M
MacZero
ich hätte folgendes Problem mit einem Debian unstable System (2.6.18.6).
Der Rechner hat eine DVB-S Karte und zwei DVB-T Sticks (Pinnacle PCTV, und einen Pinnacle Hybrid).
Die DVB-S Karte und ein DVB-T Stick (Hybrid) funktionieren einwandfrei.
Es werden beide DVB-T Sticks erkannt. Allerdings find ich in meiner /dev/dvb Struktur, nur ein adapter0(=DVB-S Karte) und adapter1 (=Pinnacle Hybrid).
Wora kann es liegen, dass nicht automatisch ein adapter2 angelegt wird?
Dmesg Auszug für adapter2:
em28xx new video device (eb1a:2870): interface 0, class 255
em28xx: device is attached to a USB 2.0 bus
em28xx #1: Alternate settings: 8
em28xx #1: Alternate setting 0, max size= 0
em28xx #1: Alternate setting 1, max size= 0
em28xx #1: Alternate setting 2, max size= 1448
em28xx #1: Alternate setting 3, max size= 2048
em28xx #1: Alternate setting 4, max size= 2304
em28xx #1: Alternate setting 5, max size= 2580
em28xx #1: Alternate setting 6, max size= 2892
em28xx #1: Alternate setting 7, max size= 3072
Tuner: registering extension (MT2060 Silicon Tuner)
input: em2880/em2870 remote control as /class/input/input3
em28xx-input.c: remote control handler attached
attach_inform: eeprom detected.
em28xx #1: i2c eeprom 00: 1a eb 67 95 1a eb 70 28 c0 12 81 00 6a 22 00 00
em28xx #1: i2c eeprom 10: 00 00 04 57 02 0d 00 00 00 00 00 00 00 00 00 00
em28xx #1: i2c eeprom 20: 44 00 00 00 f0 10 02 00 00 00 00 00 5b 00 00 00
em28xx #1: i2c eeprom 30: 00 00 20 40 20 80 02 20 01 01 00 00 b5 95 99 49
em28xx #1: i2c eeprom 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
em28xx #1: i2c eeprom 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
em28xx #1: i2c eeprom 60: 00 00 00 00 00 00 00 00 00 00 22 03 55 00 53 00
em28xx #1: i2c eeprom 70: 42 00 20 00 32 00 38 00 37 00 30 00 20 00 44 00
em28xx #1: i2c eeprom 80: 65 00 76 00 69 00 63 00 65 00 00 00 00 00 00 00
em28xx #1: i2c eeprom 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
em28xx #1: i2c eeprom a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
em28xx #1: i2c eeprom b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
em28xx #1: i2c eeprom c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
em28xx #1: i2c eeprom d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
em28xx #1: i2c eeprom e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
em28xx #1: i2c eeprom f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
EEPROM ID= 0x9567eb1a
Vendor/Product ID= eb1a:2870
No audio on board.
500mA max power
Table at 0x04, strings=0x226a, 0x0000, 0x0000
tuner 3-0060: Chip ID is not zero. It is not a TEA5767
tuner 3-0060: chip found @ 0xc0 (em28xx #1)
attach inform (default): detected I2C address c0
Tuner: setting up tuner core extension for: MT2060 Silicon Tuner
em28xx #1: Found Pinnacle PCTV DVB-T
usbcore: registered new driver em28xx
usbcore: registered new driver snd-usb-audio
em2880-dvb.c: DVB Init
DVB: registering new adapter (em2880 DVB-T).
DVB: registering frontend 1 (Zarlink ZL10353 DVB-T)...
Em28xx: Initialized (Em2880 DVB Extension) extension
