X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.so
(II) Module bitmap: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 1.0.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
ABI class: X.Org Video Driver, version 0.8
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,2570 card 103c,12bc rev 02 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,2571 card 0000,0000 rev 02 class 06,04,00 hdr 01
(II) PCI: 00:1d:0: chip 8086,24d2 card 103c,12bc rev 02 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,24d4 card 103c,12bc rev 02 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,24dd card 103c,12bc rev 02 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev c2 class 06,04,00 hdr 01
(II) PCI: 00:1f:0: chip 8086,24d0 card 0000,0000 rev 02 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,24db card 103c,12bc rev 02 class 01,01,8a hdr 00
(II) PCI: 00:1f:2: chip 8086,24d1 card 103c,12bc rev 02 class 01,01,8f hdr 00
(II) PCI: 00:1f:3: chip 8086,24d3 card 103c,12bc rev 02 class 0c,05,00 hdr 00
(II) PCI: 01:00:0: chip 1002,4e45 card 1002,0002 rev 00 class 03,00,00 hdr 80
(II) PCI: 01:00:1: chip 1002,4e65 card 1002,0003 rev 00 class 03,80,00 hdr 00
(II) PCI: 05:02:0: chip 14e4,1696 card 103c,12bc rev 03 class 02,00,00 hdr 00
(II) PCI: 05:04:0: chip 8086,1229 card 8086,0040 rev 0c class 02,00,00 hdr 00
(II) PCI: 05:09:0: chip 1102,0002 card 1102,8027 rev 06 class 04,01,00 hdr 80
(II) PCI: 05:09:1: chip 1102,7002 card 1102,0020 rev 06 class 09,80,00 hdr 80
(II) PCI: 05:0a:0: chip 105a,4d69 card 105a,4d68 rev 02 class 01,80,85 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,5), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x00002000 - 0x00002fff (0x1000) IX[B]
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xf8500000 - 0xf87fffff (0x300000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xe8000000 - 0xf81fffff (0x10200000) MX[B]
(II) Bus 5: bridge is at (0:30:0), (0,5,5), BCTRL: 0x0006 (VGA_EN is cleared)
(II) Bus 5 I/O range:
[0] -1 0 0x00001000 - 0x000010ff (0x100) IX[B]
[1] -1 0 0x00001400 - 0x000014ff (0x100) IX[B]
[2] -1 0 0x00001800 - 0x000018ff (0x100) IX[B]
[3] -1 0 0x00001c00 - 0x00001cff (0x100) IX[B]
(II) Bus 5 non-prefetchable memory range:
[0] -1 0 0xf8200000 - 0xf84fffff (0x300000) MX[B]
(II) Bus 5 prefetchable memory range:
[0] -1 0 0x70000000 - 0x700fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) ATI Technologies Inc Radeon R300 NE [Radeon 9500 Pro] rev 0, Mem @ 0xe8000000/27, 0xf8500000/16, I/O @ 0x2000/8
(--) PCI: (1:0:1) ATI Technologies Inc Radeon R300 [Radeon 9500 Pro] (Secondary) rev 0, Mem @ 0xf0000000/27, 0xf8510000/16
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xe4000000 from 0xe7fffff0 to 0xe3ffffff
(II) Active PCI resource ranges:
[0] -1 0 0x70010000 - 0x70013ff0 (0x3ff1) MX[B]
[1] -1 0 0xf8430000 - 0xf8433ff0 (0x3ff1) MX[B]
[2] -1 0 0xf8400000 - 0xf841fff0 (0x1fff1) MX[B]
[3] -1 0 0xf8434000 - 0xf8434ff0 (0xff1) MX[B]
[4] -1 0 0xf8420000 - 0xf842fff0 (0xfff1) MX[B]
[5] -1 0 0x70100000 - 0x701003f0 (0x3f1) MX[B]
[6] -1 0 0xf8a00000 - 0xf8a003f0 (0x3f1) MX[B]
[7] -1 0 0xe4000000 - 0xe3ffffff (0x0) MX[B]O
[8] -1 0 0xf8510000 - 0xf851fff0 (0xfff1) MX[B](B)
[9] -1 0 0xf0000000 - 0xf7fffff0 (0x7fffff1) MX[B](B)
[10] -1 0 0xf8500000 - 0xf850fff0 (0xfff1) MX[B](B)
[11] -1 0 0xe8000000 - 0xeffffff0 (0x7fffff1) MX[B](B)
[12] -1 0 0x00001060 - 0x00001060 (0x1) IX[B]
[13] -1 0 0x0000108c - 0x0000108f (0x4) IX[B]
[14] -1 0 0x00001080 - 0x00001080 (0x1) IX[B]
[15] -1 0 0x00001088 - 0x0000108b (0x4) IX[B]
[16] -1 0 0x00001078 - 0x0000107f (0x8) IX[B]
[17] -1 0 0x00001070 - 0x00001070 (0x1) IX[B]
[18] -1 0 0x00001040 - 0x00001050 (0x11) IX[B]
[19] -1 0 0x00001000 - 0x00001030 (0x31) IX[B]
[20] -1 0 0x0000fc00 - 0x0000fc10 (0x11) IX[B]
[21] -1 0 0x000034b0 - 0x000034b0 (0x1) IX[B]
[22] -1 0 0x000034ec - 0x000034ef (0x4) IX[B]
[23] -1 0 0x000034d8 - 0x000034df (0x8) IX[B]
[24] -1 0 0x000034e8 - 0x000034eb (0x4) IX[B]
[25] -1 0 0x000034d0 - 0x000034d0 (0x1) IX[B]
[26] -1 0 0x000034a0 - 0x000034a0 (0x1) IX[B]
[27] -1 0 0x000034e4 - 0x000034e4 (0x1) IX[B]
[28] -1 0 0x000034c8 - 0x000034c8 (0x1) IX[B]
[29] -1 0 0x000034e0 - 0x000034e0 (0x1) IX[B]
[30] -1 0 0x000034c0 - 0x000034c0 (0x1) IX[B]
[31] -1 0 0x00003460 - 0x00003470 (0x11) IX[B]
[32] -1 0 0x00003440 - 0x00003450 (0x11) IX[B]
[33] -1 0 0x00002000 - 0x000020f0 (0xf1) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0x70010000 - 0x70013ff0 (0x3ff1) MX[B]
[6] -1 0 0xf8430000 - 0xf8433ff0 (0x3ff1) MX[B]
[7] -1 0 0xf8400000 - 0xf841fff0 (0x1fff1) MX[B]
[8] -1 0 0xf8434000 - 0xf8434ff0 (0xff1) MX[B]
[9] -1 0 0xf8420000 - 0xf842fff0 (0xfff1) MX[B]
[10] -1 0 0x70100000 - 0x701003f0 (0x3f1) MX[B]
[11] -1 0 0xf8a00000 - 0xf8a003f0 (0x3f1) MX[B]
[12] -1 0 0xe4000000 - 0xe3ffffff (0x0) MX[B]O
[13] -1 0 0xf8510000 - 0xf851fff0 (0xfff1) MX[B](B)
[14] -1 0 0xf0000000 - 0xf7fffff0 (0x7fffff1) MX[B](B)
[15] -1 0 0xf8500000 - 0xf850fff0 (0xfff1) MX[B](B)
[16] -1 0 0xe8000000 - 0xeffffff0 (0x7fffff1) MX[B](B)
[17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[18] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[19] -1 0 0x00001060 - 0x00001060 (0x1) IX[B]
[20] -1 0 0x0000108c - 0x0000108f (0x4) IX[B]
[21] -1 0 0x00001080 - 0x00001080 (0x1) IX[B]
[22] -1 0 0x00001088 - 0x0000108b (0x4) IX[B]
[23] -1 0 0x00001078 - 0x0000107f (0x8) IX[B]
[24] -1 0 0x00001070 - 0x00001070 (0x1) IX[B]
[25] -1 0 0x00001040 - 0x00001050 (0x11) IX[B]
[26] -1 0 0x00001000 - 0x00001030 (0x31) IX[B]
[27] -1 0 0x0000fc00 - 0x0000fc10 (0x11) IX[B]
[28] -1 0 0x000034b0 - 0x000034b0 (0x1) IX[B]
[29] -1 0 0x000034ec - 0x000034ef (0x4) IX[B]
[30] -1 0 0x000034d8 - 0x000034df (0x8) IX[B]
[31] -1 0 0x000034e8 - 0x000034eb (0x4) IX[B]
[32] -1 0 0x000034d0 - 0x000034d0 (0x1) IX[B]
[33] -1 0 0x000034a0 - 0x000034a0 (0x1) IX[B]
[34] -1 0 0x000034e4 - 0x000034e4 (0x1) IX[B]
[35] -1 0 0x000034c8 - 0x000034c8 (0x1) IX[B]
[36] -1 0 0x000034e0 - 0x000034e0 (0x1) IX[B]
[37] -1 0 0x000034c0 - 0x000034c0 (0x1) IX[B]
[38] -1 0 0x00003460 - 0x00003470 (0x11) IX[B]
[39] -1 0 0x00003440 - 0x00003450 (0x11) IX[B]
[40] -1 0 0x00002000 - 0x000020f0 (0xf1) IX[B](B)
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.2
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.so
(II) Module type1: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 6.9.0, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(II) Loading sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.so
(II) Module GLcore: vendor="X.Org Foundation"
(II) Loading extension GLX
(II) LoadModule: "v4l"
(II) Loading /usr/X11R6/lib/modules/drivers/v4l_drv.so
(II) Module v4l: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 0.0.1
(II) LoadModule: "dri"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.so
(II) Module drm: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "fglrx"
(II) Loading /usr/X11R6/lib/modules/drivers/fglrx_drv.so
(II) Module fglrx: vendor="FireGL - ATI Technologies Inc."
compiled for 6.8.99.8, module version = 8.25.18
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 0.7
(II) LoadModule: "kbd"
(II) Loading /usr/X11R6/lib/modules/input/kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 1.0.1
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.5
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 1.0.3
(II) v4l driver for Video4Linux
(II) ATI Radeon/FireGL: The following chipsets are supported:
RADEON 9000/9000 PRO (RV250 4966), RADEON 9000 LE (RV250 4967),
MOBILITY FireGL 9000 (M9 4C64), MOBILITY RADEON 9000 (M9 4C66),
RADEON 9000 PRO (D9 4C67), RADEON 9250 (RV280 5960),
RADEON 9200 (RV280 5961), RADEON 9000 (RV280 5962),
RADEON 9200 SE (RV280 5964), FireMV 2200 PCI (RV280 5965),
MOBILITY RADEON 9200 (M9+ 5C61), MOBILITY RADEON 9200 (M9+ 5C63),
FireGL 8800 (R200 5148), RADEON 8500 (R200 514C),
RADEON 9100 (R200 514D), RADEON 8500 AIW (R200 4242),
RADEON 9600 (RV350 4150), RADEON 9600 SE (RV350 4151),
RADEON 9600 PRO (RV360 4152), RADEON 9600 (RV350 4E51),
MOBILITY RADEON 9600/9700 (M10/M11 4E50),
MOBILITY RADEON 9500 (M11 4E52), MOBILITY RADEON 9550 (M12 4E56),
RADEON 9500 (R300 4144), RADEON 9600 TX (R300 4146),
FireGL Z1 (R300 4147), RADEON 9700 PRO (R300 4E44),
RADEON 9500 PRO/9700 (R300 4E45), RADEON 9600 TX (R300 4E46),
FireGL X1 (R300 4E47), RADEON 9800 SE (R350 4148),
RADEON 9500 (R350 4149), RADEON 9550 (RV350 4153),
FireGL T2 (RV350 4154), RADEON 9600 (RV351 4155),
RADEON 9800 PRO (R350 4E48), RADEON 9800 (R350 4E49),
RADEON 9800 XT (R360 4E4A), FireGL X2-256/X2-256t (R350 4E4B),
MOBILITY FireGL T2/T2e (M10/M11 4E54), RADEON X300 (RV370 5B60),
RADEON X600 (RV380 5B62), RADEON X550 (RV370 5B63),
FireGL V3100 (RV370 5B64), FireMV 2200 (RV370 5B65),
MOBILITY RADEON X300 (M22 5460), MOBILITY RADEON X300 (M22 5461),
MOBILITY RADEON X600 (M24 5462), MOBILITY FireGL V3100 (M22 5464),
RADEON X600 (RV380 3E50), FireGL V3200 (RV380 3E54),
MOBILITY RADEON X600 (M24 3150), MOBILITY RADEON X300 (M22 3152),
MOBILITY FireGL V3200 (M24 3154), RADEON X800 (R420 4A48),
RADEON X800 PRO (R420 4A49), RADEON X800 SE (R420 4A4A),
RADEON X800 XT (R420 4A4B), RADEON X800 (R420 4A4C),
FireGL X3-256 (R420 4A4D), MOBILITY RADEON 9800 (M18 4A4E),
RADEON X800 SE (R420 4A4F),
RADEON X800 XT Platinum Edition (R420 4A50),
RADEON X800 VE (R420 4A54), RADEON X800 (R423 5548),
RADEON X800 PRO (R423 5549),
RADEON X800 XT Platinum Edition (R423 554A),
RADEON X800 GT (R423 554B), RADEON X800 XT (R423 5D57),
FireGL V7100 (R423 5550), FireGL V5100 (R423 5551),
MOBILITY RADEON X800 XT (M28 5D48), MOBILITY FireGL V5100 (M28 5D49),
MOBILITY RADEON X800 (M28 5D4A), RADEON X800 XL (R430 554D),
RADEON X800 GT (R430 554E), RADEON X800 GTO (R430 554F),
RADEON X850 XT Platinum Edition (R480 5D4D),
RADEON X800 GTO (R480 5D4F), RADEON X850 XT (R480 5D52),
RADEON X850 (R481 4B48), RADEON X850 XT (R481 4B49),
RADEON X850 SE (R481 4B4A), RADEON X850 PRO (R481 4B4B),
RADEON X850 XT Platinum Edition (R481 4B4C),
MOBILITY FireGL V5000 (M26 564A), MOBILITY FireGL V5000 (M26 564B),
FireGL V5000 (RV410 5E48), FireGL V3300 (RV410 5E49),
RADEON X700 XT (RV410 5E4A), RADEON X700 PRO (RV410 5E4B),
RADEON X700 SE (RV410 5E4C), RADEON X700 (RV410 5E4D),
RADEON X700 (RV410 5E4F), MOBILITY RADEON X700 (M26 5652),
MOBILITY RADEON X700 (M26 5653), MOBILITY RADEON X700 XL,
RADEON 9100 IGP (RS300 5834),
RADEON 9000 PRO/9100 PRO IGP (RS350 7834),
MOBILITY RADEON 9000/9100 IGP (RS300M 5835),
RADEON XPRESS 200 (RS400 5A41), RADEON XPRESS 200M (RS400 5A42),
RADEON XPRESS 200 (RS480 5954), RADEON XPRESS 200M (RS480 5955),
RADEON XPRESS 200 (RS482 5974), RADEON XPRESS 200M (RS482 5975),
RADEON XPRESS 200 (RC410 5A61), RADEON XPRESS 200M (RC410 5A62),
RADEON X1800 (R520 7100), MOBILITY RADEON X1800 (M58 7101),
MOBILITY RADEON X1800 (M58 7102), MOBILITY FireGL V7200 (M58 7103),
FireGL V7200 (R520 7104), FireGL V5300 (R520 7105),
MOBILITY FireGL V7100 (M58 7106), RADEON X1800 XT (R520 7108),
RADEON X1800 PRO (R520 7109), RADEON X1800 SE (R520 710A),
RADEON X1800 (R520 710B), RADEON X1800 (R520 710C),
FireGL V7300 (R520 710E), FireGL V7350 (R520 710F),
RADEON X1300 PRO (RV505 7143), RADEON X1300 (RV505 7147),
MOBILITY RADEON X1300 (M52 714B), MOBILITY RADEON X1300 (M52 714C),
RADEON X1300 (RV505 715F), RADEON X1300 XT (RV515 7140),
RADEON X1300 PRO (RV515 7142), MOBILITY FireGL (M54 GL 7144),
MOBILITY RADEON X1400 (M54 7145), RADEON X1300 LE (RV515 7146),
MOBILITY RADEON X1300 (M52 7149), MOBILITY RADEON X1300 (M52 714A),
RADEON X1300 SE (RV515 714E), FireGL V3300 (RV515 7152),
RADEON X1300 VE (RV515 715E), RADEON X1300 (RV516 7180),
RADEON X1300 (RV516 7183), RADEON X1300 (RV516 7187),
RADEON X1900 (R580 7240), RADEON X1900 (R580 7243),
RADEON X1900 (R580 7244), RADEON X1900 (R580 7245),
RADEON X1900 (R580 7246), RADEON X1900 (R580 7247),
RADEON X1900 (R580 7248), RADEON X1900 (R580 7249),
RADEON X1900 (R580 724A), RADEON X1900 (R580 724B),
RADEON X1900 (R580 724C), RADEON X1900 (R580 724D),
RADEON X1900 (R580 724E), RADEON X1900 (R580 724F),
RADEON X1600 XT (RV530 71C0), RADEON X1600 PRO (RV530 71C2),
MOBILITY FireGL V5200 (M56 71C4), MOBILITY RADEON X1600 (M56 71C5),
RADEON (RV530 LE 71C6), RADEON (RV530 VE 71CE),
FireGL V3400 (RV530 71D2), FireGL V5200 (RV530 71DA),
RADEON (RV530 SE 71DE)
(II) Primary Device is: PCI 01:00:0
(II) ATI Proprietary Linux Driver Version Identifier:8.25.18
(II) ATI Proprietary Linux Driver Release Identifier: LGDr8.25g1
(II) ATI Proprietary Linux Driver Build Date: May 18 2006 09:54:44
(II) ATI Proprietary Linux Driver Build Information: autobuild-rel-r6-8.25.1-driver-lnx-268237
(--) Assigning device section with no busID to primary device
(WW) fglrx: No matching Device section for instance (BusID PCI:1:0:1) found
(--) Chipset RADEON 9500 PRO/9700 (R300 4E45) found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) fglrx(0): pEnt->device->identifier=0x821cbc0
(II) resource ranges after probing:
[17] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[18] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[19] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[20] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[21] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[22] -1 0 0x00001060 - 0x00001060 (0x1) IX[B]
[23] -1 0 0x0000108c - 0x0000108f (0x4) IX[B]
[24] -1 0 0x00001080 - 0x00001080 (0x1) IX[B]
[25] -1 0 0x00001088 - 0x0000108b (0x4) IX[B]
[26] -1 0 0x00001078 - 0x0000107f (0x8) IX[B]
[27] -1 0 0x00001070 - 0x00001070 (0x1) IX[B]
[28] -1 0 0x00001040 - 0x00001050 (0x11) IX[B]
[29] -1 0 0x00001000 - 0x00001030 (0x31) IX[B]
[30] -1 0 0x0000fc00 - 0x0000fc10 (0x11) IX[B]
[31] -1 0 0x000034b0 - 0x000034b0 (0x1) IX[B]
[32] -1 0 0x000034ec - 0x000034ef (0x4) IX[B]
[33] -1 0 0x000034d8 - 0x000034df (0x8) IX[B]
[34] -1 0 0x000034e8 - 0x000034eb (0x4) IX[B]
[35] -1 0 0x000034d0 - 0x000034d0 (0x1) IX[B]
[36] -1 0 0x000034a0 - 0x000034a0 (0x1) IX[B]
[37] -1 0 0x000034e4 - 0x000034e4 (0x1) IX[B]
[38] -1 0 0x000034c8 - 0x000034c8 (0x1) IX[B]
[39] -1 0 0x000034e0 - 0x000034e0 (0x1) IX[B]
[40] -1 0 0x000034c0 - 0x000034c0 (0x1) IX[B]
[41] -1 0 0x00003460 - 0x00003470 (0x11) IX[B]
[42] -1 0 0x00003440 - 0x00003450 (0x11) IX[B]
[43] -1 0 0x00002000 - 0x000020f0 (0xf1) IX[B](B)
[44] 0 0 0xf80003b0 - 0xf80003b0 (0x1) IS[B]
[45] 0 0 0xf80003c0 - 0xf80003d0 (0x11) IS[B]
(II) Setting vga for screen 0.
(II) fglrx(0): === [R200PreInit] === begin, [s]
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/X11R6/lib/modules/libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 0.1.0
(II) fglrx(0): PCI bus 1 card 0 func 0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "DPMS" "true"
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(==) fglrx(0): Gamma Correction for I is 0x06419064
(==) fglrx(0): Gamma Correction for II is 0x06419064
(==) fglrx(0): Buffer Tiling is ON
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(--) fglrx(0): Chipset: "RADEON 9500 PRO/9700 (R300 4E45)" (Chipset = 0x4e45)
(--) fglrx(0): (PciSubVendor = 0x1002, PciSubDevice = 0x0002)
(--) fglrx(0): board vendor info: original ATI graphics adapter
(--) fglrx(0): Linear framebuffer (phys) at 0xe8000000
(--) fglrx(0): MMIO registers at 0xf8500000
(==) fglrx(0): ROM-BIOS at 0x000c0000
(II) Loading sub module "vbe"
(II) LoadModule: "vbe"
(II) Loading /usr/X11R6/lib/modules/libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 1.1.0
(II) fglrx(0): VESA BIOS detected
(II) fglrx(0): VESA VBE Version 2.0
(II) fglrx(0): VESA VBE Total Mem: 131072 kB
(II) fglrx(0): VESA VBE OEM: ATI R300
(II) fglrx(0): VESA VBE OEM Software Rev: 1.0
(II) fglrx(0): VESA VBE OEM Vendor: ATI Technologies Inc.
(II) fglrx(0): VESA VBE OEM Product: R300
(II) fglrx(0): VESA VBE OEM Product Rev: 01.00
(II) Reloading /usr/X11R6/lib/modules/linux/libdrm.so
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is -1, (No such device or address)
drmOpenDevice: Open failed
[drm] failed to load kernel module "fglrx"
(II) Loading sub module "fglrxdrm"
(II) LoadModule: "fglrxdrm"
(II) Loading /usr/X11R6/lib/modules/linux/libfglrxdrm.so
(II) Module fglrxdrm: vendor="FireGL - ATI Technologies Inc."
(EE) fglrx(0): Fail to initialize ASIC in kernel.
(--) fglrx(0): VideoRAM: 131072 kByte, Type: DDR SGRAM / SDRAM
(II) fglrx(0): AGP card detected
(II) fglrx(0): board/chipset is supported by this driver (original ATI board)
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.so
(II) Module ddc: vendor="X.Org Foundation"
(II) fglrx(0): Connected Display1: CRT on primary DAC
(II) fglrx(0): Display1 EDID data ---------------------------
(II) fglrx(0): Manufacturer: PHL Model: 824 Serial#: 27760
(II) fglrx(0): Year: 2005 Week: 7
(II) fglrx(0): EDID Version: 1.3
(II) fglrx(0): Analog Display Input, Input Voltage Level: 0.700/0.300 V
(II) fglrx(0): Sync: Separate Composite SyncOnGreen
(II) fglrx(0): Max H-Image Size [cm]: horiz.: 38 vert.: 30
(II) fglrx(0): Gamma: 2.20
(II) fglrx(0): DPMS capabilities: StandBy Suspend Off; RGB/Color Display
(II) fglrx(0): Default color space is primary color space
(II) fglrx(0): First detailed timing is preferred mode
(II) fglrx(0): redX: 0.639 redY: 0.342 greenX: 0.297 greenY: 0.615
(II) fglrx(0): blueX: 0.146 blueY: 0.068 whiteX: 0.313 whiteY: 0.329
(II) fglrx(0): Supported VESA Video Modes:
(II) fglrx(0): 720x400@70Hz
(II) fglrx(0): 640x480@60Hz
(II) fglrx(0): 640x480@67Hz
(II) fglrx(0): 640x480@72Hz
(II) fglrx(0): 640x480@75Hz
(II) fglrx(0): 800x600@56Hz
(II) fglrx(0): 800x600@60Hz
(II) fglrx(0): 800x600@72Hz
(II) fglrx(0): 800x600@75Hz
(II) fglrx(0): 832x624@75Hz
(II) fglrx(0): 1024x768@60Hz
(II) fglrx(0): 1024x768@70Hz
(II) fglrx(0): 1024x768@75Hz
(II) fglrx(0): 1280x1024@75Hz
(II) fglrx(0): 1152x870@75Hz
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported Future Video Modes:
(II) fglrx(0): #0: hsize: 640 vsize 480 refresh: 75 vid: 20273
(II) fglrx(0): #1: hsize: 800 vsize 600 refresh: 75 vid: 20293
(II) fglrx(0): #2: hsize: 1024 vsize 768 refresh: 75 vid: 20321
(II) fglrx(0): #3: hsize: 1152 vsize 864 refresh: 75 vid: 20337
(II) fglrx(0): #4: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) fglrx(0): Supported additional Video Mode:
(II) fglrx(0): clock: 108.0 MHz Image Size: 376 x 301 mm
(II) fglrx(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
(II) fglrx(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
(II) fglrx(0): Serial No: VN 027760
(II) fglrx(0): Monitor name: Philips 190S5
(II) fglrx(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 82 kHz, PixClock max 140 MHz
(II) fglrx(0): End of Display1 EDID data --------------------
(WW) fglrx(0): Specified desktop setup not supported: 8
(II) fglrx(0): Primary Controller - CRT on primary DAC
(II) fglrx(0): Internal Desktop Setting: 0x00000004
(II) fglrx(0): POWERplay not supported on this hardware
(==) fglrx(0): Qbs disabled
(==) fglrx(0): FAST_SWAP disabled
(==) fglrx(0): PseudoColor visuals disabled
(==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
(==) fglrx(0): Center Mode is disabled
(==) fglrx(0): TMDS coherent mode is enabled
(II) fglrx(0): Total of 29 modes found for primary display.
(--) fglrx(0): Virtual size is 1280x1024 (pitch 1280)
(**) fglrx(0): *Mode "1280x1024": 135.0 MHz (scaled from 0.0 MHz), 80.0 kHz, 75.0 Hz
(II) fglrx(0): Modeline "1280x1024" 135.00 1280 1296 1440 1688 1024 1025 1028 1066
(**) fglrx(0): Default mode "1280x1024": 128.9 MHz (scaled from 0.0 MHz), 74.6 kHz, 70.0 Hz
(II) fglrx(0): Modeline "1280x1024" 128.94 1280 1368 1504 1728 1024 1025 1028 1066 +hsync
(**) fglrx(0): Default mode "1280x1024": 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1280x1024" 108.00 1280 1328 1440 1688 1024 1025 1028 1066
(**) fglrx(0): *Mode "1152x864": 108.0 MHz (scaled from 0.0 MHz), 67.5 kHz, 75.0 Hz
(II) fglrx(0): Modeline "1152x864" 108.00 1152 1216 1344 1600 864 865 868 900
(**) fglrx(0): Default mode "1152x864": 96.8 MHz (scaled from 0.0 MHz), 63.0 kHz, 70.0 Hz
(II) fglrx(0): Modeline "1152x864" 96.77 1152 1224 1344 1536 864 865 868 900 +hsync
(**) fglrx(0): Default mode "1152x864": 81.6 MHz (scaled from 0.0 MHz), 53.7 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1152x864" 81.62 1152 1216 1336 1520 864 865 868 895 +hsync
(**) fglrx(0): *Mode "1024x768": 78.8 MHz (scaled from 0.0 MHz), 60.0 kHz, 75.0 Hz
(II) fglrx(0): Modeline "1024x768" 78.75 1024 1040 1136 1312 768 769 772 800
(**) fglrx(0): Default mode "1024x768": 78.4 MHz (scaled from 0.0 MHz), 57.7 kHz, 72.0 Hz
(II) fglrx(0): Modeline "1024x768" 78.43 1024 1080 1192 1360 768 769 772 801 +hsync
(**) fglrx(0): Default mode "1024x768": 75.0 MHz (scaled from 0.0 MHz), 56.5 kHz, 70.0 Hz
(II) fglrx(0): Modeline "1024x768" 75.00 1024 1048 1184 1328 768 771 777 806 +hsync +vsync
(**) fglrx(0): Default mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz
(II) fglrx(0): Modeline "1024x768" 65.00 1024 1048 1184 1344 768 771 777 806 +hsync +vsync
(**) fglrx(0): *Mode "800x600": 49.5 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz
(II) fglrx(0): Modeline "800x600" 49.50 800 816 896 1056 600 601 604 625
(**) fglrx(0): Default mode "800x600": 50.0 MHz (scaled from 0.0 MHz), 48.1 kHz, 72.0 Hz
(II) fglrx(0): Modeline "800x600" 50.00 800 856 976 1040 600 637 643 666
(**) fglrx(0): Default mode "800x600": 45.5 MHz (scaled from 0.0 MHz), 43.8 kHz, 70.0 Hz
(II) fglrx(0): Modeline "800x600" 45.50 800 840 920 1040 600 601 604 625 +hsync
(**) fglrx(0): Default mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.0 Hz
(II) fglrx(0): Modeline "800x600" 40.00 800 840 968 1056 600 601 605 628
(**) fglrx(0): Default mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.0 Hz
(II) fglrx(0): Modeline "800x600" 36.00 800 824 896 1024 600 601 603 625
(**) fglrx(0): Default mode "800x600": 29.6 MHz (scaled from 0.0 MHz), 29.8 kHz, 47.0 Hz (I)
(II) fglrx(0): Modeline "800x600" 29.61 800 816 896 992 600 601 604 635 interlace +hsync
(**) fglrx(0): *Mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz
(II) fglrx(0): Modeline "640x480" 31.50 640 656 720 840 480 481 484 500 +hsync +vsync
(**) fglrx(0): Default mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 72.0 Hz
(II) fglrx(0): Modeline "640x480" 31.50 640 664 704 832 480 489 492 520 +hsync +vsync
(**) fglrx(0): Default mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) fglrx(0): Modeline "640x480" 25.18 640 656 752 800 480 490 492 525 +hsync +vsync
(**) fglrx(0): Default mode "640x400": 28.1 MHz (scaled from 0.0 MHz), 33.7 kHz, 75.0 Hz
(II) fglrx(0): Modeline "640x400" 28.07 640 696 736 832 400 413 415 449
(**) fglrx(0): Default mode "640x400": 24.9 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
(II) fglrx(0): Modeline "640x400" 24.92 640 664 760 792 400 460 462 525
(**) fglrx(0): Default mode "512x384": 19.7 MHz (scaled from 0.0 MHz), 31.1 kHz, 75.0 Hz
(II) fglrx(0): Modeline "512x384" 19.68 512 528 576 632 384 384 385 416
(**) fglrx(0): Default mode "512x384": 19.8 MHz (scaled from 0.0 MHz), 29.8 kHz, 60.0 Hz
(II) fglrx(0): Modeline "512x384" 19.81 512 544 624 664 384 451 453 497
(**) fglrx(0): Default mode "400x300": 24.8 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline "400x300" 24.75 400 408 448 528 150 601 602 625 doublescan
(**) fglrx(0): Default mode "400x300": 22.3 MHz (scaled from 0.0 MHz), 45.0 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "400x300" 22.33 400 416 480 496 150 601 605 742 doublescan
(**) fglrx(0): Default mode "320x240": 15.8 MHz (scaled from 0.0 MHz), 37.9 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline "320x240" 15.75 320 328 360 416 120 481 482 501 doublescan
(**) fglrx(0): Default mode "320x240": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "320x240" 12.59 320 328 376 400 120 491 493 525 doublescan
(**) fglrx(0): Default mode "320x200": 13.1 MHz (scaled from 0.0 MHz), 31.5 kHz, 75.0 Hz (D)
(II) fglrx(0): Modeline "320x200" 13.10 320 352 368 416 100 406 407 417 doublescan
(**) fglrx(0): Default mode "320x200": 12.6 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz (D)
(II) fglrx(0): Modeline "320x200" 12.59 320 336 384 400 100 457 459 524 doublescan
(--) fglrx(0): Display dimensions: (380, 300) mm
(--) fglrx(0): DPI set to (85, 86)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.2
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/X11R6/lib/modules/libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
(==) fglrx(0): NoAccel = NO
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/X11R6/lib/modules/libxaa.so
(II) Module xaa: vendor="X.Org Foundation"
compiled for 6.9.0, module version = 1.2.0
(==) fglrx(0): HPV inactive
(==) fglrx(0): FSAA enabled: NO
(==) fglrx(0): FSAA Gamma enabled
(==) fglrx(0): FSAA Multisample Position is fix
(==) fglrx(0): NoDRI = NO
(II) Reloading /usr/X11R6/lib/modules/linux/libfglrxdrm.so
(II) fglrx(0): Depth moves disabled by default
(==) fglrx(0): Capabilities: 0x00000000
(==) fglrx(0): CapabilitiesEx: 0x00000000
(==) fglrx(0): cpuFlags: 0x8000001d
(==) fglrx(0): cpuSpeedMHz: 0x00000ae9
(==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
(==) fglrx(0): UseFastTLS=0
(==) fglrx(0): BlockSignalsOnLock=1
(==) fglrx(0): EnablePrivateBackZ = NO
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xf8500000 - 0xf850fff0 (0xfff1) MX[B]
[1] 0 0 0xe8000000 - 0xeffffff0 (0x7fffff1) MX[B]
[2] -1 0 0xffe00000 - 0xffffffff (0x200000) MX[B](B)
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[7] -1 0 0x70010000 - 0x70013ff0 (0x3ff1) MX[B]
[8] -1 0 0xf8430000 - 0xf8433ff0 (0x3ff1) MX[B]
[9] -1 0 0xf8400000 - 0xf841fff0 (0x1fff1) MX[B]
[10] -1 0 0xf8434000 - 0xf8434ff0 (0xff1) MX[B]
[11] -1 0 0xf8420000 - 0xf842fff0 (0xfff1) MX[B]
[12] -1 0 0x70100000 - 0x701003f0 (0x3f1) MX[B]
[13] -1 0 0xf8a00000 - 0xf8a003f0 (0x3f1) MX[B]
[14] -1 0 0xe4000000 - 0xe3ffffff (0x0) MX[B]O
[15] -1 0 0xf8510000 - 0xf851fff0 (0xfff1) MX[B](B)
[16] -1 0 0xf0000000 - 0xf7fffff0 (0x7fffff1) MX[B](B)
[17] -1 0 0xf8500000 - 0xf850fff0 (0xfff1) MX[B](B)
[18] -1 0 0xe8000000 - 0xeffffff0 (0x7fffff1) MX[B](B)
[19] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[20] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[21] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[22] 0 0 0x00002000 - 0x000020f0 (0xf1) IX[B]
[23] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[24] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[25] -1 0 0x00001060 - 0x00001060 (0x1) IX[B]
[26] -1 0 0x0000108c - 0x0000108f (0x4) IX[B]
[27] -1 0 0x00001080 - 0x00001080 (0x1) IX[B]
[28] -1 0 0x00001088 - 0x0000108b (0x4) IX[B]
[29] -1 0 0x00001078 - 0x0000107f (0x8) IX[B]
[30] -1 0 0x00001070 - 0x00001070 (0x1) IX[B]
[31] -1 0 0x00001040 - 0x00001050 (0x11) IX[B]
[32] -1 0 0x00001000 - 0x00001030 (0x31) IX[B]
[33] -1 0 0x0000fc00 - 0x0000fc10 (0x11) IX[B]
[34] -1 0 0x000034b0 - 0x000034b0 (0x1) IX[B]
[35] -1 0 0x000034ec - 0x000034ef (0x4) IX[B]
[36] -1 0 0x000034d8 - 0x000034df (0x8) IX[B]
[37] -1 0 0x000034e8 - 0x000034eb (0x4) IX[B]
[38] -1 0 0x000034d0 - 0x000034d0 (0x1) IX[B]
[39] -1 0 0x000034a0 - 0x000034a0 (0x1) IX[B]
[40] -1 0 0x000034e4 - 0x000034e4 (0x1) IX[B]
[41] -1 0 0x000034c8 - 0x000034c8 (0x1) IX[B]
[42] -1 0 0x000034e0 - 0x000034e0 (0x1) IX[B]
[43] -1 0 0x000034c0 - 0x000034c0 (0x1) IX[B]
[44] -1 0 0x00003460 - 0x00003470 (0x11) IX[B]
[45] -1 0 0x00003440 - 0x00003450 (0x11) IX[B]
[46] -1 0 0x00002000 - 0x000020f0 (0xf1) IX[B](B)
[47] 0 0 0xf80003b0 - 0xf80003b0 (0x1) IS[B]
[48] 0 0 0xf80003c0 - 0xf80003d0 (0x11) IS[B]
(II) fglrx(0): UMM Bus area: 0xe8701000 (size=0x078ff000)
(II) fglrx(0): UMM area: 0xe8701000 (size=0x078ff000)
(II) fglrx(0): driver needs X.org 6.8.x.y with x.y >= 99.8
(II) fglrx(0): detected X.org 7.0.0.0
(II) Loading extension ATIFGLRXDRI
(II) fglrx(0): doing DRIScreenInit
(II) fglrx(0): [drm] drmOpen failed
(EE) fglrx(0): DRIScreenInit failed!
(WW) fglrx(0): ***********************************************
(WW) fglrx(0): * DRI initialization failed! *
(WW) fglrx(0): * (maybe driver kernel module missing or bad) *
(WW) fglrx(0): * 2D acceleraton available (MMIO) *
(WW) fglrx(0): * no 3D acceleration available *
(WW) fglrx(0): ********************************************* *
(II) fglrx(0): FBADPhys: 0xe8000000 FBMappedSize: 0x08000000
(==) fglrx(0): Write-combining range (0xe8000000,0x8000000)
(II) fglrx(0): FBMM initialized for area (0,0)-(1280,8191)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(1280,1024) (front color buffer - assumption)
(==) fglrx(0): Backing store disabled
(==) fglrx(0): Silken mouse enabled
(**) fglrx(0): DPMS enabled
(WW) fglrx(0): Option "VendorName" is not used
(WW) fglrx(0): Option "ModelName" is not used
(II) fglrx(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
Solid Horizontal and Vertical Lines
Offscreen Pixmaps
Setting up tile and stipple cache:
32 128x128 slots
32 256x256 slots
16 512x512 slots
(II) fglrx(0): Acceleration enabled
(II) fglrx(0): Direct rendering disabled
(==) fglrx(0): Using hardware cursor
(II) fglrx(0): Largest offscreen area available: 1280 x 7163
(II) Loading extension FGLRXEXTENSION
(II) Loading extension ATITVOUT
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(**) Option "CoreKeyboard"
(**) Keyboard[0]: Core Keyboard
(**) Option "Protocol" "Standard"
(**) Keyboard[0]: Protocol: Standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xfree86"
(**) Keyboard[0]: XkbRules: "xfree86"
(**) Option "XkbModel" "pc105"
(**) Keyboard[0]: XkbModel: "pc105"
(**) Option "XkbLayout" "de"
(**) Keyboard[0]: XkbLayout: "de"
(**) Option "XkbVariant" "nodeadkeys"
(**) Keyboard[0]: XkbVariant: "nodeadkeys"
(**) Option "CustomKeycodes" "off"
(**) Keyboard[0]: CustomKeycodes disabled
(**) Option "Protocol" "explorerps/2"
(**) Mouse[1]: Device: "/dev/input/mice"
(**) Mouse[1]: Protocol: "explorerps/2"
(**) Option "CorePointer"
(**) Mouse[1]: Core Pointer
(**) Option "Device" "/dev/input/mice"
(**) Option "Buttons" "12"
(==) Mouse[1]: Emulate3Buttons, Emulate3Timeout: 50
(**) Option "ZAxisMapping" "4 5"
(**) Mouse[1]: ZAxisMapping: buttons 4 and 5
(**) Mouse[1]: Buttons: 16
(II) XINPUT: Adding extended input device "Mouse[1]" (type: MOUSE)
(II) XINPUT: Adding extended input device "Keyboard[0]" (type: KEYBOARD)
(II) Mouse[1]: ps2EnableDataReporting: succeeded
Could not init font path element /usr/X11R6/lib/X11/fonts/local, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/CID, removing from list!
# SaX generated X11 config file
# Created on: 2007-01-13T09:00:57+0100.
# Version: 7.1
# Contact: Marcus Schaefer <sax@suse.de>, 2005
# Contact: SaX-User list <https://lists.berlios.de/mailman/listinfo/sax-users>
# Automatically generated by [ISaX] (7.1)
# PLEASE DO NOT EDIT THIS FILE!
Section "ServerLayout"
Identifier "Layout[all]"
Screen 0 "aticonfig-Screen[0]" 0 0
InputDevice "Keyboard[0]" "CoreKeyboard"
InputDevice "Mouse[1]" "CorePointer"
Option "Clone" "off"
EndSection
Section "Files"
InputDevices "/dev/gpmdata"
InputDevices "/dev/input/mice"
FontPath "/usr/X11R6/lib/X11/fonts/misc:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/local"
FontPath "/usr/X11R6/lib/X11/fonts/75dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/100dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/URW"
FontPath "/usr/X11R6/lib/X11/fonts/Speedo"
FontPath "/usr/X11R6/lib/X11/fonts/PEX"
FontPath "/usr/X11R6/lib/X11/fonts/cyrillic"
FontPath "/usr/X11R6/lib/X11/fonts/latin2/misc:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/latin2/75dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/latin2/100dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/latin2/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/latin7/75dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/baekmuk:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/japanese:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/kwintv"
FontPath "/usr/X11R6/lib/X11/fonts/truetype"
FontPath "/usr/X11R6/lib/X11/fonts/uni:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/CID"
FontPath "/usr/X11R6/lib/X11/fonts/ucs/misc:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/ucs/75dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/ucs/100dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/hellas/misc:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/hellas/75dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/hellas/100dpi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/hellas/Type1"
FontPath "/usr/X11R6/lib/X11/fonts/misc/sgi:unscaled"
FontPath "/usr/X11R6/lib/X11/fonts/xtest"
FontPath "/opt/kde3/share/fonts"
EndSection
Section "Module"
Load "dbe"
Load "type1"
Load "freetype"
Load "extmod"
Load "glx"
Load "v4l"
Load "dri"
EndSection
Section "ServerFlags"
EndSection
Section "InputDevice"
Identifier "Keyboard[0]"
Driver "kbd"
EndSection
Identifier "Mouse[1]"
Driver "mouse"
Option "Name" "Logitech Cordless Mouse+Keyboard Receiver"
Option "Vendor" "Sysp"
EndSection
Section "Modes"
Identifier "Modes[0]"
ModeLine "1280x1024" 136.6 1280 1368 1504 1728 1024 1025 1028 1068
ModeLine "1280x1024" 134.7 1280 1368 1504 1728 1024 1025 1028 1068
ModeLine "1280x1024" 132.8 1280 1368 1504 1728 1024 1025 1028 1067
ModeLine "1152x864" 103.6 1152 1224 1352 1552 864 865 868 902
ModeLine "1152x864" 102.1 1152 1224 1352 1552 864 865 868 901
ModeLine "1152x864" 99.6 1152 1224 1344 1536 864 865 868 901
ModeLine "1024x768" 80.7 1024 1080 1192 1360 768 769 772 802
ModeLine "1024x768" 79.5 1024 1080 1192 1360 768 769 772 801
ModeLine "1024x768" 78.4 1024 1080 1192 1360 768 769 772 801
ModeLine "800x600" 48.2 800 840 920 1040 600 601 604 626
ModeLine "800x600" 47.5 800 840 920 1040 600 601 604 626
ModeLine "800x600" 46.9 800 840 920 1040 600 601 604 626
EndSection
Section "Monitor"
Identifier "Monitor[0]"
VendorName "PHL"
ModelName "PHILIPS PHILIPS 190S5"
UseModes "Modes[0]"
DisplaySize 380 300
HorizSync 30.0 - 82.0
VertRefresh 43.0 - 76.0
Option "DPMS"
EndSection
Section "Monitor"
Identifier "aticonfig-Monitor[0]"
Option "VendorName" "ATI Proprietary Driver"
Option "ModelName" "Generic Autodetecting Monitor"
EndSection
Section "Device"
Identifier "Device[0]"
Driver "radeon"
VendorName "ATI"
BoardName "R300 NE"
BusID "1:0:0"
EndSection
Section "Device"
Identifier "aticonfig-Device[0]"
Driver "fglrx"
EndSection
Section "Screen"
Identifier "Screen[0]"
Device "Device[0]"
Monitor "Monitor[0]"
DefaultDepth 24
SubSection "Display"
Depth 15
Modes "1280x1024" "1152x864" "1024x768" "800x600"
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
Depth 8
EndSubSection
EndSection
Section "Screen"
Identifier "aticonfig-Screen[0]"
DefaultDepth 24
Viewport 0 0
Depth 24
EndSubSection
EndSection
Section "DRI"
Group "video"
Mode 0660
EndSection
csfricki@dhcppc1:~> fglrxinfo
display: :0.0 screen: 0
OpenGL vendor string: Mesa project: [url]www.mesa3d.org[/url]
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.2 (1.5 Mesa 6.4.1)
