zyon
undeadlyBSD
bei test1.wmv habe ich keine Probleme. es läauft sauber durch, bei test2.wmv hack der ton und das bild sehr stark, mann kann nur male 1-2sec ein anderes Bild sehen wie mann ja an:
merkt. Hat jeamdn für dieses Problem eine lösung? Ich würde mich sehr freuen. Hier noch mal die logs beim abspielen der *wmv's.
Zy0n
test1.wmv
test2.wmv
alsa-space: xrun of at least 0.075 msecs. resetting stream0.4% 4 0 63%
alsa-space: xrun of at least 0.072 msecs. resetting stream0.4% 4 0 61%
alsa-space: xrun of at least 0.074 msecs. resetting stream0.4% 5 0 58%
alsa-space: xrun of at least 0.073 msecs. resetting stream0.4% 6 0 56%
alsa-space: xrun of at least 0.078 msecs. resetting stream0.4% 7 0 54%
alsa-space: xrun of at least 0.081 msecs. resetting stream0.4% 7 0 51%
..... usw bis zum schluss
Zy0n
test1.wmv
zyon@****up:~$ mplayer incoming/downloade/test1.wmv
MPlayer dev-CVS--4.0.3 (C) 2000-2005 MPlayer Team
CPU: Intel Pentium 4/Celeron 4 Northwood; Pentium 4 EE/Xeon Prestonia,Gallatin (Family: 15, Ste
pping: 9)
Detected cache-line size is 64 bytes
CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled for Debian
Failed to open /dev/rtc: Permission denied (it should be readable by the user.)
Opening joystick device /dev/input/js0
Can't open joystick device /dev/input/js0 : Permission denied
Can't init input joystick
Setting up LIRC support...
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support.
You will not be able to use your remote control.
Playing incoming/downloade/test1.wmv.
ASF file format detected.
VIDEO: [WMV3] 320x240 24bpp 1000.000 fps 0.0 kbps ( 0.0 kbyte/s)
Clip info:
copyright: my
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 44100 Hz, 2 ch, s16le, 48.2 kbit/3.42% (ratio: 6028->176400)
Selected audio codec: [ffwmav2] afm: ffmpeg (DivX audio v2 (FFmpeg))
Opening video decoder: [dmo] DMO video codecs
DMO dll supports VO Optimizations 0 1
DMO dll might use previous sample when requested
GetOutput r=0x0 size:230400 align:1
StreamCount r=0x0 1 1
Decoder supports the following formats: YV12 YUY2 UYVY YVYU RGB8 RGB555 RGB565 RGB24 RGB32
Decoder is capable of YUV output (flags 0x1b)
VDec: vo config request - 320 x 240 (preferred colorspace: Packed YUY2)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
VO: [xv] 320x240 => 320x240 Planar YV12
Selected video codec: [wmv9dmo] vfm: dmo (Windows Media Video 9 DMO)
Building audio filter chain for 44100Hz/2ch/s16le -> 0Hz/0ch/??...
alsa-init: 1 soundcard found, using: default
ALSA lib timer_hw.c:269:(snd_timer_hw_open) extended read is not supported (SNDRV_TIMER_IOCTL_T
READ)
alsa: 44100 Hz/2 channels/4 bpf/60208 bytes buffer/Signed 16 bit Little Endian
AO: [alsa] 44100Hz 2ch s16le (2 bytes per sample)
Building audio filter chain for 44100Hz/2ch/s16le -> 44100Hz/2ch/s16le...
Starting playback...
A: 7.0 V: 7.0 A-V: -0.020 ct: -0.046 120/120 5% 3% 0.7% 0 0 69%
MPlayer interrupted by signal 13 in module: flip_page
- MPlayer crashed. This shouldn't happen.
It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
gcc version. If you think it's MPlayer's fault, please read
DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
won't help unless you provide this information when reporting a possible bug.
X connection to :0.0 broken (explicit kill or server shutdown).
test2.wmv
zyon@****up:~$ mplayer incoming/downloade/test2.wmv
CPU: Intel Pentium 4/Celeron 4 Northwood; Pentium 4 EE/Xeon Prestonia,Gallatin (Family: 15, Stepping: 9)
Compiled for Debian
Playing incoming/downloade/test2.wmv.
Cache fill: 0.00% (0 bytes)
AUDIO: 44100 Hz, 1 ch, s16le, 48.0 kbit/6.81% (ratio: 6003->88200)
Building audio filter chain for 44100Hz/1ch/s16le -> 0Hz/0ch/??...
ALSA lib timer_hw.c:269:(snd_timer_hw_open) extended read is not supported (SNDRV_TIMER_IOCTL_TREAD)
alsa: 44100 Hz/1 channels/2 bpf/30104 bytes buffer/Signed 16 bit Little Endian
AO: [alsa] 44100Hz 1ch s16le (2 bytes per sample)
Building audio filter chain for 44100Hz/1ch/s16le -> 44100Hz/1ch/s16le...
alsa-space: xrun of at least 0.071 msecs. resetting stream?,?% 0 0 90%
alsa-space: xrun of at least 0.074 msecs. resetting stream0.3% 1 0 87%
alsa-space: xrun of at least 0.072 msecs. resetting stream0.3% 1 0 83%
alsa-space: xrun of at least 0.074 msecs. resetting stream0.3% 1 0 83%
alsa-space: xrun of at least 0.073 msecs. resetting stream0.3% 2 0 79%
alsa-space: xrun of at least 0.073 msecs. resetting stream0.3% 3 0 76%
alsa-space: xrun of at least 0.073 msecs. resetting stream0.3% 4 0 74%
alsa-space: xrun of at least 0.077 msecs. resetting stream0.3% 4 0 74%
alsa-space: xrun of at least 0.077 msecs. resetting stream0.3% 4 0 71%
alsa-space: xrun of at least 0.075 msecs. resetting stream0.3% 4 0 67%
alsa-space: xrun of at least 0.074 msecs. resetting stream0.3% 4 0 65%
