modprobe slamr Problem bei Aurox 10.0
J
Jesuz
Hallo, ich habe ein Maxdata Notebook mit eingebautem Winmodem. Das Modem ist von der Firma Smartlink. Diese stellen auf www.smlink.com einen Treiber für ihre Modems online. Ich habe damit ein Problem. Nach dem Herunterladen des Treibers habe ich alles getan was in der Readme stand. Hier kurz ein Ausschnitt davon:
Installation
1. Unpack tar.gz package file:
$ gzip -dc slmodem-2.9.X.tar.gz | tar xf -
2. 'cd' to package directory:
$ cd slmodem-2.9.X
3. Review and edit 'Makefile' (if need):
In many cases you will need to correct path to your local kernel
source tree:
KERNEL_DIR=/path/to/linux
Default KERNEL_DIR is '/lib/modules/<kerne-version>/build'. Many Linux
Distributions use directory '/usr/src/linux-<version>' also.
Note: If you are using Linux kernel 2.4, only header files should be
available for build in $(KERNEL_DIR)/include
Another way to pass right value KERNEL_DIR is to use command line
parameter while running 'make':
$ make KERNEL_DIR=/path/to/linux ...
4. Run 'make' command to compile package:
$ make
5. Install. As 'root' user run:
# make install
It will install:
- application 'slmodemd' under '/usr/sbin' directory
- hardware specific drivers (kernel modules) 'slamr' and 'slusb'
under conventional kernel modules directory
- character device nodes '/dev/slamr0-3' with major number 212
(for pci modems) and '/dev/slusb0-3' with major number 213
(for usb modems).
- config modules for autoloading (by editing file '/etc/modules.conf')
(only with 2.4 kernels)
6. Config modem country.
Use AT+GCI=<T.35 country code> command to setup country.
Also you can setup default modem country by passing command line
parameter '--country=MY_COUNTRY' to program 'slmodemd'.
See output of 'slmodemd --countrylist' for a list of supported
country names and T.35 country codes (see also 'slmodemd --help').
Note: Command ATI7 shows currently installed country setting.
8. Uninstallation.
In package directory just type:
# make uninstall
Getting Started
After successful installation and configuration:
1. Load modem driver.
Load your modem hardware specific kernel module:
# modprobe slamr
if you are using AMR/CNR/PCI modem, or
# modprobe slusb
if you are using SmartUSB56 Modem.
Note: this will be done automatically when modules were
configured for 'loading on demand'
Note: this is safe to load both 'alamr' and 'slusb' modules.
2. Run soft modem application.
# /usr/sbin/slmodemd [options] <device_name>
Where device name is appropriate device node for your modem
(look at output of 'dmesg' command).
Run '/usr/sbin/slmodemd --help' for details.
Examples:
# /usr/sbin/slmodemd --country=USA /dev/slamr0
, or for SmartUSB56 Modems:
# /usr/sbin/slmodemd --country=ITALY /dev/slusb0
Sooo ... es läuft auch alles, bis zu der Stelle als ich den Treiber via modprobe laden soll, da gibt er mir aus "Command not found" ... was tun? Ich bin als Root in der Konsole wenn ich das eingebe. Kompilieren und Installieren tut er ohne eine Fehlermeldung.
Das Modem funktioniert ohne Probleme, ich habe Testweise eine SuSe 9.3 draufgehabt (die kann ich aufgrund von Kompitabilitätsproblemen mit dem soundchipsatz nicht nutzen) und da funkte das Modem wunderbar... wenn ich das RPM Paket von der SuSe Distri installiere tut sich da nichts sonderliches, der Treiber taucht in der Ausgabe von dmesg dann auch nicht auf ,...
Was soll ich tun? Ich habe keine Ahnung was ich noch machen könnte ...
Als Kernel ist die Standardkernel drin, eine 2.6.7
Ok, ich würde mich auf alle Fälle über Hilfe freuen, bin eigentlich noch Linux Neuling, wollte aber schon seit längerem Zeitraum umsteigen.
vlg
Scheinbar hast du modprobe nicht installiert (was ich nicht glaube). Schau mal einfach mit 'whereis modprobe' nach, wo sich das Programm befindet und starte es dann mit Angabe des kompletten Pfads.
Also ich hab das jetzt hinbekommen, modprobe war bei mir nicht installiert und ich bin über den normalen "SU" Account gegangen ... jetzt hab ichs mit "su -" gemacht.
Jetzt hab ich zwar nen Port ttysl0 wo mein modem liegt, nunhab ich noch ein Problem (ich hoffe ich nerve nicht damit) ... das kppp zeigt mir genau dieses nicht an, kann mal den nicht irgendwie auf einen an eine andere Schnittstelle wie zum Beispiel ttys0 oder so legen? Oder vielleicht direkt an /dev/modem/ legen? ist sowas möglich?
Leg doch einfach einen Softlink (ln -s quelle ziel) von /dev/ttysl0 nach /dev/ttyS0 an.
Samba4 AD DC
X startet nichtmehr
Ich mag Dovecot nicht ...
