asound.conf Probleme nach Update auf Suse 10.2
K
Kenji
Hi
Ich hab da leichte Troubles mit der asound.conf.
Ich habe ein Gateway von Knoppix auf Suse upgedatet und seit dem läuft die asound.conf nicht mehr richtig
ALSA lib pcm_direct.c:1379: (snd_pcm_direct_parse_bindings) invalid slave channel number 2 in binding to 0
aplay: main:545: audio open error: Invalid argument
Knoppix Original config:
pcm.ice1712 {
type hw
card 0
ctl.ice1712 {
type hw
card 0
pcm.via82xx {
type hw
card 1
ctl.via82xx {
type hw
card 1
# pcm.!default {
# type plug
# slave.pcm "duplex02"
pcm.intmix {
type dmix
ipc_key 1024
#slave.pcm "snd_card"
slave {
pcm "hw:1,0"
#period_time 0
period_size 64
buffer_size 1024
#channels 1
#rate 16000
bindings {
0 0
1 1
pcm.ossmix01 {
type dmix
ipc_key 1024
slave {
pcm "hw:0,0"
#period_time 0
period_size 64
buffer_size 1024
channels 1
rate 8000
bindings {
0 0
1 1
pcm.ossmix02 {
type dmix
ipc_key 1024
slave {
pcm "hw:0,0"
period_size 64
buffer_size 1024
channels 1
rate 8000
bindings {
0 2
1 3
pcm.ossmix03 {
type dmix
ipc_key 1024
slave {
pcm "hw:0,0"
period_size 64
buffer_size 1024
channels 1
rate 8000
bindings {
0 4
1 5
pcm.ossmix04 {
type dmix
ipc_key 1024
slave {
pcm "hw:0,0"
rate 8000
period_size 64
buffer_size 1024
channels 1
bindings {
0 6
1 7
# Allow reading from the default device.
# Also known as record or capture.
pcm.input01 {
type dsnoop
ipc_key 2048
slave {
pcm "hw:0,0"
period_size 64
buffer_size 1024
rate 8000
bindings {
0 0
1 1
pcm.input02 {
type dsnoop
ipc_key 2048
slave {
pcm "hw:0,0"
period_size 64
buffer_size 1024
rate 8000
bindings {
0 2
1 3
pcm.input03 {
type dsnoop
ipc_key 2048
slave {
pcm "hw:0,0"
period_size 64
buffer_size 1024
rate 8000
bindings {
0 4
1 5
pcm.input04 {
type dsnoop
ipc_key 2048
slave {
pcm "hw:0,0"
period_size 64
buffer_size 1024
rate 8000
bindings {
0 6
1 7
pcm.duplex01{
type asym
playback.pcm "ossmix01"
capture.pcm "input01"
pcm.duplex02{
type asym
playback.pcm "ossmix02"
capture.pcm "input02"
pcm.duplex03{
type asym
playback.pcm "ossmix03"
capture.pcm "input03"
pcm.duplex04{
type asym
playback.pcm "ossmix04"
capture.pcm "input04"
Suse test config laut wiki:
Bei der kommt einfach nur ein Ton...
pcm.ice1712 {
type hw
card 0
ctl.ice1712 {
type hw
card 0
#disable dmix
#pcm.!default {
#type plug
#slave.pcm hw
#tut
pcm.demo {
type asym
playback.pcm {
type plug
slave.pcm {
@func concat
strings [ "dmix:0,FORMAT=S32_LE" ] #card number 0
ttable.0.0 1
ttable.1.1 1
ttable.0.2 1
ttable.1.3 1
ttable.0.4 0.5
ttable.1.4 0.5
ttable.0.5 0.5
ttable.1.5 0.5
capture.pcm {
type plug
slave.pcm {
@func concat
strings [ "dsnoop:0,FORMAT=S32_LE" ]#card number 0
pcm.duplex01 {
type asym
playback.pcm {
type plug
slave.pcm {
@func concat
ttable.0.0 1
ttable.1.1 1
capture.pcm {
type plug
slave.pcm {
@func concat
ttable.0.0 1
ttable.1.1 1
pcm.duplex02 {
type asym
playback.pcm {
type plug
slave.pcm {
@func concat
ttable.0.2 1
ttable.1.3 1
capture.pcm {
type plug
slave.pcm {
@func concat
ttable.0.2 1
ttable.1.3 1
pcm.duplex03 {
type asym
playback.pcm {
type plug
slave.pcm {
@func concat
ttable.0.4 1
ttable.1.5 1
capture.pcm {
type plug
slave.pcm {
@func concat
ttable.0.4 1
ttable.1.5 1
pcm.duplex04 {
type asym
playback.pcm {
type plug
slave.pcm {
@func concat
ttable.0.6 1
ttable.1.7 1
capture.pcm {
type plug
slave.pcm {
@func concat
ttable.0.6 1
ttable.1.7 1
pcm.ossmix04 {
type dmix
ipc_key 1024
slave {
pcm "hw:0,0"
rate 8000
period_size 64
buffer_size 1024
channels 1
bindings {
0 6
1 7
pcm.input01 {
type dsnoop
ipc_key 2048
slave {
pcm "hw:0,0"
period_size 64
buffer_size 1024
rate 48000
bindings {
0 0
1 1
Kenji
Kleines Update: plug:duplex01 funkt,
beim 02, 03 und 04 bekomm ich noch immer die Fehlermeldung das die Bindings nicht stimmen.
Neue Config:
pcm.ice1712 {
type hw
card 0
ctl.ice1712 {
type hw
card 0
pcm.via82xx {
type hw
card 1
ctl.via82xx {
type hw
card 1
# pcm.!default {
# type plug
pcm.intmix {
type dmix
ipc_key 1024
slave {
pcm "hw:1,0"
#period_time 0
period_size 64
buffer_size 1024
#channels 1
#rate 16000
bindings {
0 0
1 1
pcm.ossmix01 {
type dmix
ipc_key 1024
slave {
pcm "hw:0,0"
#period_time 0
period_size 64
buffer_size 1024
#channels 1
#rate 8000
bindings {
0 0
1 1
pcm.ossmix02 {
type dmix
ipc_key 1024
slave {
pcm "hw:0,0"
period_size 64
buffer_size 1024
#channels 1
#rate 8000
bindings {
0 2
1 3
pcm.ossmix03 {
type dmix
ipc_key 1024
# slave.pcm "snd_card"
slave {
pcm "hw:0,0"
period_size 64
buffer_size 1024
# channels 1
# rate 8000
bindings {
0 4
1 5
pcm.ossmix04 {
type dmix
ipc_key 1024
slave {
pcm "hw:0,0"
# rate 8000
period_size 64
buffer_size 1024
# channels 1
bindings {
0 6
1 7
pcm.input01 {
type dsnoop
ipc_key 2048
slave {
pcm "hw:0,0"
period_size 64
buffer_size 1024
rate 8000
bindings {
0 0
1 1
pcm.input02 {
type dsnoop
ipc_key 2048
slave {
pcm "hw:0,0"
period_size 64
buffer_size 1024
rate 8000
bindings {
0 2
1 3
pcm.input03 {
type dsnoop
ipc_key 2048
slave {
pcm "hw:0,0"
period_size 64
buffer_size 1024
rate 8000
bindings {
0 4
1 5
pcm.input04 {
type dsnoop
ipc_key 2048
slave {
pcm "hw:0,0"
period_size 64
buffer_size 1024
rate 8000
bindings {
0 6
1 7
pcm.duplex01{
type asym
pcm.duplex02{
type asym
pcm.duplex03{
type asym
pcm.duplex04{
type asym
So das Problem ist eindeutig, die bindings beim ossmix ;(
bei
0 0
1 1
Funktioniert alles beim Rest kommt immer die Fehlermeldung...
Irgendwelche Ideen dazu?
Pulseaudio unter Debian multiple Output
.asoundrc für USB-Soundkarte konfigurieren
