compilierungs probleme
Schlubber
Schlubber
Aurox ,Win XP User
Hi!
Hab ein paar probleme beim Kompilieren unter Ubuntu.
Hab Ubuntu erst gestern installiert weil Mandriva immer Kernel panic bekam.
Immer wenn ich ./configure ausführe(egal welches programm ich versuche zu kompilieren)bekomme gibt er mir dies aus
schlubber@ubuntu:~/kbilliards-0.8.6$ ./configure
checking build system type... i686-pc-linux-gnulibc1
checking host system type... i686-pc-linux-gnulibc1
checking target system type... i686-pc-linux-gnulibc1
checking for a BSD-compatible install... /usr/bin/install -c
checking for -p flag to install... yes
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... configure: error: C compiler cannot create executables
See `config.log' for more details.
also hab ich in die config.log datei gesehen.
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.59.  Invocation command line was
  $ ./configure
## Platform. ##
hostname = ubuntu
uname -m = i686
uname -r = 2.6.12-10-386
uname -s = Linux
uname -v = #1 Thu Dec 22 11:37:10 UTC 2005
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = i686
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
hostinfo               = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /usr/local/bin
PATH: /usr/local/sbin
PATH: /sbin
PATH: /usr/sbin
PATH: /bin
PATH: /usr/bin
PATH: /usr/bin/X11
PATH: /usr/games
## Core tests. ##
configure:1561: checking build system type
configure:1579: result: i686-pc-linux-gnulibc1
configure:1587: checking host system type
configure:1601: result: i686-pc-linux-gnulibc1
configure:1609: checking target system type
configure:1623: result: i686-pc-linux-gnulibc1
configure:1670: checking for a BSD-compatible install
configure:1725: result: /usr/bin/install -c
configure:1740: checking for -p flag to install
configure:1753: result: yes
configure:1764: checking whether build environment is sane
configure:1807: result: yes
configure:1859: checking for gawk
configure:1888: result: no
configure:1859: checking for mawk
configure:1875: found /usr/bin/mawk
configure:1885: result: mawk
configure:1895: checking whether make sets $(MAKE)
configure:1915: result: yes
configure:2132: checking for style of include used by make
configure:2160: result: GNU
configure:2307: checking for gcc
configure:2323: found /usr/bin/gcc
configure:2333: result: gcc
configure:2577: checking for C compiler version
configure:2580: gcc --version </dev/null >&5
gcc (GCC) 4.0.2 20050808 (prerelease) (Ubuntu 4.0.1-4ubuntu9)
Copyright (C) 2005 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
configure:2583: $? = 0
configure:2585: gcc -v </dev/null >&5
Using built-in specs.
Target: i486-linux-gnu
Configured with: ../src/configure -v --enable-languages=c,c++,java,f95,objc,ada,treelang --prefix=/usr --with-gxx-include-dir=/usr/include/c++/4.0.2 --enable-shared --with-system-zlib --libexecdir=/usr/lib --enable-nls --without-included-gettext --enable-threads=posix --program-suffix=-4.0 --enable-__cxa_atexit --enable-libstdcxx-allocator=mt --enable-clocale=gnu --enable-libstdcxx-debug --enable-java-gc=boehm --enable-java-awt=gtk --enable-gtk-cairo --with-java-home=/usr/lib/jvm/java-1.4.2-gcj-4.0-1.4.2.0/jre --enable-mpfr --disable-werror --enable-checking=release i486-linux-gnu
Thread model: posix
gcc version 4.0.2 20050808 (prerelease) (Ubuntu 4.0.1-4ubuntu9)
configure:2588: $? = 0
configure:2590: gcc -V </dev/null >&5
gcc: '-V' option must have argument
configure:2593: $? = 1
configure:2616: checking for C compiler default output file name
configure:2619: gcc     conftest.c  >&5
/usr/bin/ld: crt1.o: No such file: No such file or directory
collect2: ld returned 1 exit status
configure:2622: $? = 1
configure: failed program was:
| /* confdefs.h.  */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE "kbilliards"
| #define VERSION "0.8.6"
| /* end confdefs.h.  */
| int
| main ()
|   return 0;
configure:2661: error: C compiler cannot create executables
## Cache variables. ##
ac_cv_build=i686-pc-linux-gnulibc1
ac_cv_build_alias=i686-pc-linux-gnulibc1
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_F77_set=
ac_cv_env_F77_value=
ac_cv_env_FFLAGS_set=
ac_cv_env_FFLAGS_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_host=i686-pc-linux-gnulibc1
ac_cv_host_alias=i686-pc-linux-gnulibc1
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_AWK=mawk
ac_cv_prog_ac_ct_CC=gcc
ac_cv_prog_make_make_set=yes
ac_cv_target=i686-pc-linux-gnulibc1
ac_cv_target_alias=i686-pc-linux-gnulibc1
## Output variables. ##
ACLOCAL='${SHELL} /home/schlubber/kbilliards-0.8.6/admin/missing --run aclocal-1.9'
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='${SHELL} /home/schlubber/kbilliards-0.8.6/admin/missing --run tar'
AR=''
ARTSCCONFIG=''
AUTOCONF='${SHELL} /home/schlubber/kbilliards-0.8.6/admin/missing --run autoconf'
AUTODIRS=''
AUTOHEADER='${SHELL} /home/schlubber/kbilliards-0.8.6/admin/missing --run autoheader'
AUTOMAKE='${SHELL} /home/schlubber/kbilliards-0.8.6/admin/missing --run automake-1.9'
AWK='mawk'
CC='gcc'
CCDEPMODE=''
CFLAGS=' '
CONF_FILES=' $(top_srcdir)/./admin/configure.in.min $(top_srcdir)/configure.in.in'
CPP=''
CPPFLAGS=''
CXX=''
CXXCPP=''
CXXDEPMODE=''
CXXFLAGS=''
CYGPATH_W='echo'
DCOPIDL2CPP=''
DCOPIDL=''
DCOPIDLNG=''
DCOP_DEPENDENCIES=''
DEFS=''
DEPDIR='.deps'
ECHO='echo'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
EXEEXT=''
F77=''
FFLAGS=''
FRAMEWORK_COREAUDIO=''
GMSGFMT=''
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL} $(INSTALL_STRIP_FLAG)'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s'
KCFG_DEPENDENCIES=''
KCONFIG_COMPILER=''
KDECONFIG=''
KDE_EXTRA_RPATH=''
KDE_INCLUDES=''
KDE_LDFLAGS=''
KDE_MT_LDFLAGS=''
KDE_MT_LIBS=''
KDE_NO_UNDEFINED=''
KDE_PLUGIN=''
KDE_RPATH=''
KDE_USE_CLOSURE_FALSE=''
KDE_USE_CLOSURE_TRUE=''
KDE_USE_FINAL_FALSE=''
KDE_USE_FINAL_TRUE=''
KDE_USE_NMCHECK_FALSE=''
KDE_USE_NMCHECK_TRUE=''
KDE_XSL_STYLESHEET=''
LDFLAGS=''
LIBCOMPAT=''
LIBCRYPT=''
LIBDL=''
LIBJPEG=''
LIBOBJS=''
LIBPNG=''
LIBPTHREAD=''
LIBRESOLV=''
LIBS=''
LIBSM=''
LIBSOCKET=''
LIBTOOL=''
LIBUCB=''
LIBUTIL=''
LIBZ=''
LIB_KAB=''
LIB_KABC=''
LIB_KDECORE=''
LIB_KDEPIM=''
LIB_KDEPRINT=''
LIB_KDEUI=''
LIB_KFILE=''
LIB_KFM=''
LIB_KHTML=''
LIB_KIO=''
LIB_KPARTS=''
LIB_KSPELL=''
LIB_KSYCOCA=''
LIB_KUTILS=''
LIB_POLL=''
LIB_QPE=''
LIB_QT=''
LIB_SMB=''
LIB_X11=''
LIB_XEXT=''
LIB_XRENDER=''
LN_S=''
LTLIBOBJS=''
MAKEINFO='${SHELL} /home/schlubber/kbilliards-0.8.6/admin/missing --run makeinfo'
MCOPIDL=''
MEINPROC=''
MOC=''
MSGFMT=''
NOOPT_CFLAGS=''
NOOPT_CXXFLAGS=''
OBJEXT=''
PACKAGE='kbilliards'
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PATH_SEPARATOR=':'
PERL=''
QTE_NORTTI=''
QT_INCLUDES=''
QT_LDFLAGS=''
RANLIB=''
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
TOPSUBDIRS=''
UIC=''
UIC_TR=''
USER_INCLUDES=''
USER_LDFLAGS=''
USE_EXCEPTIONS=''
USE_RTTI=''
USE_THREADS=''
VERSION='0.8.6'
WOVERLOADED_VIRTUAL=''
XGETTEXT=''
XMLLINT=''
X_EXTRA_LIBS=''
X_INCLUDES=''
X_LDFLAGS=''
X_PRE_LIBS=''
X_RPATH=''
ac_ct_AR=''
ac_ct_CC='gcc'
ac_ct_CXX=''
ac_ct_F77=''
ac_ct_RANLIB=''
ac_ct_STRIP=''
all_includes=''
all_libraries=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE=''
am__fastdepCXX_TRUE=''
am__include='include'
am__leading_dot='.'
am__quote=''
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
bindir='${exec_prefix}/bin'
build='i686-pc-linux-gnulibc1'
build_alias=''
build_cpu='i686'
build_os='linux-gnulibc1'
build_vendor='pc'
datadir='${prefix}/share'
exec_prefix='NONE'
host='i686-pc-linux-gnulibc1'
host_alias=''
host_cpu='i686'
host_os='linux-gnulibc1'
host_vendor='pc'
include_ARTS_FALSE=''
include_ARTS_TRUE=''
includedir='${prefix}/include'
infodir='${prefix}/info'
install_sh='/home/schlubber/kbilliards-0.8.6/admin/install-sh'
kde_appsdir=''
kde_bindir=''
kde_confdir=''
kde_datadir=''
kde_htmldir=''
kde_icondir=''
kde_includes=''
kde_kcfgdir=''
kde_libraries=''
kde_libs_htmldir=''
kde_libs_prefix=''
kde_locale=''
kde_mimedir=''
kde_moduledir=''
kde_qtver=''
kde_servicesdir=''
kde_servicetypesdir=''
kde_sounddir=''
kde_styledir=''
kde_templatesdir=''
kde_wallpaperdir=''
kde_widgetdir=''
kdeinitdir=''
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localstatedir='${prefix}/var'
mandir='${prefix}/man'
mkdir_p='mkdir -p --'
oldincludedir='/usr/include'
prefix='/usr/local/kde'
program_transform_name='s,x,x,'
qt_includes=''
qt_libraries=''
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target='i686-pc-linux-gnulibc1'
target_alias=''
target_cpu='i686'
target_os='linux-gnulibc1'
target_vendor='pc'
x_includes='NONE'
x_libraries='NONE'
xdg_appsdir=''
xdg_directorydir=''
xdg_menudir=''
## confdefs.h. ##
configure: exit 77
ich glaube es liegt daran (steht auch in der config.log)
dann hab ich nachgeschaut
schlubber@ubuntu:~/kbilliards-0.8.6$ which /usr/bin/ld
/usr/bin/ld
aber die datei ist schon da :( ?
Danke schon mal
Ihm fehlt auch nicht die Datei /usr/bin/ld sondern crt1.o. Die Meldung vom configure sieht mir allerdings eher danach aus, dass der Kompiler nicht richtig installiert ist.
apt-get install libc6-dev
Das sollte helfen ...
So bin jetzt schon bis zum make gekommen :) doch nächstes problem
schlubber@ubuntu:~/kbilliards-0.8.6$ make cd . && make -f admin/Makefile.common configure.in ; make all-recursive make[1]: Gehe in Verzeichnis »/home/schlubber/kbilliards-0.8.6« cd . && make -f admin/Makefile.common configure.in ; Making all in doc make[2]: Gehe in Verzeichnis »/home/schlubber/kbilliards-0.8.6/doc« make[3]: Gehe in Verzeichnis »/home/schlubber/kbilliards-0.8.6/doc« make[3]: Für das Ziel »all-am« ist nichts zu tun. make[3]: Verlasse Verzeichnis »/home/schlubber/kbilliards-0.8.6/doc« make[2]: Verlasse Verzeichnis »/home/schlubber/kbilliards-0.8.6/doc« Making all in media make[2]: Gehe in Verzeichnis »/home/schlubber/kbilliards-0.8.6/media« Making all in sound make[3]: Gehe in Verzeichnis »/home/schlubber/kbilliards-0.8.6/media/sound« make[3]: Für das Ziel »all« ist nichts zu tun. make[3]: Verlasse Verzeichnis »/home/schlubber/kbilliards-0.8.6/media/sound« Making all in balls make[3]: Gehe in Verzeichnis »/home/schlubber/kbilliards-0.8.6/media/balls« make[3]: Für das Ziel »all« ist nichts zu tun. make[3]: Verlasse Verzeichnis »/home/schlubber/kbilliards-0.8.6/media/balls« Making all in other make[3]: Gehe in Verzeichnis »/home/schlubber/kbilliards-0.8.6/media/other« make[3]: Für das Ziel »all« ist nichts zu tun. make[3]: Verlasse Verzeichnis »/home/schlubber/kbilliards-0.8.6/media/other« Making all in maps make[3]: Gehe in Verzeichnis »/home/schlubber/kbilliards-0.8.6/media/maps« make[3]: Für das Ziel »all« ist nichts zu tun. make[3]: Verlasse Verzeichnis »/home/schlubber/kbilliards-0.8.6/media/maps« make[3]: Gehe in Verzeichnis »/home/schlubber/kbilliards-0.8.6/media« make[3]: Für das Ziel »all-am« ist nichts zu tun. make[3]: Verlasse Verzeichnis »/home/schlubber/kbilliards-0.8.6/media« make[2]: Verlasse Verzeichnis »/home/schlubber/kbilliards-0.8.6/media« Making all in po make[2]: Gehe in Verzeichnis »/home/schlubber/kbilliards-0.8.6/po« make[2]: Für das Ziel »all« ist nichts zu tun. make[2]: Verlasse Verzeichnis »/home/schlubber/kbilliards-0.8.6/po« Making all in src make[2]: Gehe in Verzeichnis »/home/schlubber/kbilliards-0.8.6/src« if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include/kde -I/usr/share/qt3/include -I. -DQT_THREAD_SUPPORT -D_REENTRANT -Wnon-virtual-dtor -Wno-long-long -Wundef -Wall -W -Wpointer-arith -Wwrite-strings -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -MT main.o -MD -MP -MF ".deps/main.Tpo" -c -o main.o main.cpp; \ then mv -f ".deps/main.Tpo" ".deps/main.Po"; else rm -f ".deps/main.Tpo"; exit 1; fi In Datei, eingefügt von main.cpp:22: kbilliards.h:31:19: Fehler: qlist.h: Datei oder Verzeichnis nicht gefunden /usr/include/kde/arts/notification.h:54: Warnung: »class Arts::NotificationClient« hat virtuelle Funktionen aber nicht-virtuellen Destruktor /usr/include/kde/arts/iomanager.h:93: Warnung: »class Arts::IONotify« hat virtuelle Funktionen aber nicht-virtuellen Destruktor /usr/include/kde/arts/iomanager.h:112: Warnung: »class Arts::TimeNotify« hat virtuelle Funktionen aber nicht-virtuellen Destruktor /usr/include/kde/arts/startupmanager.h:42: Warnung: »class Arts::StartupClass« hat virtuelle Funktionen aber nicht-virtuellen Destruktor /usr/include/kde/arts/factory.h:45: Warnung: »class Arts::Factory« hat virtuelle Funktionen aber nicht-virtuellen Destruktor /usr/include/kde/arts/idlfilereg.h:41: Warnung: »class Arts::IDLFileReg« hat virtuelle Funktionen aber nicht-virtuellen Destruktor /usr/include/kde/arts/datapacket.h:43: Warnung: »class Arts::GenericDataChannel« hat virtuelle Funktionen aber nicht-virtuellen Destruktor /usr/include/kde/arts/asyncstream.h:44: Warnung: »class Arts::GenericAsyncStream« hat virtuelle Funktionen aber nicht-virtuellen Destruktor /usr/include/kde/arts/asyncstream.h: In instantiation of »Arts::AsyncStream<float>«: /usr/include/kde/arts/asyncstream.h:87: instantiated from here /usr/include/kde/arts/asyncstream.h:63: Warnung: »class Arts::AsyncStream<float>« hat virtuelle Funktionen aber nicht-virtuellen Destruktor /usr/include/kde/arts/asyncstream.h:88: Warnung: »class Arts::FloatAsyncStream« hat virtuelle Funktionen aber nicht-virtuellen Destruktor /usr/include/kde/arts/asyncstream.h: In instantiation of »Arts::AsyncStream<Arts::mcopbyte>«: /usr/include/kde/arts/asyncstream.h:94: instantiated from here /usr/include/kde/arts/asyncstream.h:63: Warnung: »class Arts::AsyncStream<Arts::mcopbyte>« hat virtuelle Funktionen aber nicht-virtuellen Destruktor /usr/include/kde/arts/asyncstream.h:95: Warnung: »class Arts::ByteAsyncStream« hat virtuelle Funktionen aber nicht-virtuellen Destruktor main.cpp:50: schwerwiegender Fehler: Abhängigkeitsdatei ».deps/main.Tpo« wird geöffnet: Keine Berechtigung Kompilierung beendet. make[2]: *** [main.o] Fehler 1 make[2]: Verlasse Verzeichnis »/home/schlubber/kbilliards-0.8.6/src« make[1]: *** [all-recursive] Fehler 1 make[1]: Verlasse Verzeichnis »/home/schlubber/kbilliards-0.8.6« make: *** [all] Fehler 2 schlubber@ubuntu:~/kbilliards-0.8.6$
vl versteht einer von euch den sinn ? so hab jetzt auch noch ein zweites problem! hab ein einfach C++ programm geschrieben aber beim compilieren gibt er mir eine fehler meldung aus. das wäre der code
#include <iostream> using namespace std; int main () { double wert=0.0; cout << "\n Bitte eine Zahl eingeben: "; cin >> wert; if(wert == 10.0) { cout << "Der Wert ist zehn."; } else { if(wert > 10.0) { cout << "Der Wet ist groesser als zehn."; } else { cout << "Der Wert ist kleiner als zehn."; } } return 0; }
und die fehler meldung
schlubber@ubuntu:~/programme/c++$ gcc -o bspl017 bspl0017.cpp /tmp/cclDEYNT.o: In function `main': bspl0017.cpp:(.text+0x35): undefined reference to `std::cout' bspl0017.cpp:(.text+0x 3a): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)' bspl0017.cpp:(.text+0x49): undefined reference to `std::cin' bspl0017.cpp:(.text+0x4e): undefined reference to `std::basic_istream<char, std::char_traits<char> >::operator>>(double&)' bspl0017.cpp:(.text+0x77): undefined reference to `std::cout' bspl0017.cpp:(.text+0x7c): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)' bspl0017.cpp:(.text+0xa4): undefined reference to `std::cout' bspl0017.cpp:(.text+0xa9): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)' bspl0017.cpp:(.text+0xbb): undefined reference to `std::cout' bspl0017.cpp:(.text+0xc0): undefined reference to `std::basic_ostream<char, std::char_traits<char> >& std::operator<< <std::char_traits<char> >(std::basic_ostream<char, std::char_traits<char> >&, char const*)' /tmp/cclDEYNT.o: In function `__tcf_0': bspl0017.cpp:(.text+0xdd): undefined reference to `std::ios_base::Init::~Init()' /tmp/cclDEYNT.o: In function `__static_initialization_and_destruction_0(int, int)': bspl0017.cpp:(.text+0x10a): undefined reference to `std::ios_base::Init::Init()' /tmp/cclDEYNT.o:(.eh_frame+0x11): undefined reference to `__gxx_personality_v0' collect2: ld gab 1 als Ende-Status zurück schlubber@ubuntu:~/programme/c++$
vl könnt ihr mir auch hier helfen
Zu Deinem C++-Problem:
benutze g++ statt gcc zum Kompilieren, dann sollten die Pfade/Optionen/etc. korrekt gesetzt sein.
danke
so ist nun mal das erste problem gelöst
OpenJDK8 unter Debian7.11/sparc64/kernel 3.16 kompilieren
patch erstellen: Probleme mit autotools?
Apache /var/www zu /home/ich/www wechseln
