Emess
Turmspringer
Habe mir einen neuen Rechner gebaut. Lenny installiert- alles einwandfrei.
Unter Squeeze lässt sich allerdings der Wlan Treiber rt2500 nicht installieren, weder mit dem module-assistant noch mit make.
Egal was tue es gibt die gleiche Fehlermeldung.Ich hoffe einer von euch kann mir sagen wo es hängt?
wie schon gesagt m-a build rt2500 erzeugt den gleichen Fehler
make[1]: Entering directory `/usr/src/linux-headers-2.6.30-2-686'
CC [M] /usr/src/Module/rtmp_main.o
In file included from /usr/src/Module/rt_config.h:144,
from /usr/src/Module/rtmp_main.c:50:
/usr/src/Module/rtmp.h:52: error: conflicting types for ‘irqreturn_t’
/usr/src/linux-headers-2.6.30-2-common/include/linux/irqreturn.h:16: error: previous declaration of ‘irqreturn_t’ was here
/usr/src/Module/rtmp.h:55:1: warning: "IRQ_RETVAL" redefined
In file included from /usr/src/linux-headers-2.6.30-2-common/include/linux/pci.h:55,
from /usr/src/Module/rt_config.h:73,
/usr/src/linux-headers-2.6.30-2-common/include/linux/irqreturn.h:17:1: warning: this is the location of the previous definition
/usr/src/Module/rtmp_main.c: In function ‘RT2500_probe’:
/usr/src/Module/rtmp_main.c:262: error: ‘struct device’ has no member named ‘bus_id’
/usr/src/Module/rtmp_main.c:295: error: ‘struct net_device’ has no member named ‘priv’
/usr/src/Module/rtmp_main.c: In function ‘RT2500_open’:
/usr/src/Module/rtmp_main.c:392: error: ‘struct net_device’ has no member named ‘priv’
/usr/src/Module/rtmp_main.c:413: warning: passing argument 2 of ‘request_irq’ from incompatible pointer type
/usr/src/Module/rtmp_main.c: In function ‘RTMPSendPackets’:
/usr/src/Module/rtmp_main.c:514: error: ‘struct net_device’ has no member named ‘priv’
/usr/src/Module/rtmp_main.c: In function ‘RTMPIsr’:
/usr/src/Module/rtmp_main.c:599: error: ‘struct net_device’ has no member named ‘priv’
/usr/src/Module/rtmp_main.c: In function ‘rt2500_set_mac_address’:
/usr/src/Module/rtmp_main.c:712: error: ‘struct net_device’ has no member named ‘priv’
/usr/src/Module/rtmp_main.c: In function ‘RT2500_get_wireless_stats’:
/usr/src/Module/rtmp_main.c:770: error: ‘struct net_device’ has no member named ‘priv’
/usr/src/Module/rtmp_main.c: In function ‘RT2500_get_ether_stats’:
/usr/src/Module/rtmp_main.c:812: error: ‘struct net_device’ has no member named ‘priv’
/usr/src/Module/rtmp_main.c: In function ‘RT2500_set_rx_mode’:
/usr/src/Module/rtmp_main.c:872: error: ‘struct net_device’ has no member named ‘priv’
/usr/src/Module/rtmp_main.c: In function ‘RT2500_close’:
/usr/src/Module/rtmp_main.c:899: error: ‘struct net_device’ has no member named ‘priv’
/usr/src/Module/rtmp_main.c: In function ‘RT2500_remove_one’:
/usr/src/Module/rtmp_main.c:953: error: ‘struct net_device’ has no member named ‘priv’
/usr/src/Module/rtmp_main.c: In function ‘rt2500_suspend’:
/usr/src/Module/rtmp_main.c:993: error: ‘struct net_device’ has no member named ‘priv’
/usr/src/Module/rtmp_main.c: In function ‘rt2500_resume’:
/usr/src/Module/rtmp_main.c:1024: error: ‘struct net_device’ has no member named ‘priv’
make[4]: *** [/usr/src/Module/rtmp_main.o] Fehler 1
make[3]: *** [_module_/usr/src/Module] Fehler 2
make[2]: *** [sub-make] Fehler 2
make[1]: *** [all] Fehler 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.30-2-686'
rt2500.ko failed to build!
make: *** [debug] Fehler 1
