T
tuxdrummer
Tripel-As
ich verusche gerade bei meinem Sony Vaio FZ die Helligkeitskontrolle zu installieren nach diesem schema soll es eigentlich funktionieren
https://bugs.launchpad.net/ubuntu/+source/hotkey-setup/+bug/95444
also habe ich das ganze per CVS runtergeladen jedoch bei der installation bekomme ich einen Fehler besser beim Configure script:
vielleicht kann mir jemand helfen sehr nett
tuxdrummer
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for a BSD-compatible install... /usr/bin/install -c
checking whether make sets $(MAKE)... yes
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for library containing getopt_long... none required
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking for pkg-config... /usr/bin/pkg-config
checking for gtk+-2.0 >= 2.4.0... checking for x11... configure: error: "X11 required for nvcontrol support"
tuxdrummer
