>>> Unpacking source...
Unpacking parts of kdebase-workspace-4.1.0.tar.bz2 to /var/tmp/portage/kde-base/systemsettings-4.1.0/work
>>> Source unpacked.
>>> Compiling source in /var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0 ...
-- Check for working C compiler: /usr/bin/x86_64-pc-linux-gnu-gcc
-- Check for working C compiler: /usr/bin/x86_64-pc-linux-gnu-gcc -- works
-- Check size of void*
-- Check size of void* - done
-- Check for working CXX compiler: /usr/bin/x86_64-pc-linux-gnu-g++
-- Check for working CXX compiler: /usr/bin/x86_64-pc-linux-gnu-g++ -- works
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - found
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found.
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found.
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found.
-- Found Qt-Version 4.4.0 (using /usr/bin/qmake)
-- Looking for XOpenDisplay in /usr/lib64/libX11.so;/usr/lib64/libXext.so;/usr/lib64/libXft.so;/usr/lib64/libXau.so;/usr/lib64/libXdmcp.so;/usr/lib64/libXpm.so
-- Looking for XOpenDisplay in /usr/lib64/libX11.so;/usr/lib64/libXext.so;/usr/lib64/libXft.so;/usr/lib64/libXau.so;/usr/lib64/libXdmcp.so;/usr/lib64/libXpm.so - found
-- Looking for gethostbyname
-- Looking for gethostbyname - found
-- Looking for connect
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found X11: /usr/lib64/libX11.so
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Automoc4: /usr/bin/automoc4
-- Performing Test _OFFT_IS_64BIT
-- Performing Test _OFFT_IS_64BIT - Success
-- Performing Test HAVE_FPIE_SUPPORT
-- Performing Test HAVE_FPIE_SUPPORT - Success
-- Performing Test __KDE_HAVE_W_OVERLOADED_VIRTUAL
-- Performing Test __KDE_HAVE_W_OVERLOADED_VIRTUAL - Success
-- Performing Test __KDE_HAVE_GCC_VISIBILITY
-- Performing Test __KDE_HAVE_GCC_VISIBILITY - Success
-- Found Phonon: /usr/lib64/qt4/libphonon.so
-- Found Phonon Includes: /usr/include/qt4/KDE;/usr/include/qt4
-- Found KDE 4.1 include dir: /usr/kde/4.1/include
-- Found KDE 4.1 library dir: /usr/kde/4.1/lib64
-- Found KDE4 kconfig_compiler preprocessor: /usr/kde/4.1/bin/kconfig_compiler
-- Found automoc4: /usr/bin/automoc4
-- Found Strigi >= 0.5.9
-- Found Strigi: /usr/lib64/libstreams.so
-- Found QImageBlitz: /usr/include/qimageblitz
-- Found LIBUSB: /lib64/libusb.so
-- Found Fontconfig: /usr/lib64/libfontconfig.so
-- Performing Test PAM_MESSAGE_CONST
-- Performing Test PAM_MESSAGE_CONST - Success
-- Found PAM: /lib64/libpam.so;/usr/lib64/libdl.so
-- Looking for getspnam
-- Looking for getspnam - found
-- Looking for crypt in crypt
-- Looking for crypt in crypt - found
-- Looking for include files HAVE_CRYPT_H
-- Looking for include files HAVE_CRYPT_H - found
-- Looking for XkbLockModifiers in X11
-- Looking for XkbLockModifiers in X11 - found
-- Looking for getpassphrase
-- Looking for getpassphrase - not found
-- Looking for vsyslog
-- Looking for vsyslog - found
-- Looking for statvfs
-- Looking for statvfs - found
-- Looking for include files HAVE_LIMITS_H
-- Looking for include files HAVE_LIMITS_H - found
-- Looking for include files HAVE_SYS_TIME_H
-- Looking for include files HAVE_SYS_TIME_H - found
-- Looking for include files HAVE_STDINT_H
-- Looking for include files HAVE_STDINT_H - found
-- Looking for include files HAVE_SYS_VFS_H
-- Looking for include files HAVE_SYS_VFS_H - found
-- Looking for include files HAVE_SYS_STATVFS_H
-- Looking for include files HAVE_SYS_STATVFS_H - found
-- Looking for include files HAVE_SYS_PARAM_H
-- Looking for include files HAVE_SYS_PARAM_H - found
-- Looking for include files HAVE_SYS_MOUNT_H
-- Looking for include files HAVE_SYS_MOUNT_H - found
-- Looking for include files HAVE_SYS_STATFS_H
-- Looking for include files HAVE_SYS_STATFS_H - found
-- Looking for statfs
-- Looking for statfs - found
-- Check size of struct ucred
-- Check size of struct ucred - failed
-- Looking for getpeereid
-- Looking for getpeereid - not found
-- checking for module 'xrandr>=1.2'
-- found xrandr, version 1.2.3
-- Found Freetype: -lfreetype -lz
-- Found LibXKlavier: -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/include/libxml2
-- Found GLIB2: /usr/lib64/libglib-2.0.so
-- Found GObject libraries: /usr/lib64/libgobject-2.0.so;/usr/lib64/libgmodule-2.0.so;/usr/lib64/libgthread-2.0.so;/usr/lib64/libglib-2.0.so
-- Found GObject includes : /usr/include/glib-2.0/gobject
-- Looking for glXChooseVisual in GL
-- Looking for glXChooseVisual in GL - found
-- /var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol: skipped subdir $(KSMCARD_SUBDIR)
-- The following external packages were located on your system.
-- This installation will have the extra features provided by these packages.
+ libxklavier
+ libusb
+ libxft
Congratulations! All external packages have been found.
-- Configuring done
-- Generating done
-- Build files have been written to: /var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings_build
[34m[1mGenerating mainwindow.moc
[0m[34m[1mGenerating kcmultiwidget.moc
[0m[34m[1mGenerating moc_kcmodulemodel.cpp
[0m[35m[1mScanning dependencies of target systemsettings
[0m[ 0%] [32mBuilding CXX object systemsettings/CMakeFiles/systemsettings.dir/systemsettings_automoc.o
[0m[ 0%] [32mBuilding CXX object systemsettings/CMakeFiles/systemsettings.dir/kcmodulemodel.o
[0m[ 1%] [32mBuilding CXX object systemsettings/CMakeFiles/systemsettings.dir/kcmultiwidget.o
[0m[ 1%] [32mBuilding CXX object systemsettings/CMakeFiles/systemsettings.dir/main.o
[0m[ 2%] [32mBuilding CXX object systemsettings/CMakeFiles/systemsettings.dir/mainwindow.o
[0m[ 2%] [32mBuilding CXX object systemsettings/CMakeFiles/systemsettings.dir/menuitem.o
[0m[ 2%] [32mBuilding CXX object systemsettings/CMakeFiles/systemsettings.dir/moduleiconitem.o
[0m[31m[1mLinking CXX executable systemsettings
[0m[ 2%] Built target systemsettings
[ 2%] [34m[1mGenerating ui_outputconfigbase.h
[0m[34m[1mGenerating legacyrandrscreen.moc
[0m[34m[1mGenerating randrcrtc.moc
[0m[34m[1mGenerating collapsiblewidget.moc
[0m[34m[1mGenerating krandrmodule.moc
[0m[34m[1mGenerating randrconfig.moc
[0m[34m[1mGenerating randrscreen.moc
[0m[34m[1mGenerating legacyrandrconfig.moc
[0m[34m[1mGenerating outputconfig.moc
[0m[34m[1mGenerating outputgraphicsitem.moc
[0m[34m[1mGenerating ktimerdialog.moc
[0m[34m[1mGenerating randroutput.moc
[0m[34m[1mGenerating moc_layoutmanager.cpp
[0m[ 3%] [34m[1mGenerating ui_legacyrandrconfigbase.h
[0m[ 3%] [34m[1mGenerating ui_randrconfigbase.h
[0m[35m[1mScanning dependencies of target kcm_randr
[0m[ 4%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/kcm_randr_automoc.o
[0m[ 4%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/krandrmodule.o
[0m[ 5%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/legacyrandrconfig.o
[0m[ 5%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/ktimerdialog.o
[0m/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/randr/ktimerdialog.cpp: In member function 'void KTimerDialog::slotInternalTimeout()':
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/randr/ktimerdialog.cpp:173: warning: enumeration value 'Reset' not handled in switch
[ 6%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/randr.o
[0m[ 6%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/randrdisplay.o
[0m[ 6%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/collapsiblewidget.o
[0m/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/randr/collapsiblewidget.cpp: In member function 'void CollapsibleWidget::animateCollapse(qreal)':
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/randr/collapsiblewidget.cpp:258: warning: converting to 'int' from 'qreal'
[ 7%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/legacyrandrscreen.o
[0m[ 7%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/layoutmanager.o
[0m[ 8%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/outputconfig.o
[0m/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/randr/outputconfig.cpp:93: warning: unused parameter 'output'
[ 8%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/outputgraphicsitem.o
[0m[ 8%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/randrconfig.o
[0m[ 9%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/randrcrtc.o
[0m[ 9%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/randrmode.o
[0m[ 10%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/randroutput.o
[0m[ 10%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/kcm_randr.dir/randrscreen.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_randr.so
[0m[ 10%] Built target kcm_randr
[0m[34m[1mGenerating krandrtray.moc
[0m[34m[1mGenerating krandrpassivepopup.moc
[0m[34m[1mGenerating krandrapp.moc
[0m[35m[1mScanning dependencies of target krandrtray
[0m[ 11%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/krandrtray_automoc.o
[0m[ 11%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/main.o
[0m[ 12%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/krandrtray.o
[0m[ 12%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/krandrapp.o
[0m[ 12%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/krandrpassivepopup.o
[0m[ 13%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/ktimerdialog.o
[ 13%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/randr.o
[0m[ 14%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/randrdisplay.o
[0m[ 14%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/collapsiblewidget.o
[ 15%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/legacyrandrscreen.o
[0m[ 15%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/layoutmanager.o
[0m[ 15%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/outputconfig.o
[ 16%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/outputgraphicsitem.o
[0m[ 16%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/randrconfig.o
[0m[ 17%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/randrcrtc.o
[0m[ 17%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/randrmode.o
[0m[ 17%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/randroutput.o
[0m[ 18%] [32mBuilding CXX object kcontrol/randr/CMakeFiles/krandrtray.dir/randrscreen.o
[0m[31m[1mLinking CXX executable krandrtray
[0m[ 18%] Built target krandrtray
[ 19%] [34m[1mGenerating ui_kcmlayoutwidget.h
[0m[34m[1mGenerating kcmlayout.moc
[0m[35m[1mScanning dependencies of target kcm_keyboard_layout
[0m[ 19%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kcm_keyboard_layout.dir/kcm_keyboard_layout_automoc.o
[0m[ 20%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kcm_keyboard_layout.dir/kcmlayout.o
[0m[ 20%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kcm_keyboard_layout.dir/rules.o
[0m[ 21%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kcm_keyboard_layout.dir/kxkbconfig.o
[0m[ 21%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kcm_keyboard_layout.dir/extension.o
[0m[ 21%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kcm_keyboard_layout.dir/x11helper.o
[0m[ 22%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kcm_keyboard_layout.dir/pixmap.o
[0m[ 22%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kcm_keyboard_layout.dir/xklavier_adaptor.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_keyboard_layout.so
[0m[ 22%] Built target kcm_keyboard_layout
[34m[1mGenerating kxkbcore.moc
[0m[34m[1mGenerating kxkbwidget.moc
[0m[34m[1mGenerating kxkb_adaptor.moc
[0m[34m[1mGenerating kxkbapp.moc
[0m[34m[1mGenerating moc_kxkb_part.cpp
[0m[35m[1mScanning dependencies of target kdeinit_kxkb
[0m[ 22%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kdeinit_kxkb.dir/kdeinit_kxkb_automoc.o
[0m[ 22%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kdeinit_kxkb.dir/rules.o
[0m[ 23%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kdeinit_kxkb.dir/kxkbconfig.o
[0m[ 23%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kdeinit_kxkb.dir/extension.o
[0m[ 24%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kdeinit_kxkb.dir/x11helper.o
[0m[ 24%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kdeinit_kxkb.dir/pixmap.o
[0m[ 25%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kdeinit_kxkb.dir/xklavier_adaptor.o
[0m[ 25%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kdeinit_kxkb.dir/kxkbcore.o
[0m[ 25%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kdeinit_kxkb.dir/layoutmap.o
[0m[ 26%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kdeinit_kxkb.dir/kxkbapp.o
[0m[ 26%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kdeinit_kxkb.dir/kxkbwidget.o
[0m[ 27%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kdeinit_kxkb.dir/kxkb_adaptor.o
[0m[ 27%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kdeinit_kxkb.dir/kxkb_part.o
[0m/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/kxkb/kxkb_part.cpp:37: warning: unused parameter 'args'
[31m[1mLinking CXX shared library ../../lib/libkdeinit4_kxkb.so
[0m[ 27%] Built target kdeinit_kxkb
[35m[1mScanning dependencies of target kxkb
[0m[ 27%] [32mBuilding CXX object kcontrol/kxkb/CMakeFiles/kxkb.dir/kxkb_dummy.o
[0m[31m[1mLinking CXX executable kxkb
[0m[ 27%] Built target kxkb
[ 28%] [34m[1mGenerating ui_kcmmiscwidget.h
[0m[34m[1mGenerating kcmmisc.moc
[0m[ 29%] [32mBuilding CXX object kcontrol/keyboard/CMakeFiles/kcm_keyboard.dir/kcm_keyboard_automoc.o
[0m[ 29%] [32mBuilding CXX object kcontrol/keyboard/CMakeFiles/kcm_keyboard.dir/kcmmisc.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_keyboard.so
[0m[ 29%] Built target kcm_keyboard
[34m[1mGenerating bell.moc
[0m[35m[1mScanning dependencies of target kcm_bell
[0m[ 29%] [32mBuilding CXX object kcontrol/bell/CMakeFiles/kcm_bell.dir/kcm_bell_automoc.o
[0m[ 30%] [32mBuilding CXX object kcontrol/bell/CMakeFiles/kcm_bell.dir/bell.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_bell.so
[0m[ 30%] Built target kcm_bell
[35m[1mScanning dependencies of target kapplymousetheme
[0m[ 30%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kapplymousetheme.dir/kapplymousetheme_automoc.o
[0m[ 30%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kapplymousetheme.dir/kapplymousetheme.o
[0m[31m[1mLinking CXX executable kapplymousetheme
[0m[ 30%] Built target kapplymousetheme
[ 30%] [34m[1mGenerating ui_logitechmouse_base.h
[0m[34m[1mGenerating thememodel.moc
[0m[34m[1mGenerating themepage.moc
[0m[34m[1mGenerating mouse.moc
[0m[34m[1mGenerating logitechmouse.moc
[0m[ 30%] [34m[1mGenerating ui_themepage.h
[0m[ 31%] [34m[1mGenerating ui_kmousedlg.h
[0m[35m[1mScanning dependencies of target kcm_input
[0m[ 32%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kcm_input.dir/kcm_input_automoc.o
[0m[ 32%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kcm_input.dir/mouse.o
[0m/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/input/mouse.cpp:722:2: warning: #warning was key == NULL how was this working? is key.isNull() what the coder meant?
[ 33%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kcm_input.dir/main.o
[0m[ 33%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kcm_input.dir/logitechmouse.o
[0m[ 33%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kcm_input.dir/xcursor/themepage.o
[0m[ 34%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kcm_input.dir/xcursor/thememodel.o
[0m[ 34%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kcm_input.dir/xcursor/cursortheme.o
[0m[ 35%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kcm_input.dir/xcursor/legacytheme.o
[0m[ 35%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kcm_input.dir/xcursor/xcursortheme.o
[0m[ 36%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kcm_input.dir/xcursor/previewwidget.o
[0m[ 36%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kcm_input.dir/xcursor/itemdelegate.o
[0m[ 36%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kcm_input.dir/xcursor/sortproxymodel.o
[0m[ 37%] [32mBuilding CXX object kcontrol/input/CMakeFiles/kcm_input.dir/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/krdb/krdb.o
[0m/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/krdb/krdb.cpp: In function 'void applyQtColors(KConfigGroup, QSettings&, QPalette&)':
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/krdb/krdb.cpp:129: warning: 'changeGroup' is deprecated (declared at /usr/kde/4.1/include/kconfiggroup.h:131)
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/krdb/krdb.cpp:165: warning: 'changeGroup' is deprecated (declared at /usr/kde/4.1/include/kconfiggroup.h:131)
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/krdb/krdb.cpp: In function 'void applyQtSettings(KConfigGroup, QSettings&)':
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/krdb/krdb.cpp:260: warning: 'changeGroup' is deprecated (declared at /usr/kde/4.1/include/kconfiggroup.h:131)
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/krdb/krdb.cpp:275: warning: 'changeGroup' is deprecated (declared at /usr/kde/4.1/include/kconfiggroup.h:131)
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/krdb/krdb.cpp: In function 'void runRdb(uint)':
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/krdb/krdb.cpp:514: warning: 'changeGroup' is deprecated (declared at /usr/kde/4.1/include/kconfiggroup.h:131)
[31m[1mLinking CXX shared module ../../lib/kcm_input.so
[0m[ 37%] Built target kcm_input
[ 37%] [34m[1mGenerating ui_bgadvanced_ui.h
[0m[34m[1mGenerating kdm-gen.moc
[0m[34m[1mGenerating bgdialog.moc
[0m[34m[1mGenerating kdm-theme.moc
[0m[34m[1mGenerating kdm-shut.moc
[0m[34m[1mGenerating kdm-users.moc
[0m[34m[1mGenerating kdm-dlg.moc
[0m[34m[1mGenerating main.moc
[0m[34m[1mGenerating bgrender.moc
[0m[34m[1mGenerating kdm-conv.moc
[0m[34m[1mGenerating positioner.moc
[0m[34m[1mGenerating background.moc
[0m[34m[1mGenerating bgadvanced.moc
[0m[34m[1mGenerating bgmonitor.moc
[0m[34m[1mGenerating bgwallpaper.moc
[0m[ 38%] [34m[1mGenerating ui_bgwallpaper_ui.h
[0m[ 38%] [34m[1mGenerating ui_bgdialog_ui.h
[0m[35m[1mScanning dependencies of target kcm_kdm
[0m[ 38%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/kcm_kdm_automoc.o
[0m[ 39%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/background/bgdialog.o
[0m[ 39%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/background/bgadvanced.o
[0m[ 40%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/background/bgmonitor.o
[0m[ 40%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/background/bgwallpaper.o
[0m[ 41%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/background/bgrender.o
[0m[ 41%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/background/bgsettings.o
[0m[ 41%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/background.o
[0m[ 42%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/kdm-gen.o
[0m[ 42%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/kdm-dlg.o
[0m[ 43%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/kdm-theme.o
[0m[ 43%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/kdm-shut.o
[0m[ 43%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/kdm-users.o
[0m[ 44%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/kdm-conv.o
[0m[ 44%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/main.o
[0m[ 45%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/kbackedcombobox.o
[0m[ 45%] [32mBuilding CXX object kcontrol/kdm/CMakeFiles/kcm_kdm.dir/positioner.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_kdm.so
[0m[ 45%] Built target kcm_kdm
[ 45%] [34m[1mGenerating krunner_interface.cpp, krunner_interface.h
[0m[34m[1mGenerating kcmlaunch.moc
[0m[ 45%] [34m[1mGenerating krunner_interface.moc
[0m[35m[1mScanning dependencies of target kcm_launch
[0m[ 46%] [32mBuilding CXX object kcontrol/launch/CMakeFiles/kcm_launch.dir/kcm_launch_automoc.o
[0m[ 46%] [32mBuilding CXX object kcontrol/launch/CMakeFiles/kcm_launch.dir/kcmlaunch.o
[0m[ 47%] [32mBuilding CXX object kcontrol/launch/CMakeFiles/kcm_launch.dir/krunner_interface.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_launch.so
[0m[ 47%] Built target kcm_launch
[34m[1mGenerating tzone.moc
[0m[34m[1mGenerating dtime.moc
[0m[35m[1mScanning dependencies of target kcm_clock
[0m[ 48%] [32mBuilding CXX object kcontrol/dateandtime/CMakeFiles/kcm_clock.dir/kcm_clock_automoc.o
[0m[ 48%] [32mBuilding CXX object kcontrol/dateandtime/CMakeFiles/kcm_clock.dir/dtime.o
[0m/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/dateandtime/dtime.cpp:142:2: warning: #warning fixme hour->setValidator(new KStrictIntValidator(0, 23, hour));
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/dateandtime/dtime.cpp:156:4: warning: #warning fixme minute->setValidator(new KStrictIntValidator(0, 59, minute));
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/dateandtime/dtime.cpp:170:4: warning: #warning fixme second->setValidator(new KStrictIntValidator(0, 59, second));
[ 49%] [32mBuilding CXX object kcontrol/dateandtime/CMakeFiles/kcm_clock.dir/tzone.o
[0m[ 49%] [32mBuilding CXX object kcontrol/dateandtime/CMakeFiles/kcm_clock.dir/main.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_clock.so
[0m[ 49%] Built target kcm_clock
[35m[1mScanning dependencies of target kcmdatetimehelper
[0m[ 50%] [32mBuilding CXX object kcontrol/dateandtime/CMakeFiles/kcmdatetimehelper.dir/kcmdatetimehelper_automoc.o
[0m[ 50%] [32mBuilding CXX object kcontrol/dateandtime/CMakeFiles/kcmdatetimehelper.dir/helper.o
[0m[31m[1mLinking CXX executable kcmdatetimehelper
[0m[ 50%] Built target kcmdatetimehelper
[ 50%] [34m[1mGenerating ui_preview.h
[0m[34m[1mGenerating colorscm.moc
[0m[34m[1mGenerating previewwidget.moc
[0m[ 50%] [34m[1mGenerating ui_colorsettings.h
[0m[35m[1mScanning dependencies of target kcm_colors
[0m[ 50%] [32mBuilding CXX object kcontrol/colors/CMakeFiles/kcm_colors.dir/kcm_colors_automoc.o
[0m[ 51%] [32mBuilding CXX object kcontrol/colors/CMakeFiles/kcm_colors.dir/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/krdb/krdb.o
[ 51%] [32mBuilding CXX object kcontrol/colors/CMakeFiles/kcm_colors.dir/colorscm.o
[0m/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1085: warning: unused parameter 'index'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1093: warning: unused parameter 'value'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1101: warning: unused parameter 'index'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1109: warning: unused parameter 'value'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1117: warning: unused parameter 'color'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1125: warning: unused parameter 'index'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1133: warning: unused parameter 'value'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1142: warning: unused parameter 'index'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1150: warning: unused parameter 'value'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1158: warning: unused parameter 'index'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1166: warning: unused parameter 'value'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1174: warning: unused parameter 'color'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1182: warning: unused parameter 'index'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/colors/colorscm.cpp:1190: warning: unused parameter 'value'
[ 52%] [32mBuilding CXX object kcontrol/colors/CMakeFiles/kcm_colors.dir/previewwidget.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_colors.so
[0m[ 52%] Built target kcm_colors
[ 53%] [34m[1mGenerating kscreensaver_interface.cpp, kscreensaver_interface.h
[0m[34m[1mGenerating energy.moc
[0m[ 53%] [34m[1mGenerating kscreensaver_interface.moc
[0m[35m[1mScanning dependencies of target kcm_energy
[0m[ 54%] [32mBuilding CXX object kcontrol/energy/CMakeFiles/kcm_energy.dir/kcm_energy_automoc.o
[0m[ 54%] [32mBuilding CXX object kcontrol/energy/CMakeFiles/kcm_energy.dir/energy.o
[0m/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/energy/energy.cpp: In constructor 'KEnergy::KEnergy(QWidget*, const QVariantList&)':
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/energy/energy.cpp:209: warning: '__comp_ctor ' is deprecated (declared at /usr/kde/4.1/include/knuminput.h:218)
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/energy/energy.cpp:221: warning: '__comp_ctor ' is deprecated (declared at /usr/kde/4.1/include/knuminput.h:218)
[ 55%] [32mBuilding CXX object kcontrol/energy/CMakeFiles/kcm_energy.dir/kscreensaver_interface.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_energy.so
[0m[ 55%] Built target kcm_energy
[34m[1mGenerating fonts.moc
[0m[35m[1mScanning dependencies of target kcm_fonts
[0m[ 55%] [32mBuilding CXX object kcontrol/fonts/CMakeFiles/kcm_fonts.dir/kcm_fonts_automoc.o
[0m[ 55%] [32mBuilding CXX object kcontrol/fonts/CMakeFiles/kcm_fonts.dir/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/krdb/krdb.o
[ 56%] [32mBuilding CXX object kcontrol/fonts/CMakeFiles/kcm_fonts.dir/fonts.o
[0m[ 56%] [32mBuilding CXX object kcontrol/fonts/CMakeFiles/kcm_fonts.dir/kxftconfig.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_fonts.so
[0m[ 56%] Built target kcm_fonts
[ 56%] [34m[1mGenerating ui_stylepreview.h
[0m[34m[1mGenerating kcmstyle.moc
[0m[34m[1mGenerating styleconfdialog.moc
[0m[35m[1mScanning dependencies of target kcm_style
[0m[ 57%] [32mBuilding CXX object kcontrol/style/CMakeFiles/kcm_style.dir/kcm_style_automoc.o
[0m[ 57%] [32mBuilding CXX object kcontrol/style/CMakeFiles/kcm_style.dir/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/krdb/krdb.o
[ 57%] [32mBuilding CXX object kcontrol/style/CMakeFiles/kcm_style.dir/styleconfdialog.o
[0m[ 58%] [32mBuilding CXX object kcontrol/style/CMakeFiles/kcm_style.dir/kcmstyle.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_style.so
[0m[ 58%] Built target kcm_style
[34m[1mGenerating keramikconf.moc
[0m[35m[1mScanning dependencies of target kstyle_keramik_config
[0m[ 59%] [32mBuilding CXX object kcontrol/style/keramik/CMakeFiles/kstyle_keramik_config.dir/kstyle_keramik_config_automoc.o
[0m[ 59%] [32mBuilding CXX object kcontrol/style/keramik/CMakeFiles/kstyle_keramik_config.dir/keramikconf.o
[0m[31m[1mLinking CXX shared module ../../../lib/kstyle_keramik_config.so
[0m[ 59%] Built target kstyle_keramik_config
[ 60%] [34m[1mGenerating ui_advanceddialogimpl.h
[0m[34m[1mGenerating testwin.moc
[0m[34m[1mGenerating scrnsave.moc
[0m[34m[1mGenerating advanceddialog.moc
[0m[34m[1mGenerating kswidget.moc
[0m[ 60%] [34m[1mGenerating kscreensaver_interface.cpp, kscreensaver_interface.h
[0m[ 61%] [34m[1mGenerating kscreensaver_interface.moc
[0m[35m[1mScanning dependencies of target kcm_screensaver
[0m[ 62%] [32mBuilding CXX object kcontrol/screensaver/CMakeFiles/kcm_screensaver.dir/kcm_screensaver_automoc.o
[0m[ 62%] [32mBuilding CXX object kcontrol/screensaver/CMakeFiles/kcm_screensaver.dir/scrnsave.o
[0m[ 62%] [32mBuilding CXX object kcontrol/screensaver/CMakeFiles/kcm_screensaver.dir/testwin.o
[0m[ 63%] [32mBuilding CXX object kcontrol/screensaver/CMakeFiles/kcm_screensaver.dir/saverlist.o
[0m[ 63%] [32mBuilding CXX object kcontrol/screensaver/CMakeFiles/kcm_screensaver.dir/saverconfig.o
[0m[ 64%] [32mBuilding CXX object kcontrol/screensaver/CMakeFiles/kcm_screensaver.dir/advanceddialog.o
[0m[ 64%] [32mBuilding CXX object kcontrol/screensaver/CMakeFiles/kcm_screensaver.dir/kswidget.o
[0m[ 64%] [32mBuilding CXX object kcontrol/screensaver/CMakeFiles/kcm_screensaver.dir/kscreensaver_interface.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_screensaver.so
[0m[ 64%] Built target kcm_screensaver
[ 64%] [34m[1mGenerating ui_select_scheme_dialog.h
[0m[34m[1mGenerating moc_select_scheme_dialog.cpp
[0m[34m[1mGenerating kglobalshortcutseditor.moc
[0m[34m[1mGenerating globalshortcuts.moc
[0m[ 65%] [34m[1mGenerating ui_kglobalshortcutseditor.h
[0m[35m[1mScanning dependencies of target kcm_keys
[0m[ 65%] [32mBuilding CXX object kcontrol/keys/CMakeFiles/kcm_keys.dir/kcm_keys_automoc.o
[0m[ 66%] [32mBuilding CXX object kcontrol/keys/CMakeFiles/kcm_keys.dir/kglobalshortcutseditor.o
[0m[ 66%] [32mBuilding CXX object kcontrol/keys/CMakeFiles/kcm_keys.dir/globalshortcuts.o
[0m[ 66%] [32mBuilding CXX object kcontrol/keys/CMakeFiles/kcm_keys.dir/select_scheme_dialog.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_keys.so
[0m[ 66%] Built target kcm_keys
[ 66%] [34m[1mGenerating ui_xineramawidget.h
[0m[34m[1mGenerating kcmxinerama.moc
[0m[34m[1mGenerating xineramawidget.moc
[0m[ 67%] [34m[1mGenerating kwin_interface.cpp, kwin_interface.h
[0m[ 67%] [34m[1mGenerating kwin_interface.moc
[0m[35m[1mScanning dependencies of target kcm_xinerama
[0m[ 68%] [32mBuilding CXX object kcontrol/xinerama/CMakeFiles/kcm_xinerama.dir/kcm_xinerama_automoc.o
[0m[ 68%] [32mBuilding CXX object kcontrol/xinerama/CMakeFiles/kcm_xinerama.dir/kcmxinerama.o
[0m[ 68%] [32mBuilding CXX object kcontrol/xinerama/CMakeFiles/kcm_xinerama.dir/xineramawidget.o
[0m[ 69%] [32mBuilding CXX object kcontrol/xinerama/CMakeFiles/kcm_xinerama.dir/kwin_interface.o
[0m[31m[1mLinking CXX shared module ../../lib/kcm_xinerama.so
[0m[ 69%] Built target kcm_xinerama
[35m[1mScanning dependencies of target test_kcm_xinerama
[0m[ 70%] [32mBuilding CXX object kcontrol/xinerama/CMakeFiles/test_kcm_xinerama.dir/test_kcm_xinerama.o
[0m[ 70%] [32mBuilding CXX object kcontrol/xinerama/CMakeFiles/test_kcm_xinerama.dir/kwin_interface.o
[0m[31m[1mLinking CXX executable test_kcm_xinerama
[0m[ 71%] Built target test_kcm_xinerama
[34m[1mGenerating display.moc
[0m[35m[1mScanning dependencies of target kcm_display
[0m[ 71%] [32mBuilding CXX object kcontrol/hardware/display/CMakeFiles/kcm_display.dir/kcm_display_automoc.o
[0m[ 72%] [32mBuilding CXX object kcontrol/hardware/display/CMakeFiles/kcm_display.dir/display.o
[0m[31m[1mLinking CXX shared module ../../../lib/kcm_display.so
[0m[ 72%] Built target kcm_display
[34m[1mGenerating poswidget.moc
[0m[34m[1mGenerating joystick.moc
[0m[34m[1mGenerating joywidget.moc
[0m[34m[1mGenerating caldialog.moc
[0m[35m[1mScanning dependencies of target kcm_joystick
[0m[ 72%] [32mBuilding CXX object kcontrol/hardware/joystick/CMakeFiles/kcm_joystick.dir/kcm_joystick_automoc.o
[0m[ 72%] [32mBuilding CXX object kcontrol/hardware/joystick/CMakeFiles/kcm_joystick.dir/joystick.o
[0m[ 73%] [32mBuilding CXX object kcontrol/hardware/joystick/CMakeFiles/kcm_joystick.dir/joywidget.o
[0m[ 73%] [32mBuilding CXX object kcontrol/hardware/joystick/CMakeFiles/kcm_joystick.dir/poswidget.o
[0m[ 74%] [32mBuilding CXX object kcontrol/hardware/joystick/CMakeFiles/kcm_joystick.dir/joydevice.o
[0m[ 74%] [32mBuilding CXX object kcontrol/hardware/joystick/CMakeFiles/kcm_joystick.dir/caldialog.o
[0m[31m[1mLinking CXX shared module ../../../lib/kcm_joystick.so
[0m[ 74%] Built target kcm_joystick
[34m[1mGenerating kaccess.moc
[0m[35m[1mScanning dependencies of target kdeinit_kaccess
[0m[ 75%] [32mBuilding CXX object kcontrol/access/CMakeFiles/kdeinit_kaccess.dir/kdeinit_kaccess_automoc.o
[0m[ 75%] [32mBuilding CXX object kcontrol/access/CMakeFiles/kdeinit_kaccess.dir/kaccess.o
[0mIn file included from /var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings_build/kcontrol/access/kaccess.moc:10,
from /var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/access/kaccess.cpp:33:
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings_build/kcontrol/access/../../../systemsettings-4.1.0/kcontrol/access/kaccess.h:15:30: error: Phonon/MediaObject: No such file or directory
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/access/kaccess.cpp:441:2: warning: #warning is this the best way to invert a pixmap?
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/access/kaccess.cpp:590:2: warning: #warning "kde4 fixme"
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings_build/kcontrol/access/../../../systemsettings-4.1.0/kcontrol/access/kaccess.h:76: error: 'Phonon' has not been declared
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings_build/kcontrol/access/../../../systemsettings-4.1.0/kcontrol/access/kaccess.h:76: error: ISO C++ forbids declaration of 'MediaObject' with no type
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings_build/kcontrol/access/../../../systemsettings-4.1.0/kcontrol/access/kaccess.h:76: error: expected ';' before '*' token
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/access/kaccess.cpp: In constructor 'KAccessApp::KAccessApp(bool, bool)':
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/access/kaccess.cpp:100: error: class 'KAccessApp' does not have any field named '_player'
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/access/kaccess.cpp: In member function 'void KAccessApp::xkbBellNotify(XkbBellNotifyEvent*)':
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/access/kaccess.cpp:471: error: '_player' was not declared in this scope
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/access/kaccess.cpp:472: error: 'Phonon' has not been declared
/var/tmp/portage/kde-base/systemsettings-4.1.0/work/systemsettings-4.1.0/kcontrol/access/kaccess.cpp:476: error: '_player' was not declared in this scope
make[2]: *** [kcontrol/access/CMakeFiles/kdeinit_kaccess.dir/kaccess.o] Error 1
make[1]: *** [kcontrol/access/CMakeFiles/kdeinit_kaccess.dir/all] Error 2
make: *** [all] Error 2
[31;01m*[0m
[31;01m*[0m ERROR: kde-base/systemsettings-4.1.0 failed.
[31;01m*[0m Call stack:
[31;01m*[0m ebuild.sh, line 49: Called src_compile
[31;01m*[0m environment, line 2973: Called kde4overlay-meta_src_compile
[31;01m*[0m environment, line 2321: Called kde4overlay-meta_src_make
[31;01m*[0m environment, line 2370: Called kde4overlay-base_src_make
[31;01m*[0m environment, line 2081: Called cmake-utils_src_make
[31;01m*[0m environment, line 733: Called die
[31;01m*[0m The specific snippet of code:
[31;01m*[0m emake "$@" || die "Make failed!";
[31;01m*[0m The die message:
[31;01m*[0m Make failed!
[31;01m*[0m
[31;01m*[0m If you need support, post the topmost build error, and the call stack if relevant.
[31;01m*[0m A complete build log is located at '/var/tmp/portage/kde-base/systemsettings-4.1.0/temp/build.log'.
[31;01m*[0m The ebuild environment file is located at '/var/tmp/portage/kde-base/systemsettings-4.1.0/temp/environment'.
[31;01m*[0m This ebuild used the following eclasses from overlays:
[31;01m*[0m /usr/local/portage/layman/kdesvn-portage/eclass/kde4overlay-meta.eclass
[31;01m*[0m /usr/local/portage/layman/kdesvn-portage/eclass/kde4overlay-functions.eclass
[31;01m*[0m /usr/local/portage/layman/kdesvn-portage/eclass/kde4overlay-base.eclass
[31;01m*[0m This ebuild is from an overlay: '/usr/local/portage/layman/kdesvn-portage/'
[31;01m*[0m
