dmesg -cWoW@linux:~> dmesg-c
bash: dmesg-c: command not found
WoW@linux:~> dmesg -c
klogctl: Die Operation ist nicht erlaubt
WoW@linux:~> dmesg
Bootdata ok (command line is root=/dev/sda3 vga=0x31a selinux=0 console=tty0 resume=/dev/sda2 desktop elevator=as splash=silent)
Linux version 2.6.8-24-default (geeko@buildhost) (gcc version 3.3.4 (pre 3.3.5 20040809)) #1 Wed Oct 6 09:16:23 UTC 2004
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 0000000000099800 (usable)
BIOS-e820: 0000000000099800 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000ce000 - 00000000000d0000 (reserved)
BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000003fef0000 (usable)
BIOS-e820: 000000003fef0000 - 000000003fef8000 (ACPI data)
BIOS-e820: 000000003fef8000 - 000000003ff00000 (ACPI NVS)
BIOS-e820: 000000003ff00000 - 0000000040000000 (reserved)
BIOS-e820: 00000000fec00000 - 00000000fed00000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
BIOS-e820: 00000000fffe0000 - 0000000100000000 (reserved)
No mptable found.
On node 0 totalpages: 261872
DMA zone: 4096 pages, LIFO batch:1
Normal zone: 257776 pages, LIFO batch:16
HighMem zone: 0 pages, LIFO batch:1
ACPI: RSDP (v002 PTLTD ) @ 0x00000000000f8000
ACPI: XSDT (v001 PTLTD XSDT 0x06040001 LTP 0x00000000) @ 0x000000003fef516d
ACPI: FADT (v003 FSC 0x06040001 0x000f4240) @ 0x000000003fef5225
ACPI: SSDT (v001 PTLTD POWERNOW 0x06040001 LTP 0x00000001) @ 0x000000003fef7e80
ACPI: MADT (v001 FSC APIC 0x06040001 CSF 0x00000000) @ 0x000000003fef7f98
ACPI: BOOT (v001 PTLTD $SBFTBL$ 0x06040001 LTP 0x00000001) @ 0x000000003fef7fd8
ACPI: DSDT (v001 FSC D1607 0x06040001 MSFT 0x02000002) @ 0x0000000000000000
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 15:12 APIC version 16
ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 1, version 3, address 0xfec00000, GSI 0-23
ACPI: IRQ9 used by override.
Using ACPI (MADT) for SMP configuration information
Checking aperture...
CPU 0: aperture @ d0000000 size 256 MB
Built 1 zonelists
Kernel command line: root=/dev/sda3 vga=0x31a selinux=0 console=tty0 resume=/dev/sda2 desktop elevator=as splash=silent
bootsplash: silent mode.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 131072 bytes)
time.c: Using 1.193182 MHz PIT timer.
time.c: Detected 2399.952 MHz processor.
Console: colour dummy device 80x25
Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
Memory: 1024588k/1047488k available (2322k kernel code, 22128k reserved, 927k data, 180k init)
Calibrating delay loop... 4718.59 BogoMIPS (lpj=2359296)
Security Scaffold v1.0.0 initialized
SELinux: Disabled at boot.
Mount-cache hash table entries: 256 (order: 0, 4096 bytes)
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 512K (64 bytes/line)
CPU: AMD Athlon(tm) 64 Processor 3400+ stepping 00
Using local APIC NMI watchdog using perfctr0
Using local APIC timer interrupts.
Detected 12.499 MHz APIC timer.
checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Looking for DSDT in initrd ...No customized DSDT found in initrd!
NET: Registered protocol family 16
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20040715
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (00:00)
PCI: Probing PCI hardware (bus 00)
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.AGPB._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: Device [ECP] status [00000008]: functional but not present; setting present
ACPI: Device [COM2] status [00000008]: functional but not present; setting present
PCI: Using ACPI for IRQ routing
ACPI: PCI interrupt 0000:00:0a.0[A] -> GSI 19 (level, low) -> IRQ 177
ACPI: PCI interrupt 0000:00:0b.0[A] -> GSI 19 (level, low) -> IRQ 177
ACPI: PCI interrupt 0000:00:0d.0[A] -> GSI 22 (level, low) -> IRQ 185
ACPI: PCI interrupt 0000:00:0f.0[B] -> GSI 20 (level, low) -> IRQ 193
ACPI: PCI interrupt 0000:00:0f.1[A] -> GSI 20 (level, low) -> IRQ 193
ACPI: PCI interrupt 0000:00:10.0[A] -> GSI 21 (level, low) -> IRQ 201
ACPI: PCI interrupt 0000:00:10.1[A] -> GSI 21 (level, low) -> IRQ 201
ACPI: PCI interrupt 0000:00:10.2[B] -> GSI 21 (level, low) -> IRQ 201
ACPI: PCI interrupt 0000:00:10.3[B] -> GSI 21 (level, low) -> IRQ 201
ACPI: PCI interrupt 0000:00:10.4[C] -> GSI 21 (level, low) -> IRQ 201
ACPI: PCI interrupt 0000:00:11.5[C] -> GSI 22 (level, low) -> IRQ 185
ACPI: PCI interrupt 0000:00:13.0[A] -> GSI 22 (level, low) -> IRQ 185
ACPI: PCI interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 209
TC classifier action (bugs to [email]netdev@oss.sgi.com[/email] cc [email]hadi@cyberus.ca[/email])
agpgart: Detected AGP bridge 0
agpgart: Maximum main memory to use for agp memory: 940M
agpgart: AGP aperture is 256M @ 0xd0000000
PCI-DMA: Disabling IOMMU.
Simple Boot Flag at 0x69 set to 0x1
IA32 emulation $Id: sys_ia32.c,v 1.32 2002/03/24 13:02:28 ak Exp $
audit: initializing netlink socket (disabled)
audit(1107279743.248:0): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Initializing Cryptographic API
PCI: Via IRQ fixup for 0000:00:10.0, from 11 to 9
PCI: Via IRQ fixup for 0000:00:10.1, from 11 to 9
PCI: Via IRQ fixup for 0000:00:10.2, from 11 to 9
PCI: Via IRQ fixup for 0000:00:10.3, from 11 to 9
vesafb: framebuffer at 0xe0000000, mapped to 0xffffff0000180000, using 10240k, total 16384k
vesafb: mode is 1280x1024x16, linelength=2560, pages=5
vesafb: scrolling: redraw
vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
bootsplash 3.1.6-2004/03/31: looking for picture...<6> silentjpeg size 47601 bytes,<6>...found (1280x1024, 24984 bytes, v3).
Console: switching to colour frame buffer device 158x57
fb0: VESA VGA frame buffer device
Real Time Clock Driver v1.12
Non-volatile memory driver v1.2
Linux agpgart interface v0.100 (c) Dave Jones
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
Serial: 8250/16550 driver $Revision: 1.90 $ 8 ports, IRQ sharing disabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 128000K size 1024 blocksize
loop: loaded (max 8 devices)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:0f.1
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1
ide0: BM-DMA at 0x2c10-0x2c17, BIOS settings: hda:pio, hdb:pio
ide1: BM-DMA at 0x2c18-0x2c1f, BIOS settings: hdc:DMA, hdd:DMA
Probing IDE interface ide0...
Probing IDE interface ide1...
hdc: HL-DT-ST DVD-RW GWA-4160B, ATAPI CD/DVD-ROM drive
hdd: LITE-ON LTR-24102B, ATAPI CD/DVD-ROM drive
Using anticipatory io scheduler
ide1 at 0x170-0x177,0x376 on irq 15
Probing IDE interface ide2...
ide2: Wait for ready failed before probe !
Probing IDE interface ide3...
ide3: Wait for ready failed before probe !
Probing IDE interface ide4...
ide4: Wait for ready failed before probe !
Probing IDE interface ide5...
ide5: Wait for ready failed before probe !
hdc: ATAPI 24X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache
Uniform CD-ROM driver Revision: 3.20
hdd: ATAPI 40X CD-ROM CD-R/RW drive, 2048kB Cache
ide-floppy driver 0.99.newide
mice: PS/2 mouse device common for all mice
input: AT Translated Set 2 keyboard on isa0060/serio0
alps.c: E6 report: 0a 03 c8
input: PS2++ Logitech Wheel Mouse on isa0060/serio1
input: PC Speaker
md: md driver 0.90.0 MAX_MD_DEVS=256, MD_SB_DISKS=27
NET: Registered protocol family 2
IP: routing cache hash table of 8192 buckets, 64Kbytes
TCP: Hash tables configured (established 262144 bind 65536)
PM: Reading pmdisk image.
swsusp: Resume From Partition: /dev/sda2
pmdisk: Error -6 resuming
PM: Resume from disk failed.
ACPI: (supports S0 S1 S3 S4 S5)
ACPI wakeup devices:
PCI0 AGPB USB1 USB2 USB3 USB4 USB5 AC97 MC97 KEYB PS2M COM1 COM2
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
RAMDISK: Compressed image found at block 0
VFS: Mounted root (ext2 filesystem).
SCSI subsystem initialized
libata version 1.02 loaded.
sata_via version 0.20
sata_via(0000:00:0f.0): routed to hard irq line 9
ata1: SATA max UDMA/133 cmd 0x2C30 ctl 0x2C26 bmdma 0x2C00 irq 193
ata2: SATA max UDMA/133 cmd 0x2C28 ctl 0x2C22 bmdma 0x2C08 irq 193
ata1: dev 0 cfg 49:2f00 82:346b 83:7d01 84:4003 85:3469 86:3c01 87:4003 88:407f
ata1: dev 0 ATA, max UDMA/133, 390721968 sectors: lba48
ata1: dev 0 configured for UDMA/133
scsi0 : sata_via
ata2: no device found (phy stat 00000000)
scsi1 : sata_via
Vendor: ATA Model: ST3200822AS Rev: 3.01
Type: Direct-Access ANSI SCSI revision: 05
SCSI device sda: 390721968 512-byte hdwr sectors (200050 MB)
SCSI device sda: drive cache: write back
sda: sda1 sda2 sda3
Attached scsi disk sda at scsi0, channel 0, id 0, lun 0
ReiserFS: sda3: found reiserfs format "3.6" with standard journal
ReiserFS: sda3: using ordered data mode
reiserfs: using flush barriers
ReiserFS: sda3: journal params: device sda3, size 8192, journal first block 18,max trans len 1024, max batch 900, max commit age 30, max trans age 30
ReiserFS: sda3: checking transaction log (sda3)
reiserfs: disabling flush barriers on sda3
ReiserFS: sda3: Using r5 hash to sort names
VFS: Mounted root (reiserfs filesystem) readonly.
Trying to move old root to /initrd ... failed
Unmounting old root
Trying to free ramdisk memory ... okay
Freeing unused kernel memory: 180k freed
Adding 1036184k swap on /dev/sda2. Priority:42 extents:1
Linux Tulip driver version 1.1.13-NAPI (May 11, 2002)
tulip0: MII transceiver #1 config 1000 status 786d advertising 01e1.
eth0: ADMtek Comet rev 17 at 0x1000, 00:30:05:68:5A:B0, IRQ 177.
usbcore: registered new driver usbfs
usbcore: registered new driver hub
md: autorun ...
device-mapper: 4.1.0-ioctl (2003-12-10) initialised: [email]dm@uk.sistina.com[/email]
NTFS driver 2.1.17 [Flags: R/O MODULE].
NTFS volume version 3.1.
subfs 0.9
evdev_connect: evdev 000001003fd59200 handle 000001003fd59220 name event0
evdev_connect: evdev 000001003fd27e00 handle 000001003fd27e20 name event1
evdev_connect: evdev 000001003fd27c00 handle 000001003fd27c20 name event2
ieee1394: Initialized config rom entry `ip1394'
ohci1394: $Rev: 1223 $ Ben Collins <bcollins@debian.org>
ohci1394: fw-host0: Unexpected PCI resource length of 1000!
ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[185] MMIO=[f0001000-f00017ff] Max Packet=[2048]
USB Universal Host Controller Interface driver v2.2
uhci_hcd 0000:00:10.0: UHCI Host Controller
uhci_hcd 0000:00:10.0: irq 201, io base 0000000000001800
uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
usb usb1: Product: UHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.8-24-default uhci_hcd
usb usb1: SerialNumber: 0000:00:10.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
uhci_hcd 0000:00:10.1: UHCI Host Controller
uhci_hcd 0000:00:10.1: irq 201, io base 0000000000001c00
uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
usb usb2: Product: UHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.8-24-default uhci_hcd
usb usb2: SerialNumber: 0000:00:10.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
uhci_hcd 0000:00:10.2: UHCI Host Controller
uhci_hcd 0000:00:10.2: irq 201, io base 0000000000002000
uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
usb usb3: Product: UHCI Host Controller
usb usb3: Manufacturer: Linux 2.6.8-24-default uhci_hcd
usb usb3: SerialNumber: 0000:00:10.2
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
uhci_hcd 0000:00:10.3: UHCI Host Controller
uhci_hcd 0000:00:10.3: irq 201, io base 0000000000002400
uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
usb usb4: Product: UHCI Host Controller
usb usb4: Manufacturer: Linux 2.6.8-24-default uhci_hcd
usb usb4: SerialNumber: 0000:00:10.3
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
ieee1394: Host added: ID:BUS[0-00:1023] GUID[00300531000e3e0f]
ehci_hcd 0000:00:10.4: EHCI Host Controller
ehci_hcd 0000:00:10.4: irq 201, pci mem ffffff000017a800
ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 5
ehci_hcd 0000:00:10.4: USB 2.0 enabled, EHCI 1.00, driver 2004-May-10
usb usb5: Product: EHCI Host Controller
usb usb5: Manufacturer: Linux 2.6.8-24-default ehci_hcd
usb usb5: SerialNumber: 0000:00:10.4
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 8 ports detected
usb 5-7: new high speed USB device using address 2
usb 5-7: device not accepting address 2, error -71
usb 5-7: new high speed USB device using address 3
usb 5-7: device not accepting address 3, error -71
NET: Registered protocol family 10
Disabled Privacy Extensions on device ffffffff803e24c0(lo)
IPv6 over IPv4 tunneling driver
ip6_tables: (C) 2000-2002 Netfilter core team
ip_tables: (C) 2000-2002 Netfilter core team
ip_conntrack version 2.1 (4091 buckets, 32728 max) - 480 bytes per conntrack
ip6_conntrack version 0.1 (4091 buckets, 32728 max) - 312 bytes per conntrack
st: Version 20040403, fixed bufsize 32768, s/g segs 256
Attached scsi generic sg0 at scsi0, channel 0, id 0, lun 0, type 0
NET: Registered protocol family 17
eth0: Setting full-duplex based on MII#1 link partner capability of 41e1.
Disabled Privacy Extensions on device 000001003c464800(sit0)
eth0: no IPv6 routers present
via82xx: Assuming DXS channels with 48k fixed sample rate.
Please try dxs_support=1 or dxs_support=4 option
and report if it works on your machine.
PCI: Setting latency timer of device 0000:00:11.5 to 64
ACPI: Power Button (FF) [PWRF]
ACPI: Processor [CPU0] (supports C1)
powernow-k8: Found 1 AMD Athlon 64 / Opteron processors (version 1.00.09b)
powernow-k8: 0 : fid 0x10 (2400 MHz), vid 0x2 (1500 mV)
powernow-k8: 1 : fid 0xe (2200 MHz), vid 0x6 (1400 mV)
powernow-k8: 2 : fid 0xc (2000 MHz), vid 0xa (1300 mV)
powernow-k8: 3 : fid 0xa (1800 MHz), vid 0xe (1200 mV)
powernow-k8: 4 : fid 0x2 (1000 MHz), vid 0x12 (1100 mV)
powernow-k8: cpu_init done, current fid 0x10, vid 0x2
BIOS EDD facility v0.16 2004-Jun-25, 1 devices found
parport0: PC-style at 0x378 [PCSPP,TRISTATE,EPP]
lp0: using parport0 (polling).
drivers/usb/serial/usb-serial.c: USB Serial support registered for Generic
usbcore: registered new driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core v2.0
mtrr: 0xe0000000,0x8000000 overlaps existing 0xe0000000,0x1000000
Linux video capture interface: v1.00
saa7130/34: v4l2 driver version 0.2.12 loaded
saa7134[0]: found at 0000:00:0a.0, rev: 1, irq: 177, latency: 64, mmio: 0xf0000000
saa7134[0]: subsystem: 1540:9524, board: UNKNOWN/GENERIC [card=0,autodetected]
saa7134[0]: board init: gpio is 0
saa7134[0]: i2c eeprom 00: 40 15 24 95 00 00 00 00 00 00 00 00 00 00 00 00
saa7134[0]: i2c eeprom 10: 00 03 1f 00 ff ff ff ff ff ff ff ff ff ff ff ff
saa7134[0]: i2c eeprom 20: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7134[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7134[0]: registered device video0 [v4l2]
saa7134[0]: registered device vbi0
inserting floppy driver for 2.6.8-24-default
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
end_request: I/O error, dev fd0, sector 0
Bluetooth: Core ver 2.6
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
CSLIP: code copyright 1989 Regents of the University of California
PPP generic driver version 2.4.2
NET: Registered protocol family 24
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.82.213.79 DST=217.82.19.13 LEN=48 TOS=0x00 PREC=0x00 TTL=124 ID=28088 DF PROTO=TCP SPT=3586 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0 OPT (020405A001010402)
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=84.128.174.118 DST=217.82.19.13 LEN=52TOS=0x00 PREC=0x00 TTL=124 ID=25460 DF PROTO=TCP SPT=4367 DPT=445 WINDOW=32767 RES=0x00 SYN URGP=0 OPT (020405A00103030001010402)
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.82.103.139 DST=217.82.19.13 LEN=48TOS=0x00 PREC=0x00 TTL=124 ID=41827 DF PROTO=TCP SPT=3614 DPT=135 WINDOW=64800 RES=0x00 SYN URGP=0 OPT (020405A001010402)
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.82.103.139 DST=217.82.19.13 LEN=48TOS=0x00 PREC=0x00 TTL=124 ID=42006 DF PROTO=TCP SPT=3614 DPT=135 WINDOW=64800 RES=0x00 SYN URGP=0 OPT (020405A001010402)
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.82.103.139 DST=217.82.19.13 LEN=48TOS=0x00 PREC=0x00 TTL=124 ID=42356 DF PROTO=TCP SPT=3816 DPT=135 WINDOW=64800 RES=0x00 SYN URGP=0 OPT (020405A001010402)
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.82.103.139 DST=217.82.19.13 LEN=48TOS=0x00 PREC=0x00 TTL=124 ID=42489 DF PROTO=TCP SPT=3860 DPT=135 WINDOW=64800 RES=0x00 SYN URGP=0 OPT (020405A001010402)
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.82.192.96 DST=217.82.19.13 LEN=48 TOS=0x00 PREC=0x00 TTL=124 ID=23881 DF PROTO=TCP SPT=3587 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0 OPT (020405AC01010402)
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.82.103.139 DST=217.82.19.13 LEN=48TOS=0x00 PREC=0x00 TTL=124 ID=45450 DF PROTO=TCP SPT=4883 DPT=135 WINDOW=64800 RES=0x00 SYN URGP=0 OPT (020405A001010402)
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.82.235.10 DST=217.82.19.13 LEN=52 TOS=0x00 PREC=0x00 TTL=124 ID=36546 DF PROTO=TCP SPT=4354 DPT=135 WINDOW=32767 RES=0x00 SYN URGP=0 OPT (020405A00103030001010402)
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.82.155.244 DST=217.82.19.13 LEN=52TOS=0x00 PREC=0x00 TTL=124 ID=48366 DF PROTO=TCP SPT=4650 DPT=445 WINDOW=32767 RES=0x00 SYN URGP=0 OPT (020405A00103030001010402)
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.82.201.46 DST=217.82.19.13 LEN=48 TOS=0x00 PREC=0x00 TTL=124 ID=47623 DF PROTO=TCP SPT=3589 DPT=135 WINDOW=64800 RES=0x00 SYN URGP=0 OPT (020405A001010402)
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.82.99.15 DST=217.82.19.13 LEN=48 TOS=0x00 PREC=0x00 TTL=124 ID=9172 DF PROTO=TCP SPT=1264 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0 OPT (020405AC01010402)
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.224.77.34 DST=217.82.19.13 LEN=52 TOS=0x00 PREC=0x00 TTL=124 ID=24938 DF PROTO=TCP SPT=4397 DPT=135 WINDOW=32767 RES=0x00 SYN URGP=0 OPT (020405AC0103030001010402)
WoW@linux:~> dmesg
No mptable found.
Built 1 zonelists
Initializing CPU#0
input: PC Speaker
md: autorun ...
scsi0 : sata_via
scsi1 : sata_via
sda: sda1 sda2 sda3
Unmounting old root
md: autorun ...
subfs 0.9
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.82.134.8 DST=217.82.19.13 LEN=48 TOS=0x00 PREC=0x00 TTL=124 ID=41016 DF PROTO=TCP SPT=3769 DPT=135 WINDOW=16384 RES=0x00 SYN URGP=0 OPT (020405A001010402)
SFW2-IN-ILL-TARGET IN=dsl0 OUT= MAC= SRC=217.82.167.244 DST=217.82.19.13 LEN=48TOS=0x00 PREC=0x00 TTL=124 ID=3141 DF PROTO=TCP SPT=2777 DPT=135 WINDOW=64800 RES=0x00 SYN URGP=0 OPT (020405A001010402)
usb 5-1: new high speed USB device using address 4
usb 5-1: Product: WG111T
usb 5-1: Manufacturer: Atheros Communications Inc
usb 5-1: SerialNumber: 1.0
