[ 0.251878] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.251882] pci 0000:00:01.0: IO window: disabled
[ 0.251889] pci 0000:00:01.0: MEM window: 0xfc900000-0xfe9fffff
[ 0.251895] pci 0000:00:01.0: PREFETCH window: 0xd7f00000-0xf7efffff
[ 0.251901] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:02
[ 0.251906] pci 0000:00:1e.0: IO window: 0xb000-0xbfff
[ 0.251913] pci 0000:00:1e.0: MEM window: 0xfea00000-0xfeafffff
[ 0.251918] pci 0000:00:1e.0: PREFETCH window: disabled
[ 0.251940] pci 0000:00:1e.0: setting latency timer to 64
[ 0.251948] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.251952] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.251956] pci_bus 0000:01: resource 1 mem: [0xfc900000-0xfe9fffff]
[ 0.251960] pci_bus 0000:01: resource 2 pref mem [0xd7f00000-0xf7efffff]
[ 0.251964] pci_bus 0000:02: resource 0 io: [0xb000-0xbfff]
[ 0.251968] pci_bus 0000:02: resource 1 mem: [0xfea00000-0xfeafffff]
[ 0.251972] pci_bus 0000:02: resource 3 io: [0x00-0xffff]
[ 0.251975] pci_bus 0000:02: resource 4 mem: [0x000000-0xffffffff]
[ 0.252038] NET: Registered protocol family 2
[ 0.252199] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.252795] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.254039] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.254810] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.254817] TCP reno registered
[ 0.255023] NET: Registered protocol family 1
[ 0.255180] Trying to unpack rootfs image as initramfs...
[ 0.517283] Freeing initrd memory: 7469k freed
[ 0.529433] cpufreq-nforce2: No nForce2 chipset.
[ 0.529499] Scanning for low memory corruption every 60 seconds
[ 0.529664] audit: initializing netlink socket (disabled)
[ 0.529691] type=2000 audit(1259768644.528:1): initialized
[ 0.538379] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.540615] VFS: Disk quotas dquot_6.5.2
[ 0.540717] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.541628] fuse init (API version 7.12)
[ 0.541760] msgmni has been set to 1498
[ 0.542137] alg: No test for stdrng (krng)
[ 0.542163] io scheduler noop registered
[ 0.542166] io scheduler anticipatory registered
[ 0.542170] io scheduler deadline registered
[ 0.542246] io scheduler cfq registered (default)
[ 0.542334] pci 0000:01:00.0: Boot video device
[ 0.542360] pci 0000:02:08.0: Firmware left e100 interrupts enabled; disabling
[ 0.542558] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.542601] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.542801] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[ 0.542807] ACPI: Power Button [PWRF]
[ 0.542892] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input1
[ 0.542900] ACPI: Power Button [PWRB]
[ 0.543213] processor LNXCPU:00: registered as cooling_device0
[ 0.543272] processor LNXCPU:01: registered as cooling_device1
[ 0.546431] isapnp: Scanning for PnP cards...
[ 0.697000] Switched to high resolution mode on CPU 1
[ 0.700087] Switched to high resolution mode on CPU 0
[ 0.900147] isapnp: No Plug & Play device found
[ 0.901946] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.903867] brd: module loaded
[ 0.904614] loop: module loaded
[ 0.904746] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.904926] ata_piix 0000:00:1f.1: version 2.13
[ 0.904953] alloc irq_desc for 18 on node -1
[ 0.904957] alloc kstat_irqs on node -1
[ 0.904968] ata_piix 0000:00:1f.1: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.905064] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.905222] scsi0 : ata_piix
[ 0.905388] scsi1 : ata_piix
[ 0.907679] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xfc00 irq 14
[ 0.907684] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xfc08 irq 15
[ 0.909180] Fixed MDIO Bus: probed
[ 0.909257] PPP generic driver version 2.4.2
[ 0.909453] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.909494] alloc irq_desc for 20 on node -1
[ 0.909498] alloc kstat_irqs on node -1
[ 0.909509] ehci_hcd 0000:02:0a.2: PCI INT C -> GSI 20 (level, low) -> IRQ 20
[ 0.909534] ehci_hcd 0000:02:0a.2: EHCI Host Controller
[ 0.909617] ehci_hcd 0000:02:0a.2: new USB bus registered, assigned bus number 1
[ 0.909681] ehci_hcd 0000:02:0a.2: irq 20, io mem 0xfeafec00
[ 0.920015] ehci_hcd 0000:02:0a.2: USB 2.0 started, EHCI 1.00
[ 0.920141] usb usb1: configuration #1 chosen from 1 choice
[ 0.920189] hub 1-0:1.0: USB hub found
[ 0.920202] hub 1-0:1.0: 4 ports detected
[ 0.920305] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.920337] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.920398] alloc irq_desc for 16 on node -1
[ 0.920402] alloc kstat_irqs on node -1
[ 0.920410] uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.920421] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.920426] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.920482] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.920518] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000e400
[ 0.920648] usb usb2: configuration #1 chosen from 1 choice
[ 0.920690] hub 2-0:1.0: USB hub found
[ 0.920704] hub 2-0:1.0: 2 ports detected
[ 0.920778] alloc irq_desc for 19 on node -1
[ 0.920782] alloc kstat_irqs on node -1
[ 0.920788] uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[ 0.920797] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.920802] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.920853] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 0.920886] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000e800
[ 0.921001] usb usb3: configuration #1 chosen from 1 choice
[ 0.921051] hub 3-0:1.0: USB hub found
[ 0.921067] hub 3-0:1.0: 2 ports detected
[ 0.921138] uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.921146] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.921151] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.921203] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 0.921241] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ec00
[ 0.921365] usb usb4: configuration #1 chosen from 1 choice
[ 0.921409] hub 4-0:1.0: USB hub found
[ 0.921422] hub 4-0:1.0: 2 ports detected
[ 0.921500] alloc irq_desc for 22 on node -1
[ 0.921504] alloc kstat_irqs on node -1
[ 0.921510] uhci_hcd 0000:02:0a.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 0.921518] uhci_hcd 0000:02:0a.0: UHCI Host Controller
[ 0.921567] uhci_hcd 0000:02:0a.0: new USB bus registered, assigned bus number 5
[ 0.921600] uhci_hcd 0000:02:0a.0: irq 22, io base 0x0000b400
[ 0.921729] usb usb5: configuration #1 chosen from 1 choice
[ 0.921771] hub 5-0:1.0: USB hub found
[ 0.921784] hub 5-0:1.0: 2 ports detected
[ 0.921858] alloc irq_desc for 23 on node -1
[ 0.921861] alloc kstat_irqs on node -1
[ 0.921867] uhci_hcd 0000:02:0a.1: PCI INT B -> GSI 23 (level, low) -> IRQ 23
[ 0.921876] uhci_hcd 0000:02:0a.1: UHCI Host Controller
[ 0.921938] uhci_hcd 0000:02:0a.1: new USB bus registered, assigned bus number 6
[ 0.921971] uhci_hcd 0000:02:0a.1: irq 23, io base 0x0000b800
[ 0.922090] usb usb6: configuration #1 chosen from 1 choice
[ 0.922132] hub 6-0:1.0: USB hub found
[ 0.922145] hub 6-0:1.0: 2 ports detected
[ 0.922289] PNP: PS/2 Controller [PNP0f03:PS2M] at 0x60,0x64 irq 12
[ 0.922293] PNP: PS/2 controller doesn't have KBD irq; using default 1
[ 0.925166] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.925177] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.925268] mice: PS/2 mouse device common for all mice
[ 0.925425] rtc_cmos 00:02: RTC can wake from S4
[ 0.925482] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 0.925509] rtc0: alarms up to one month, 114 bytes nvram, hpet irqs
[ 0.925688] device-mapper: uevent: version 1.0.3
[ 0.925876] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[ 0.926028] device-mapper: multipath: version 1.1.0 loaded
[ 0.926033] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.926246] EISA: Probing bus 0 at eisa.0
[ 0.926289] EISA: Detected 0 cards.
[ 0.926473] cpuidle: using governor ladder
[ 0.926480] cpuidle: using governor menu
[ 0.927355] TCP cubic registered
[ 0.927551] NET: Registered protocol family 10
[ 0.928329] lo: Disabled Privacy Extensions
[ 0.928901] NET: Registered protocol family 17
[ 0.928933] Bluetooth: L2CAP ver 2.13
[ 0.928936] Bluetooth: L2CAP socket layer initialized
[ 0.928940] Bluetooth: SCO (Voice Link) ver 0.6
[ 0.928942] Bluetooth: SCO socket layer initialized
[ 0.929027] Bluetooth: RFCOMM TTY layer initialized
[ 0.929032] Bluetooth: RFCOMM socket layer initialized
[ 0.929035] Bluetooth: RFCOMM ver 1.11
[ 0.929095] Using IPI No-Shortcut mode
[ 0.929212] PM: Resume from disk failed.
[ 0.929233] registered taskstats version 1
[ 0.929409] Magic number: 5:461:739
[ 0.929515] rtc_cmos 00:02: setting system clock to 2009-12-02 15:44:05 UTC (1259768645)
[ 0.929520] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.929523] EDD information not available.
[ 1.073750] ata1.00: ATA-6: WDC WD1200BB-22DAA0, 65.13G65, max UDMA/100
[ 1.073755] ata1.00: 234441648 sectors, multi 16: LBA48
[ 1.089250] ata1.00: configured for UDMA/100
[ 1.089433] scsi 0:0:0:0: Direct-Access ATA WDC WD1200BB-22D 65.1 PQ: 0 ANSI: 5
[ 1.089647] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.089732] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
[ 1.089810] sd 0:0:0:0: [sda] Write Protect is off
[ 1.089815] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.089853] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.090069] sda:
[ 1.096297] ata2.00: ATAPI: TSSTcorpDVD-ROM SH-D162C, TS02, max UDMA/33
[ 1.096345] ata2.01: ATAPI: HL-DT-ST DVDRAM GSA-4167B, DL11, max UDMA/33
[ 1.105436] sda1 sda2 sda3 sda4 < sda5
[ 1.129201] ata2.00: configured for UDMA/33
[ 1.139141] sda6 >
[ 1.139693] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.144214] ata2.01: configured for UDMA/33
[ 1.147106] scsi 1:0:0:0: CD-ROM TSSTcorp DVD-ROM SH-D162C TS02 PQ: 0 ANSI: 5
[ 1.149187] sr0: scsi3-mmc drive: 48x/48x cd/rw xa/form2 cdda tray
[ 1.149193] Uniform CD-ROM driver Revision: 3.20
[ 1.149328] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.149416] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.153153] scsi 1:0:1:0: CD-ROM HL-DT-ST DVDRAM GSA-4167B DL11 PQ: 0 ANSI: 5
[ 1.165919] sr1: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.166040] sr 1:0:1:0: Attached scsi CD-ROM sr1
[ 1.166106] sr 1:0:1:0: Attached scsi generic sg2 type 5
[ 1.166149] Freeing unused kernel memory: 540k freed
[ 1.167079] Write protecting the kernel text: 4568k
[ 1.167158] Write protecting the kernel read-only data: 1836k
[ 1.356112] Linux agpgart interface v0.103
[ 1.366330] usb 2-1: new low speed USB device using uhci_hcd and address 2
[ 1.411225] agpgart-intel 0000:00:00.0: Intel 865 Chipset
[ 1.414762] agpgart-intel 0000:00:00.0: AGP aperture is 64M @ 0xf8000000
[ 1.431899] Floppy drive(s): fd0 is 1.44M
[ 1.453858] FDC 0 is a post-1991 82077
[ 1.467620] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 1.467631] e100: Copyright(c) 1999-2006 Intel Corporation
[ 1.467734] e100 0000:02:08.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20
[ 1.491628] e100 0000:02:08.0: PME# disabled
[ 1.505448] e100: eth0: e100_probe: addr 0xfeaff000, irq 20, MAC addr 00:0c:6e:45:9b:43
[ 1.596497] usb 2-1: configuration #1 chosen from 1 choice
[ 1.600013] ohci1394 0000:02:0e.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 1.613026] usbcore: registered new interface driver hiddev
[ 1.627031] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/input/input3
[ 1.627327] generic-usb 0003:046D:C01B.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:1d.0-1/input0
[ 1.627367] usbcore: registered new interface driver usbhid
[ 1.627374] usbhid: v2.6:USB HID core driver
[ 1.655034] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[18] MMIO=[feafd000-feafd7ff] Max Packet=[2048] IR/IT contexts=[4/4]
[ 1.712063] usb 2-2: new low speed USB device using uhci_hcd and address 3
[ 1.963688] usb 2-2: configuration #1 chosen from 1 choice
[ 2.014010] input: USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/input/input4
[ 2.014128] generic-usb 0003:1241:1503.0002: input,hidraw1: USB HID v1.10 Keyboard [ USB Keyboard] on usb-0000:00:1d.0-2/input0
[ 2.103667] input: USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.1/input/input5
[ 2.103791] generic-usb 0003:1241:1503.0003: input,hidraw2: USB HID v1.10 Device [ USB Keyboard] on usb-0000:00:1d.0-2/input1
[ 2.345039] usb 5-1: new full speed USB device using uhci_hcd and address 2
[ 2.499099] usb 5-1: configuration #1 chosen from 1 choice
[ 2.502012] hub 5-1:1.0: USB hub found
[ 2.503902] hub 5-1:1.0: 4 ports detected
[ 2.793938] usb 5-1.1: new full speed USB device using uhci_hcd and address 3
[ 2.920109] usb 5-1.1: configuration #1 chosen from 1 choice
[ 2.932180] Initializing USB Mass Storage driver...
[ 2.934012] scsi2 : SCSI emulation for USB Mass Storage devices
[ 2.934215] usbcore: registered new interface driver usb-storage
[ 2.934224] USB Mass Storage support registered.
[ 2.934822] usb-storage: device found at 3
[ 2.934830] usb-storage: waiting for device to settle before scanning
[ 2.940326] ieee1394: Host added: ID:BUS[0-00:1023] GUID[08004603016e07a5]
[ 3.037975] usb 5-1.1: USB disconnect, address 3
[ 3.363037] usb 5-1.1: new full speed USB device using uhci_hcd and address 4
[ 3.500223] usb 5-1.1: configuration #1 chosen from 1 choice
[ 3.535130] scsi6 : SCSI emulation for USB Mass Storage devices
[ 3.536324] usb-storage: device found at 4
[ 3.536329] usb-storage: waiting for device to settle before scanning
[ 3.612591] PM: Starting manual resume from disk
[ 3.612598] PM: Resume from partition 8:6
[ 3.612602] PM: Checking hibernation image.
[ 3.612832] PM: Resume from disk failed.
[ 3.636779] EXT4-fs (sda3): barriers enabled
[ 3.653483] kjournald2 starting: pid 360, dev sda3:8, commit interval 5 seconds
[ 3.653504] EXT4-fs (sda3): delayed allocation enabled
[ 3.653511] EXT4-fs: file extents enabled
[ 3.654285] EXT4-fs: mballoc enabled
[ 3.654309] EXT4-fs (sda3): mounted filesystem with ordered data mode
[ 4.307236] type=1505 audit(1259768648.876:2): operation="profile_load" pid=383 name=/usr/share/gdm/guest-session/Xsession
[ 4.311330] type=1505 audit(1259768648.878:3): operation="profile_load" pid=384 name=/sbin/dhclient3
[ 4.311970] type=1505 audit(1259768648.878:4): operation="profile_load" pid=384 name=/usr/lib/NetworkManager/nm-dhcp-client.action
[ 4.312348] type=1505 audit(1259768648.882:5): operation="profile_load" pid=384 name=/usr/lib/connman/scripts/dhclient-script
[ 4.375395] type=1505 audit(1259768648.943:6): operation="profile_load" pid=385 name=/usr/bin/evince
[ 4.386465] type=1505 audit(1259768648.954:7): operation="profile_load" pid=385 name=/usr/bin/evince-previewer
[ 4.392883] type=1505 audit(1259768648.962:8): operation="profile_load" pid=385 name=/usr/bin/evince-thumbnailer
[ 4.414477] type=1505 audit(1259768648.982:9): operation="profile_load" pid=387 name=/usr/lib/cups/backend/cups-pdf
[ 4.415230] type=1505 audit(1259768648.982:10): operation="profile_load" pid=387 name=/usr/sbin/cupsd
[ 5.305953] Adding 811240k swap on /dev/sda6. Priority:-1 extents:1 across:811240k
[ 5.950398] udev: starting version 147
[ 5.989272] EXT4-fs (sda3): internal journal on sda3:8
[ 6.849678] EXT4-fs (sda5): barriers enabled
[ 6.866373] kjournald2 starting: pid 586, dev sda5:8, commit interval 5 seconds
[ 6.866609] EXT4-fs (sda5): internal journal on sda5:8
[ 6.866616] EXT4-fs (sda5): delayed allocation enabled
[ 6.866622] EXT4-fs: file extents enabled
[ 6.873635] EXT4-fs: mballoc enabled
[ 6.873662] EXT4-fs (sda5): mounted filesystem with ordered data mode
[ 7.380991] EXT4-fs (sda1): barriers enabled
[ 7.383786] kjournald2 starting: pid 600, dev sda1:8, commit interval 5 seconds
[ 7.383980] EXT4-fs (sda1): internal journal on sda1:8
[ 7.383986] EXT4-fs (sda1): delayed allocation enabled
[ 7.383992] EXT4-fs: file extents enabled
[ 7.384242] EXT4-fs: mballoc enabled
[ 7.384267] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 8.314613] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 8.449699] __ratelimit: 3 callbacks suppressed
[ 8.449704] type=1505 audit(1259765053.018:12): operation="profile_replace" pid=675 name=/usr/share/gdm/guest-session/Xsession
[ 8.452843] type=1505 audit(1259765053.022:13): operation="profile_replace" pid=676 name=/sbin/dhclient3
[ 8.453513] type=1505 audit(1259765053.022:14): operation="profile_replace" pid=676 name=/usr/lib/NetworkManager/nm-dhcp-client.action
[ 8.453865] type=1505 audit(1259765053.022:15): operation="profile_replace" pid=676 name=/usr/lib/connman/scripts/dhclient-script
[ 8.464040] type=1505 audit(1259765053.034:16): operation="profile_replace" pid=677 name=/usr/bin/evince
[ 8.523637] intel_rng: FWH not detected
[ 8.546256] type=1505 audit(1259765053.114:17): operation="profile_replace" pid=677 name=/usr/bin/evince-previewer
[ 8.548352] usb-storage: device scan complete
[ 8.555296] scsi 6:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
[ 8.564137] type=1505 audit(1259765053.134:18): operation="profile_replace" pid=677 name=/usr/bin/evince-thumbnailer
[ 8.588537] type=1505 audit(1259765053.158:19): operation="profile_replace" pid=719 name=/usr/lib/cups/backend/cups-pdf
[ 8.589674] type=1505 audit(1259765053.158:20): operation="profile_replace" pid=719 name=/usr/sbin/cupsd
[ 8.597410] type=1505 audit(1259765053.166:21): operation="profile_replace" pid=720 name=/usr/sbin/tcpdump
[ 8.621892] sr2: scsi-1 drive
[ 8.622235] sr 6:0:0:0: Attached scsi CD-ROM sr2
[ 8.622423] sr 6:0:0:0: Attached scsi generic sg3 type 5
[ 8.777476] nf_conntrack version 0.5.0 (12285 buckets, 49140 max)
[ 8.777999] CONFIG_NF_CT_ACCT is deprecated and will be removed soon. Please use
[ 8.778005] nf_conntrack.acct=1 kernel parameter, acct=1 nf_conntrack module option or
[ 8.778010] sysctl net.netfilter.nf_conntrack_acct=1 to enable it.
[ 8.907823] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 9.001997] lp: driver loaded but no devices found
[ 9.432951] nvidia: module license 'NVIDIA' taints kernel.
[ 9.432961] Disabling lock debugging due to kernel taint
[ 9.519543] usbcore: registered new interface driver usbserial
[ 9.519572] USB Serial support registered for generic
[ 9.519656] usbcore: registered new interface driver usbserial_generic
[ 9.519661] usbserial: USB Serial Driver core
[ 9.580948] USB Serial support registered for GSM modem (1-port)
[ 9.581043] option 5-1.1:1.0: GSM modem (1-port) converter detected
[ 9.581194] usb 5-1.1: GSM modem (1-port) converter now attached to ttyUSB0
[ 9.581215] option 5-1.1:1.1: GSM modem (1-port) converter detected
[ 9.581304] usb 5-1.1: GSM modem (1-port) converter now attached to ttyUSB1
[ 9.581323] option 5-1.1:1.2: GSM modem (1-port) converter detected
[ 9.581410] usb 5-1.1: GSM modem (1-port) converter now attached to ttyUSB2
[ 9.581442] usbcore: registered new interface driver option
[ 9.581446] option: v0.7.2:USB Driver for GSM modems
[ 9.585899] w83627hf: Found W83637HF chip at 0x290
[ 9.690979] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 9.691415] NVRM: loading NVIDIA UNIX x86 Kernel Module 173.14.20 Thu Jun 25 19:23:24 PDT 2009
[ 9.702971] alloc irq_desc for 17 on node -1
[ 9.702979] alloc kstat_irqs on node -1
[ 9.702998] Intel ICH 0000:00:1f.5: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 9.703095] Intel ICH 0000:00:1f.5: setting latency timer to 64
[ 10.131618] intel8x0_measure_ac97_clock: measured 62151 usecs (2993 samples)
[ 10.131625] intel8x0: clocking to 48000
[ 13.873998] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.772969] ppdev: user-space parallel port driver
[ 19.168058] agpgart-intel 0000:00:00.0: AGP 3.0 bridge
[ 19.168082] agpgart-intel 0000:00:00.0: putting AGP V3 device into 8x mode
[ 19.168123] nvidia 0000:01:00.0: putting AGP V3 device into 8x mode
[ 20.498615] CPU0 attaching NULL sched-domain.
[ 20.498626] CPU1 attaching NULL sched-domain.
[ 20.513121] CPU0 attaching sched-domain:
[ 20.513127] domain 0: span 0-1 level SIBLING
[ 20.513132] groups: 0 1
[ 20.513140] domain 1: span 0-1 level MC
[ 20.513144] groups: 0-1 (__cpu_power = 2048)
[ 20.513155] CPU1 attaching sched-domain:
[ 20.513158] domain 0: span 0-1 level SIBLING
[ 20.513162] groups: 1 0
[ 20.513169] domain 1: span 0-1 level MC
[ 20.513173] groups: 0-1 (__cpu_power = 2048)
[ 24.037625] CPU0 attaching NULL sched-domain.
[ 24.037636] CPU1 attaching NULL sched-domain.
[ 24.053122] CPU0 attaching sched-domain:
[ 24.053129] domain 0: span 0-1 level SIBLING
[ 24.053134] groups: 0 1
[ 24.053144] CPU1 attaching sched-domain:
[ 24.053147] domain 0: span 0-1 level SIBLING
[ 24.053151] groups: 1 0
[ 37.181069] UDF-fs: No VRS found
[ 37.181078] UDF-fs: No partition found (1)
[ 37.212104] ISO 9660 Extensions: Microsoft Joliet Level 1
[ 37.217033] ISOFS: changing to secondary root
[ 132.976932] usb 5-1.1: USB disconnect, address 4
[ 132.977918] option: option_instat_callback: error -108
[ 132.978273] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 132.978310] option 5-1.1:1.0: device disconnected
[ 132.978542] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 132.978575] option 5-1.1:1.1: device disconnected
[ 132.978799] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 132.978832] option 5-1.1:1.2: device disconnected
[ 141.041070] usb 5-1.1: new full speed USB device using uhci_hcd and address 5
[ 141.167249] usb 5-1.1: configuration #1 chosen from 1 choice
[ 141.175534] option 5-1.1:1.0: GSM modem (1-port) converter detected
[ 141.175751] usb 5-1.1: GSM modem (1-port) converter now attached to ttyUSB0
[ 141.181765] option 5-1.1:1.1: GSM modem (1-port) converter detected
[ 141.182074] usb 5-1.1: GSM modem (1-port) converter now attached to ttyUSB1
[ 141.187936] option 5-1.1:1.2: GSM modem (1-port) converter detected
[ 141.188244] usb 5-1.1: GSM modem (1-port) converter now attached to ttyUSB2
[ 141.202240] scsi10 : SCSI emulation for USB Mass Storage devices
[ 141.214205] usb-storage: device found at 5
[ 141.214211] usb-storage: waiting for device to settle before scanning
[ 146.213918] usb-storage: device scan complete
[ 146.216925] scsi 10:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
[ 146.252879] sr3: scsi-1 drive
[ 146.253205] sr 10:0:0:0: Attached scsi CD-ROM sr3
[ 146.253393] sr 10:0:0:0: Attached scsi generic sg3 type 5
[ 147.773048] usb 5-1.2: new full speed USB device using uhci_hcd and address 6
[ 147.875059] usb 5-1.2: not running at top speed; connect to a high speed hub
[ 147.903227] usb 5-1.2: configuration #1 chosen from 1 choice
[ 147.911830] scsi11 : SCSI emulation for USB Mass Storage devices
[ 147.912430] usb-storage: device found at 6
[ 147.912436] usb-storage: waiting for device to settle before scanning
[ 152.913869] usb-storage: device scan complete
[ 152.916864] scsi 11:0:0:0: Direct-Access Seagate Portable 0130 PQ: 0 ANSI: 4
[ 152.918268] sd 11:0:0:0: Attached scsi generic sg4 type 0
[ 152.928468] sd 11:0:0:0: [sdb] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 152.930934] sd 11:0:0:0: [sdb] Write Protect is off
[ 152.930946] sd 11:0:0:0: [sdb] Mode Sense: 2f 08 00 00
[ 152.930952] sd 11:0:0:0: [sdb] Assuming drive cache: write through
[ 152.938808] sd 11:0:0:0: [sdb] Assuming drive cache: write through
[ 152.938819] sdb: sdb1
[ 153.214860] sd 11:0:0:0: [sdb] Assuming drive cache: write through
[ 153.214869] sd 11:0:0:0: [sdb] Attached SCSI disk
[ 155.294168] ISO 9660 Extensions: Microsoft Joliet Level 1
[ 155.317198] ISOFS: changing to secondary root
[ 179.877762] PPP BSD Compression module registered
[ 179.894839] PPP Deflate Compression module registered
[ 3632.786648] usb 5-1.2: USB disconnect, address 6
[ 3636.273150] usb 5-1.2: new full speed USB device using uhci_hcd and address 7
[ 3636.375161] usb 5-1.2: not running at top speed; connect to a high speed hub
[ 3636.403333] usb 5-1.2: configuration #1 chosen from 1 choice
[ 3636.408717] scsi12 : SCSI emulation for USB Mass Storage devices
[ 3636.414602] usb-storage: device found at 7
[ 3636.414609] usb-storage: waiting for device to settle before scanning
[ 3641.413967] usb-storage: device scan complete
[ 3641.416950] scsi 12:0:0:0: Direct-Access Seagate Portable 0130 PQ: 0 ANSI: 4
[ 3641.418195] sd 12:0:0:0: Attached scsi generic sg4 type 0
[ 3641.423012] sd 12:0:0:0: [sdb] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 3641.429903] sd 12:0:0:0: [sdb] Write Protect is off
[ 3641.429914] sd 12:0:0:0: [sdb] Mode Sense: 2f 08 00 00
[ 3641.429921] sd 12:0:0:0: [sdb] Assuming drive cache: write through
[ 3641.438903] sd 12:0:0:0: [sdb] Assuming drive cache: write through
[ 3641.438915] sdb: sdb1
[ 3641.696977] sd 12:0:0:0: [sdb] Assuming drive cache: write through
[ 3641.696988] sd 12:0:0:0: [sdb] Attached SCSI disk
[ 7232.489686] usb 5-1.2: USB disconnect, address 7
[ 7235.764170] usb 5-1.2: new full speed USB device using uhci_hcd and address 8
[ 7235.863183] usb 5-1.2: not running at top speed; connect to a high speed hub
[ 7235.891361] usb 5-1.2: configuration #1 chosen from 1 choice
[ 7235.912210] scsi13 : SCSI emulation for USB Mass Storage devices
[ 7235.917463] usb-storage: device found at 8
[ 7235.917470] usb-storage: waiting for device to settle before scanning
[ 7240.921039] usb-storage: device scan complete
[ 7240.924062] scsi 13:0:0:0: Direct-Access Seagate Portable 0130 PQ: 0 ANSI: 4
[ 7240.925143] sd 13:0:0:0: Attached scsi generic sg4 type 0
[ 7240.954342] sd 13:0:0:0: [sdb] 625142448 512-byte logical blocks: (320 GB/298 GiB)
[ 7240.956962] sd 13:0:0:0: [sdb] Write Protect is off
[ 7240.956970] sd 13:0:0:0: [sdb] Mode Sense: 2f 08 00 00
[ 7240.956974] sd 13:0:0:0: [sdb] Assuming drive cache: write through
[ 7240.966919] sd 13:0:0:0: [sdb] Assuming drive cache: write through
[ 7240.966930] sdb: sdb1
[ 7241.222988] sd 13:0:0:0: [sdb] Assuming drive cache: write through
[ 7241.223001] sd 13:0:0:0: [sdb] Attached SCSI disk
[ 7372.560939] sd 13:0:0:0: [sdb] Unhandled error code
[ 7372.560945] sd 13:0:0:0: [sdb] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 7372.560952] end_request: I/O error, dev sdb, sector 249189631
[ 7372.560962] Buffer I/O error on device sdb1, logical block 31148696
[ 7372.561106] sd 13:0:0:0: [sdb] Unhandled error code
[ 7372.561110] sd 13:0:0:0: [sdb] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 7372.561115] end_request: I/O error, dev sdb, sector 249189631
[ 7372.561121] Buffer I/O error on device sdb1, logical block 31148696
[ 7372.563582] usb 5-1.2: USB disconnect, address 8
[ 7375.949336] usb 5-1.2: new full speed USB device using uhci_hcd and address 9
[ 7376.051348] usb 5-1.2: not running at top speed; connect to a high speed hub
[ 7376.079519] usb 5-1.2: configuration #1 chosen from 1 choice
[ 7376.085965] scsi14 : SCSI emulation for USB Mass Storage devices
[ 7376.086473] usb-storage: device found at 9
[ 7376.086479] usb-storage: waiting for device to settle before scanning
