D
derevil
Da steht ziemlich viel drin...
This is a pre-release version of XFree86, and is not supported in any
way. Bugs may be reported to ********** and patches submitted
to **********. Before reporting bugs in pre-release versions,
please check the latest version in the XFree86 CVS repository
(http://www.XFree86.Org/cvs).
XFree86 Version 4.3.0.1
Release Date: 9 May 2003
X Protocol Version 11, Revision 0, Release 6.6
Build Operating System: SuSE Linux [ELF] SuSE
Build Date: 23 September 2003
Before reporting problems, check http://www.XFree86.Org/
Module Loader present
(==) Log file: "/var/log/XFree86.0.log", Time: Wed May 26 14:08:46 2004
(==) Using config file: "/etc/X11/XF86Config-4"
(==) ServerLayout "Server Layout"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "ATI Graphics Adapter"
(**) |-->Input Device "Mouse1"
(**) |-->Input Device "Keyboard1"
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xfree86"
(**) XKB: rules: "xfree86"
(**) Option "XkbModel" "pc104"
(**) XKB: model: "pc104"
(**) Option "XkbLayout" "de"
(**) XKB: layout: "de"
(==) Keyboard: CustomKeycode disabled
(**) FontPath set to "/usr/X11R6/lib/X11/fonts/local/,/usr/X11R6/lib/X11/fonts/misc/,/usr/X11R6/lib/X11/fonts/75dpi/:unscaled,/usr/X11R6/lib/X11/fonts/Type1/,/usr/X11R6/lib/X11/fonts/Speedo/,/usr/X11R6/lib/X11/fonts/75dpi/"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(++) using VT number 7
(WW) Open APM failed (/dev/apm_bios) (No such device)
(II) Module ABI versions:
XFree86 ANSI C Emulation: 0.2
XFree86 Video Driver: 0.6
XFree86 XInput driver : 0.4
XFree86 Server Extension : 0.2
XFree86 Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.0.0
Module class: XFree86 Font Renderer
ABI class: XFree86 Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
ABI class: XFree86 Video Driver, version 0.6
(II) PCI: Probing config type using method 1
(II) PCI: Config type is 1
(II) PCI: stages = 0x03, oldVal1 = 0x800089fc, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 1106,3099 card 0000,0000 rev 00 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 1106,b099 card 0000,0000 rev 00 class 06,04,00 hdr 01
(II) PCI: 00:06:0: chip 100b,0020 card 1385,f311 rev 00 class 02,00,00 hdr 00
(II) PCI: 00:07:0: chip 1102,0002 card 1102,8040 rev 08 class 04,01,00 hdr 80
(II) PCI: 00:07:1: chip 1102,7002 card 1102,0020 rev 08 class 09,80,00 hdr 80
(II) PCI: 00:08:0: chip 1274,5880 card 1274,2000 rev 04 class 04,01,00 hdr 00
(II) PCI: 00:11:0: chip 1106,3074 card 1106,3074 rev 00 class 06,01,00 hdr 80
(II) PCI: 00:11:1: chip 1106,0571 card 1106,0571 rev 06 class 01,01,8a hdr 00
(II) PCI: 00:11:2: chip 1106,3038 card 0925,1234 rev 1b class 0c,03,00 hdr 00
(II) PCI: 00:11:3: chip 1106,3038 card 0925,1234 rev 1b class 0c,03,00 hdr 00
(II) PCI: 00:11:4: chip 1106,3038 card 0925,1234 rev 1b class 0c,03,00 hdr 00
(II) PCI: 01:00:0: chip 1002,4150 card 174b,7c19 rev 00 class 03,00,00 hdr 80
(II) PCI: 01:00:1: chip 1002,4170 card 174b,7c18 rev 00 class 03,80,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,1), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 I/O range:
[0] -1 0 0x00006000 - 0x000060ff (0x100) IX
[1] -1 0 0x00006400 - 0x000064ff (0x100) IX
[2] -1 0 0x00006800 - 0x000068ff (0x100) IX
[3] -1 0 0x00006c00 - 0x00006cff (0x100) IX
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xe4000000 - 0xe5ffffff (0x2000000) MX
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xc0000000 - 0xdfffffff (0x20000000) MX
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:17:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) ATI Technologies Inc unknown chipset (0x4150) rev 0, Mem @ 0xc0000000/28, 0xe5000000/16, I/O @ 0x6000/8
(--) PCI: (1:0:1) ATI Technologies Inc unknown chipset (0x4170) rev 0, Mem @ 0xd0000000/28, 0xe5010000/16
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX
(II) OS-reported resource ranges:
[0] -1 0 0xffe00000 - 0xffffffff (0x200000) MX(B)
[1] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B)
[2] -1 0 0x000f0000 - 0x000fffff (0x10000) MX
[3] -1 0 0x000c0000 - 0x000effff (0x30000) MX
[4] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX
[5] -1 0 0x0000ffff - 0x0000ffff (0x1) IX
[6] -1 0 0x00000000 - 0x000000ff (0x100) IX
(II) PCI Memory resource overlap reduced 0xe0000000 from 0xe3ffffff to 0xdfffffff
(II) Active PCI resource ranges:
[0] -1 0 0xe7000000 - 0xe7000fff (0x1000) MX
[1] -1 0 0xe0000000 - 0xdfffffff (0x0) MXO
[2] -1 0 0xe5010000 - 0xe501ffff (0x10000) MX(B)
[3] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX(B)
[4] -1 0 0xe5000000 - 0xe500ffff (0x10000) MX(B)
[5] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX(B)
[6] -1 0 0x00008c00 - 0x00008c1f (0x20) IX
[7] -1 0 0x00008800 - 0x0000881f (0x20) IX
[8] -1 0 0x00008400 - 0x0000841f (0x20) IX
[9] -1 0 0x00008000 - 0x0000800f (0x10) IX
[10] -1 0 0x00007c00 - 0x00007c3f (0x40) IX
[11] -1 0 0x00007800 - 0x00007807 (0x IX
[12] -1 0 0x00007400 - 0x0000741f (0x20) IX
[13] -1 0 0x00007000 - 0x000070ff (0x100) IX
[14] -1 0 0x00006000 - 0x000060ff (0x100) IX(B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[5] -1 0 0xe7000000 - 0xe7000fff (0x1000) MX
[6] -1 0 0xe0000000 - 0xdfffffff (0x0) MXO
[7] -1 0 0xe5010000 - 0xe501ffff (0x10000) MX(B)
[8] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX(B)
[9] -1 0 0xe5000000 - 0xe500ffff (0x10000) MX(B)
[10] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX(B)
[11] -1 0 0x0000ffff - 0x0000ffff (0x1) IX
[12] -1 0 0x00000000 - 0x000000ff (0x100) IX
[13] -1 0 0x00008c00 - 0x00008c1f (0x20) IX
[14] -1 0 0x00008800 - 0x0000881f (0x20) IX
[15] -1 0 0x00008400 - 0x0000841f (0x20) IX
[16] -1 0 0x00008000 - 0x0000800f (0x10) IX
[17] -1 0 0x00007c00 - 0x00007c3f (0x40) IX
[18] -1 0 0x00007800 - 0x00007807 (0x IX
[19] -1 0 0x00007400 - 0x0000741f (0x20) IX
[20] -1 0 0x00007000 - 0x000070ff (0x100) IX
[21] -1 0 0x00006000 - 0x000060ff (0x100) IX(B)
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
Module class: XFree86 Server Extension
ABI class: XFree86 Server Extension, version 0.2
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "dri"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading extension XFree86-DRI
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.so
(II) Module freetype: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 2.0.2
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="The XFree86 Project"
(II) Loading extension GLX
(II) Reloading /usr/X11R6/lib/modules/extensions/libdri.a
(II) UnloadModule: "dri"
(EE) Failed to load module "dri" (once-only module, 135958787)
(II) LoadModule: "fglrx"
(II) Loading /usr/X11R6/lib/modules/drivers/fglrx_drv.o
(II) Module fglrx: vendor="Fire GL - ATI Research GmbH, Germany"
compiled for 4.3.0.1, module version = 3.7.6
Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
Module class: XFree86 XInput Driver
ABI class: XFree86 XInput driver, version 0.4
(II) FireGL8700/8800: Driver for chipset: ATI RV250 Id (R9000),
ATI RV250 Ie (R9000), ATI RV250 If (R9000), ATI RV250 Ig (R9000),
ATI RV250 Ld (M9), ATI RV250 Le (M9), ATI RV250 Lf (M9),
ATI RV250 Lg (M9), ATI RV280 5960 (R9200 PRO),
ATI RV280 Ya (R9200LE), ATI RV250SE Yd (R9200SE),
ATI RV250 5C61 (M9+), ATI RV250 5C63 (M9+), ATI R200 QH (R8500),
ATI R200 QL (R8500), ATI R200 QM (R9100), ATI R200 QT (R8500),
ATI R200 QU (R9100), ATI R200 BB (R8500), ATI RV350 AP (R9600),
ATI RV350SE AQ (R9600SE), ATI RV350 AR (R9600 PRO),
ATI RV350 NP (M10), ATI R300 AD (R9500), ATI R300 AE (R9500),
ATI R300 AF (R9500), ATI R300 AG (Fire GL Z1/X1),
ATI R300 ND (R9700 PRO), ATI R300 NE (R9700/R9500 PRO),
ATI R300 NF (R9600 TX), ATI R300 NG (Fire GL X1),
ATI R350SE AH (R9800SE), ATI R350 AK (Fire GL unknown),
ATI RV350 AT (Fire GL T2), ATI RV350 AU (Fire GL T2),
ATI RV350 AV (Fire GL T2), ATI RV350 AW (Fire GL T2),
ATI R350 NH (R9800), ATI R350LE NI (R9800LE), ATI R350 NJ (R9800),
ATI R350 NK (Fire GL X2), ATI RV350 NT (WS/M10)
(II) Primary Device is: PCI 01:00:0
(WW) fglrx: No matching Device section for instance (BusID PCI:1:0:1) found
(--) Chipset ATI RV350 AP (R9600) found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) fglrx(0): pEnt->device->identifier=0x820d288
(II) resource ranges after probing:
[11] 0 0 0x000a0000 - 0x000affff (0x10000) MS
[12] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS
[13] 0 0 0x000b8000 - 0x000bffff (0x8000) MS
[14] -1 0 0x0000ffff - 0x0000ffff (0x1) IX
[15] -1 0 0x00000000 - 0x000000ff (0x100) IX
[16] -1 0 0x00008c00 - 0x00008c1f (0x20) IX
[17] -1 0 0x00008800 - 0x0000881f (0x20) IX
[18] -1 0 0x00008400 - 0x0000841f (0x20) IX
[19] -1 0 0x00008000 - 0x0000800f (0x10) IX
[20] -1 0 0x00007c00 - 0x00007c3f (0x40) IX
[21] -1 0 0x00007800 - 0x00007807 (0x IX
[22] -1 0 0x00007400 - 0x0000741f (0x20) IX
[23] -1 0 0x00007000 - 0x000070ff (0x100) IX
[24] -1 0 0x00006000 - 0x000060ff (0x100) IX(B)
[25] 0 0 0x000003b0 - 0x000003bb (0xc) IS
[26] 0 0 0x000003c0 - 0x000003df (0x20) IS
(II) Setting vga for screen 0.
(II) fglrx(0): === [R200PreInit] === begin,
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/X11R6/lib/modules/libvgahw.a
(II) Module vgahw: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 0.1.0
(II) fglrx(0): PCI bus 1 card 0 func 0
(**) fglrx(0): Depth 24, (--) framebuffer bpp 32
(II) fglrx(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) fglrx(0): Default visual is TrueColor
(**) fglrx(0): Option "NoAccel" "no"
(**) fglrx(0): Option "NoDRI" "no"
(**) fglrx(0): Option "Capabilities" "0x00000000"
(**) fglrx(0): Option "GammaCorrectionI" "0x00000000"
(**) fglrx(0): Option "GammaCorrectionII" "0x00000000"
(**) fglrx(0): Option "OpenGLOverlay" "off"
(**) fglrx(0): Option "VideoOverlay" "on"
(**) fglrx(0): Option "DesktopSetup" "0x00000000"
(**) fglrx(0): Option "MonitorLayout" "AUTO, AUTO"
(**) fglrx(0): Option "HSync2" "unspecified"
(**) fglrx(0): Option "VRefresh2" "unspecified"
(**) fglrx(0): Option "ScreenOverlap" "0"
(**) fglrx(0): Option "IgnoreEDID" "off"
(**) fglrx(0): Option "UseInternalAGPGART" "yes"
(**) fglrx(0): Option "Stereo" "off"
(**) fglrx(0): Option "StereoSyncEnable" "1"
(**) fglrx(0): Option "UseFastTLS" "0"
(**) fglrx(0): Option "BlockSignalsOnLock" "on"
(**) fglrx(0): Option "ForceGenericCPU" "no"
(**) fglrx(0): Option "CenterMode" "off"
(**) fglrx(0): Option "FSAAScale" "1"
(**) fglrx(0): Option "FSAAEnable" "no"
(**) fglrx(0): Option "FSAADisableGamma" "no"
(**) fglrx(0): Option "FSAACustomizeMSPos" "no"
(**) fglrx(0): Option "FSAAMSPosX0" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY0" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX1" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY1" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX2" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY2" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX3" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY3" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX4" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY4" "0.000000"
(**) fglrx(0): Option "FSAAMSPosX5" "0.000000"
(**) fglrx(0): Option "FSAAMSPosY5" "0.000000"
(**) fglrx(0): Option "NoTV" "yes"
(**) fglrx(0): Option "TVStandard" "NTSC-M"
(**) fglrx(0): Option "TVHSizeAdj" "0"
(**) fglrx(0): Option "TVVSizeAdj" "0"
(**) fglrx(0): Option "TVHPosAdj" "0"
(**) fglrx(0): Option "TVVPosAdj" "0"
(**) fglrx(0): Option "TVHStartAdj" "0"
(**) fglrx(0): Option "TVColorAdj" "0"
(**) fglrx(0): Option "PseudoColorVisuals" "off"
(**) fglrx(0): Qbs disabled
(==) fglrx(0): RGB weight 888
(II) fglrx(0): Using 8 bits per RGB (8 bit DAC)
(**) fglrx(0): Gamma Correction for I is 0x00000000
(**) fglrx(0): Gamma Correction for II is 0x00000000
(==) fglrx(0): Buffer Tiling is ON
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) fglrx(0): initializing int10
(II) fglrx(0): Primary V_BIOS segment is: 0xc000
(**) fglrx(0): Option "mtrr" "off"
(--) fglrx(0): Chipset: "ATI RV350 AP (R9600)" (Chipset = 0x4150)
(--) fglrx(0): (PciSubVendor = 0x174b, PciSubDevice = 0x7c19)
(--) fglrx(0): board vendor info: third party grafics adapter - NOT original ATI
(--) fglrx(0): Linear framebuffer (phys) at 0xc0000000
(--) fglrx(0): MMIO registers at 0xe5000000
(--) fglrx(0): ChipExtRevID = 0x00
(--) fglrx(0): ChipIntRevID = 0x04
(--) fglrx(0): VideoRAM: 131072 kByte (64-bit SDR SDRAM)
(WW) fglrx(0): board is an unknown third party board, chipset is supported
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="The XFree86 Project"
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Loading /usr/X11R6/lib/modules/libi2c.a
(II) Module i2c: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.2.0
(II) fglrx(0): I2C bus "DDC" initialized.
(II) fglrx(0): Connector Layout from BIOS --------
(II) fglrx(0): Connector1: DDCType-3, DACType-0, TMDSType--1, ConnectorType-2
(II) fglrx(0): Connector0: DDCType-2, DACType-1, TMDSType-0, ConnectorType-3
(**) fglrx(0): MonitorLayout Option:
Monitor1--Type AUTO, Monitor2--Type AUTO
(II) fglrx(0): I2C device "DDC:ddc2" registered at address 0xA0.
(II) fglrx(0): I2C device "DDC:ddc2" removed.
(II) fglrx(0): DDC detected on DDCType 2 with Monitor Type 3
(II) fglrx(0): DDC detected on DDCType 3 with Monitor Type 0
(II) fglrx(0): Primary head:
Monitor -- TMDS
Connector -- DVI-I
DAC Type -- TVDAC/ExtDAC
TMDS Type -- Internal
DDC Type -- DVI_DDC
(II) fglrx(0): Secondary head:
Monitor -- NONE
Connector -- VGA
DAC Type -- Primary
TMDS Type -- NONE
DDC Type -- VGA_DDC
(II) fglrx(0): EDID data from the display on Primary head ----------------
(II) fglrx(0): Manufacturer: SAM Model: 21 Serial#: 1195913528
(II) fglrx(0): Year: 2002 Week: 33
(II) fglrx(0): EDID Version: 1.3
(II) fglrx(0): Digital Display Input
(II) fglrx(0): Max H-Image Size [cm]: horiz.: 34 vert.: 27
(II) fglrx(0): Gamma: 2.40
(II) fglrx(0): DPMS capabilities: Off; RGB/Color Display
(II) fglrx(0): First detailed timing is preferred mode
(II) fglrx(0): redX: 0.634 redY: 0.354 greenX: 0.304 greenY: 0.581
(II) fglrx(0): blueX: 0.143 blueY: 0.102 whiteX: 0.318 whiteY: 0.339
(II) fglrx(0): Supported VESA Video Modes:
(II) fglrx(0): 720x400@70Hz
(II) fglrx(0): 640x480@60Hz
(II) fglrx(0): 640x480@67Hz
(II) fglrx(0): 640x480@72Hz
(II) fglrx(0): 640x480@75Hz
(II) fglrx(0): 800x600@56Hz
(II) fglrx(0): 800x600@60Hz
(II) fglrx(0): 800x600@72Hz
(II) fglrx(0): 800x600@75Hz
(II) fglrx(0): 832x624@75Hz
(II) fglrx(0): 1024x768@60Hz
(II) fglrx(0): 1024x768@70Hz
(II) fglrx(0): 1024x768@75Hz
(II) fglrx(0): 1280x1024@75Hz
(II) fglrx(0): 1152x870@75Hz
(II) fglrx(0): Manufacturer's mask: 0
(II) fglrx(0): Supported Future Video Modes:
(II) fglrx(0): #0: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
(II) fglrx(0): #1: hsize: 1024 vsize 768 refresh: 60 vid: 16481
(II) fglrx(0): #2: hsize: 800 vsize 600 refresh: 60 vid: 16453
(II) fglrx(0): #3: hsize: 640 vsize 480 refresh: 60 vid: 16433
(II) fglrx(0): Supported additional Video Mode:
(II) fglrx(0): clock: 108.0 MHz Image Size: 338 x 270 mm
(II) fglrx(0): h_active: 1280 h_sync: 1328 h_sync_end 1440 h_blank_end 1688 h_border: 0
(II) fglrx(0): v_active: 1024 v_sync: 1025 v_sync_end 1028 v_blanking: 1066 v_border: 0
(II) fglrx(0): Ranges: V min: 56 V max: 85 Hz, H min: 30 H max: 81 kHz, PixClock max 130 MHz
(II) fglrx(0): Monitor name: SyncMaster
(II) fglrx(0): Serial No: H4JT803172
(II) fglrx(0):
(II) fglrx(0): DesktopSetup 0x0000
(**) fglrx(0): PseudoColor visuals disabled
(**) fglrx(0): Overlay disabled
(II) fglrx(0): PLL parameters: rf=2700 rd=12 min=20000 max=50000; xclk=29700
(==) fglrx(0): Using gamma correction (1.0, 1.0, 1.0)
(**) fglrx(0): Center Mode is disabled
(==) fglrx(0): TMDS coherent mode is enabled
(II) fglrx(0): Panel size found from DDC: 1280x1024
(II) fglrx(0): Total 5 valid mode(s) found.
(--) fglrx(0): Virtual size is 1280x1024 (pitch 1280)
(**) fglrx(0): *Default mode "1280x1024": 135.0 MHz (scaled from 0.0 MHz), 80.0 kHz, 75.0 Hz
(II) fglrx(0): Modeline "1280x1024" 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync
(**) fglrx(0): Default mode "1024x768": 78.8 MHz (scaled from 0.0 MHz), 60.1 kHz, 75.1 Hz
(II) fglrx(0): Modeline "1024x768" 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
(**) fglrx(0): Default mode "832x624": 57.3 MHz (scaled from 0.0 MHz), 49.7 kHz, 74.6 Hz
(II) fglrx(0): Modeline "832x624" 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync
(**) fglrx(0): Default mode "800x600": 50.0 MHz (scaled from 0.0 MHz), 48.1 kHz, 72.2 Hz
(II) fglrx(0): Modeline "800x600" 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync
(**) fglrx(0): Default mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz
(II) fglrx(0): Modeline "640x480" 31.50 640 656 720 840 480 481 484 500 -hsync -vsync
(--) fglrx(0): Display dimensions: (340, 270) mm
(--) fglrx(0): DPI set to (95, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/X11R6/lib/modules/libfb.a
(II) Module fb: vendor="The XFree86 Project"
ABI class: XFree86 ANSI C Emulation, version 0.2
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/X11R6/lib/modules/libramdac.a
(II) Module ramdac: vendor="The XFree86 Project"
(**) fglrx(0): NoAccel = NO
(II) Loading sub module "xaa"
(II) LoadModule: "xaa"
(II) Loading /usr/X11R6/lib/modules/libxaa.a
(II) Module xaa: vendor="The XFree86 Project"
compiled for 4.3.0.1, module version = 1.1.0
(==) fglrx(0): HPV inactive
(==) fglrx(0): FSAA enabled: NO
(**) fglrx(0): FSAA Gamma enabled
(**) fglrx(0): FSAA Multisample Position is fix
(**) fglrx(0): NoDRI = NO
(II) Loading sub module "fglrxdrm"
(II) LoadModule: "fglrxdrm"
(II) Loading /usr/X11R6/lib/modules/linux/libfglrxdrm.a
(II) Module fglrxdrm: vendor="Fire GL - ATI Research GmbH, Germany"
(II) fglrx(0): Depth moves disabled by default
(**) fglrx(0): Capabilities: 0x00000000
(**) fglrx(0): cpuFlags: 0x4000000f
(**) fglrx(0): cpuSpeedMHz: 0x000005ba
(==) fglrx(0): OpenGL ClientDriverName: "fglrx_dri.so"
(**) fglrx(0): using built in AGPGART module: yes
(**) fglrx(0): UseFastTLS=0
(**) fglrx(0): BlockSignalsOnLock=1
(==) fglrx(0): EnablePrivateBackZ = NO
(II) fglrx(0): using CAIL version [ATI LIB=CAIL.LIB,IA32,2.0024]
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xe5000000 - 0xe500ffff (0x10000) MX
[1] 0 0 0xc0000000 - 0xcfffffff (0x10000000) MX
[2] -1 0 0xffe00000 - 0xffffffff (0x200000) MX(B)
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MXE(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX
[7] -1 0 0xe7000000 - 0xe7000fff (0x1000) MX
[8] -1 0 0xe0000000 - 0xdfffffff (0x0) MXO
[9] -1 0 0xe5010000 - 0xe501ffff (0x10000) MX(B)
[10] -1 0 0xd0000000 - 0xdfffffff (0x10000000) MX(B)
[11] -1 0 0xe5000000 - 0xe500ffff (0x10000) MX(B)
[12] -1 0 0xc0000000 - 0xcfffffff (0x10000000) MX(B)
[13] 0 0 0x000a0000 - 0x000affff (0x10000) MS
[14] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS
[15] 0 0 0x000b8000 - 0x000bffff (0x8000) MS
[16] 0 0 0x00006000 - 0x000060ff (0x100) IX
[17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX
[18] -1 0 0x00000000 - 0x000000ff (0x100) IX
[19] -1 0 0x00008c00 - 0x00008c1f (0x20) IX
[20] -1 0 0x00008800 - 0x0000881f (0x20) IX
[21] -1 0 0x00008400 - 0x0000841f (0x20) IX
[22] -1 0 0x00008000 - 0x0000800f (0x10) IX
[23] -1 0 0x00007c00 - 0x00007c3f (0x40) IX
[24] -1 0 0x00007800 - 0x00007807 (0x IX
[25] -1 0 0x00007400 - 0x0000741f (0x20) IX
[26] -1 0 0x00007000 - 0x000070ff (0x100) IX
[27] -1 0 0x00006000 - 0x000060ff (0x100) IX(B)
[28] 0 0 0x000003b0 - 0x000003bb (0xc) IS
[29] 0 0 0x000003c0 - 0x000003df (0x20) IS
(WW) fglrx(0): Cannot read colourmap from VGA. Will restore with default
(II) fglrx(0): UMM area: 0xc0700000 (size=0x07900000)
(II) fglrx(0): driver needs XFree86 version: 4.3.x
(II) fglrx(0): detected XFree86 version: 4.3.0
(II) Loading extension ATIFGLRXDRI
(II) fglrx(0): doing DRIScreenInit
drmOpenDevice: minor is 0
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is -1, (No such device)
drmOpenDevice: Open failed
drmOpenDevice: open result is 7, (OK)
drmGetBusid returned ''
(II) fglrx(0): [drm] loaded kernel module for "fglrx" driver
(II) fglrx(0): [drm] created "fglrx" driver at busid "PCI:1:0:0"
(II) fglrx(0): [drm] added 8192 byte SAREA at 0xf48f0000
(II) fglrx(0): [drm] mapped SAREA 0xf48f0000 to 0x40022000
(II) fglrx(0): [drm] framebuffer handle = 0xc0000000
(II) fglrx(0): [drm] added 1 reserved context for kernel
(II) fglrx(0): DRIScreenInit done
(II) fglrx(0): Kernel Module Version Information:
(II) fglrx(0): Name: fglrx
(II) fglrx(0): Version: 3.2.7
(II) fglrx(0): Date: Sep 4 2003
(II) fglrx(0): Desc: ATI Fire GL DRM kernel module
(WW) fglrx(0): Kernel Module version does *not* match driver.
(EE) fglrx(0): incompatible kernel module detected - HW accelerated OpenGL will not work
(II) fglrx(0): [drm] removed 1 reserved context for kernel
(II) fglrx(0): [drm] unmapping 8192 bytes of SAREA 0xf48f0000 at 0x40022000
(WW) fglrx(0): ***********************************************
(WW) fglrx(0): * DRI initialization failed! *
(WW) fglrx(0): * (maybe driver kernel module missing or bad) *
(WW) fglrx(0): * 2D acceleraton available (MMIO) *
(WW) fglrx(0): * no 3D acceleration available *
(WW) fglrx(0): ********************************************* *
(II) fglrx(0): FBADPhys: 0xc0000000 FBMappedSize: 0x08000000
(II) fglrx(0): ----------------------------------
(II) fglrx(0): | panel native mode is 1280x1024 |
(II) fglrx(0): FBMM initialized for area (0,0)-(1280,8191)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(1280,1024) (front color buffer - assumption)
(==) fglrx(0): Backing store disabled
(==) fglrx(0): Silken mouse enabled
(II) fglrx(0): Using hardware cursor (scanline 1024)
(II) fglrx(0): Largest offscreen area available: 1280 x 7163
(**) Option "dpms"
(**) fglrx(0): DPMS enabled
(II) fglrx(0): Using XFree86 Acceleration Architecture (XAA)
Screen to screen bit blits
Solid filled rectangles
Solid Horizontal and Vertical Lines
Offscreen Pixmaps
Setting up tile and stipple cache:
32 128x128 slots
32 256x256 slots
16 512x512 slots
(II) fglrx(0): Acceleration enabled
(II) fglrx(0): Direct rendering disabled
(II) Loading extension FGLRXEXTENSION
(II) Loading extension ATITVOUT
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension LBX
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(**) Option "Protocol" "ExplorerPS/2"
(**) Mouse1: Protocol: "ExplorerPS/2"
(**) Option "CorePointer"
(**) Mouse1: Core Pointer
(**) Option "Device" "/dev/mouse"
(**) Mouse1: Emulate3Buttons, Emulate3Timeout: 50
(==) Mouse1: Buttons: 3
(II) Keyboard "Keyboard1" handled by legacy driver
(II) XINPUT: Adding extended input device "Mouse1" (type: MOUSE)
(II) Mouse1: ps2EnableDataReporting: succeeded
Could not init font path element /usr/X11R6/lib/X11/fonts/local/, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/Speedo/, removing from list!
