Player für Suse 9.3
folgende libs fehlen mir *wein*
ich werd wohl nie giga sehn können,zum kotzen ist das.gibt es kein packet mit alen libs ?????
linux:/home/enel/Down/rpms # rpm -ivh faad2-2.0-0.pm.8.i586.rpm
warning: faad2-2.0-0.pm.8.i586.rpm: V3 DSA signature: NOKEY, key ID 5f6842a4
error: Failed dependencies:
        libmp4v2.so.0 is needed by faad2-2.0-0.pm.8
        libstdc++.so.6 is needed by faad2-2.0-0.pm.8
linux:/home/enel/Down/rpms # rpm -ivh libmatroska-0.8.0-0.pm.0.i586.rpm
warning: libmatroska-0.8.0-0.pm.0.i586.rpm: V3 DSA signature: NOKEY, key ID 3ab2ce5e
        libebml.so.0 is needed by libmatroska-0.8.0-0.pm.0
        libstdc++.so.6 is needed by libmatroska-0.8.0-0.pm.0
        libstdc++.so.6(CXXABI_1.3) is needed by libmatroska-0.8.0-0.pm.0
        libstdc++.so.6(GLIBCXX_3.4) is needed by libmatroska-0.8.0-0.pm.0
linux:/home/enel/Down/rpms # rpm -ivh MPlayer-1.0pre8-3.i586.rpm
warning: MPlayer-1.0pre8-3.i586.rpm: V3 DSA signature: NOKEY, key ID 4efd697e
        libcairo.so.2 is needed by MPlayer-1.0pre8-3
        libdirectfb-0.9.so.24 is needed by MPlayer-1.0pre8-3
        libglitz.so.1 is needed by MPlayer-1.0pre8-3
        libgssapi.so.1 is needed by MPlayer-1.0pre8-3
        libldap-2.3.so.0 is needed by MPlayer-1.0pre8-3
        liblzo2.so.2 is needed by MPlayer-1.0pre8-3
        libpangocairo-1.0.so.0 is needed by MPlayer-1.0pre8-3
        libslang.so.2 is needed by MPlayer-1.0pre8-3
        libslang.so.2(SLANG2) is needed by MPlayer-1.0pre8-3
        libstdc++.so.6 is needed by MPlayer-1.0pre8-3
        libstdc++.so.6(CXXABI_1.3) is needed by MPlayer-1.0pre8-3
        libstdc++.so.6(GLIBCXX_3.4) is needed by MPlayer-1.0pre8-3
        libtheora.so.0(libtheora.so.1.0) is needed by MPlayer-1.0pre8-3
linux:/home/enel/Down/rpms # rpm -ivh vlc-0.8.5-2.pm.5.i586.rpm
warning: vlc-0.8.5-2.pm.5.i586.rpm: V3 DSA signature: NOKEY, key ID 4efd697e
        libFLAC.so.7 is needed by vlc-0.8.5-2.pm.5
        libavcodec.so.51 is needed by vlc-0.8.5-2.pm.5
        libavformat.so.50 is needed by vlc-0.8.5-2.pm.5
        libavutil.so.49 is needed by vlc-0.8.5-2.pm.5
        libc.so.6(GLIBC_2.4) is needed by vlc-0.8.5-2.pm.5
        libcddb.so.2 is needed by vlc-0.8.5-2.pm.5
        libcdio.so.6 is needed by vlc-0.8.5-2.pm.5
        libcrypto.so.0.9.8 is needed by vlc-0.8.5-2.pm.5
        libdbus-1.so.2 is needed by vlc-0.8.5-2.pm.5
        libdbus-glib-1.so.2 is needed by vlc-0.8.5-2.pm.5
        libebml.so.0 is needed by vlc-0.8.5-2.pm.5
        libfaac.so.0 is needed by vlc-0.8.5-2.pm.5
        libfaad.so.0 is needed by vlc-0.8.5-2.pm.5
        libgnutls.so.12 is needed by vlc-0.8.5-2.pm.5
        libgnutls.so.12(GNUTLS_1_2) is needed by vlc-0.8.5-2.pm.5
        libhal-storage.so.1 is needed by vlc-0.8.5-2.pm.5
        libhal.so.1 is needed by vlc-0.8.5-2.pm.5
        libid3tag.so.0 is needed by vlc-0.8.5-2.pm.5
        libiso9660.so.4 is needed by vlc-0.8.5-2.pm.5
        libmatroska.so.0 is needed by vlc-0.8.5-2.pm.5
        libmp4v2.so.0 is needed by vlc-0.8.5-2.pm.5
        libmpeg2.so.0 is needed by vlc-0.8.5-2.pm.5
        libpostproc.so.51 is needed by vlc-0.8.5-2.pm.5
        libresmgr.so.1 is needed by vlc-0.8.5-2.pm.5
        libslang.so.2 is needed by vlc-0.8.5-2.pm.5
        libssl.so.0.9.8 is needed by vlc-0.8.5-2.pm.5
        libstdc++.so.6 is needed by vlc-0.8.5-2.pm.5
        libstdc++.so.6(CXXABI_1.3) is needed by vlc-0.8.5-2.pm.5
        libstdc++.so.6(GLIBCXX_3.4) is needed by vlc-0.8.5-2.pm.5
        libtheora.so.0(libtheora.so.1.0) is needed by vlc-0.8.5-2.pm.5
        libwx_baseu-2.6.so.0 is needed by vlc-0.8.5-2.pm.5
        libwx_baseu_net-2.6.so.0 is needed by vlc-0.8.5-2.pm.5
        libwx_baseu_xml-2.6.so.0 is needed by vlc-0.8.5-2.pm.5
        libwx_gtk2u_adv-2.6.so.0 is needed by vlc-0.8.5-2.pm.5
        libwx_gtk2u_core-2.6.so.0 is needed by vlc-0.8.5-2.pm.5
        libwx_gtk2u_html-2.6.so.0 is needed by vlc-0.8.5-2.pm.5
        libwx_gtk2u_qa-2.6.so.0 is needed by vlc-0.8.5-2.pm.5
        libwx_gtk2u_xrc-2.6.so.0 is needed by vlc-0.8.5-2.pm.5
        libxosd.so.2 is needed by vlc-0.8.5-2.pm.5
Gib einfach die Nötige Abhaengigket in Yast ein oder such ein RPM bei rpm.pbone.org.
z.B.: libmp4v2.so.0
EDIT: Oder installier die 'Smart' wie hier im Forum beschrieben. Füge die Live server hinzu und installiere den VLC. Es wählt automatisch die notwendigen Pakete.
Die libstdc++ ist z.B. ueber die normalen SuSE-Server bzw. die CD/DVD nachinstallierbar. Einfach yast aufrufen, auf Software installieren gehen, libstdc++ in das Suchen-Feld eingeben, Haekchen vor dem entsprechenden Paket machen, bestaetigen, fertig. Ob die libmp4 bei SuSE dabei ist, weiss ich jetzt nicht aus dem Kopf, aber einfach mal danach mit yast suchen, wuerde ich sagen.
Ares schrieb:
ja ich will mir den giga live stream an sehn und kanns nicht da er mir immer sagt ist nicht kompatible.
http://www.giga.de/features/live/
der zweite Play-knopf geht mit dem mplayer und dem mplayer-plugin fuer den browser...
1. mplayer installieren
2. alle mplayer-codecs installieren/kopieren
3. mplayer-plugin installieren
4. wmv im browser schauen.
5. mit mplayer -dumpstream und stream-addresse sogar den stream(avi, mpg, rm, wmv...) auf der festplattte aufnehmen.. ;)
was Win-mediaplayer kann das kann mplayer mit mplayer plugin gerade so gut. :)
z.B.: libmp4v2.so.0
wie mach ich das
Mediaplayer: VLC 3.0.21 legt mit Opus ambisonic und AMD-Upscaling nach [Notiz]
Virtualisierung: VMware Workstation 17 Pro und Player 17 vorgestellt
Virtualisierung: VMware Workstation 17 Pro und Player 17 vorgestellt (Update)
Android-Apps unter Linux: ExTiX 22.9 mit Anbox und Google Play Store erschienen
Valve Steam Client Update: Optimierungen für den Vollbildmodus und Linux (Update)
