trunksen
Doppel-As
Hallo!
Beim installieren von VLC und Super Karamba ist ein Fehler aufgetreten.
Zuerst einmal der Fehler von Super Karamba:
dann hab ich probiert den VLC Player zu installieren:
also hab ich das libmad-0.15.1b heruntergeladen und probiert zu installieren:
scheint doch alles gut gegangen zu sein oder?
als ich dann allerdings wiederum vlc probierte zu installieren, kam der selbe Fehler wieder.
Hoffentlich könnt ihr mir meine Fehler sagen
mfg trunksen
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking for -p flag to install... yes
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for kde-config... /opt/kde3/bin/kde-config
checking where to install... /opt/kde3 (as returned by kde-config)
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking whether gcc is blacklisted... no
checking whether g++ supports -Wmissing-format-attribute... yes
checking whether gcc supports -Wmissing-format-attribute... yes
checking whether g++ supports -Wundef... yes
checking whether g++ supports -Wno-long-long... yes
checking whether g++ supports -Wno-non-virtual-dtor... yes
checking whether g++ supports -fno-reorder-blocks... yes
checking whether g++ supports -fno-exceptions... yes
checking whether g++ supports -fno-check-new... yes
checking whether g++ supports -fno-common... yes
checking whether g++ supports -fexceptions... yes
checking whether system headers can cope with -O2 -fno-inline... irrelevant
checking how to run the C++ preprocessor... g++ -E
checking whether g++ supports -O0... yes
checking whether g++ supports -Wl,--no-undefined... yes
checking whether g++ supports -Wl,--allow-shlib-undefined... yes
not using lib directory suffix
checking for a sed that does not truncate output... /usr/bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/i586-suse-linux/bin/ld
checking if the linker (/usr/i586-suse-linux/bin/ld) is GNU ld... yes
checking for /usr/i586-suse-linux/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/i586-suse-linux/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... yes
checking whether a statically linked program can dlopen itself... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/i586-suse-linux/bin/ld
checking whether the g++ linker (/usr/i586-suse-linux/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ supports -c -o file.o... yes
checking for shl_load... (cached) no
checking for shl_load in -ldld... (cached) no
checking for dlopen... (cached) no
checking for dlopen in -ldl... (cached) yes
checking whether a program can dlopen itself... (cached) yes
checking whether a statically linked program can dlopen itself... (cached) yes
appending configuration tag "F77" to libtool
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... :
checking if C++ programs can be compiled... yes
checking for strlcat... no
checking if strlcat needs custom prototype... yes - in libkdefakes
checking for strlcpy... no
checking if strlcpy needs custom prototype... yes - in libkdefakes
checking for main in -lutil... yes
checking for main in -lcompat... no
checking for crypt in -lcrypt... yes
checking for socklen_t... yes
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for inet_ntoa... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for sys/types.h... (cached) yes
checking for stdint.h... (cached) yes
checking sys/bitypes.h usability... yes
checking sys/bitypes.h presence... yes
checking for sys/bitypes.h... yes
checking for poll in -lpoll... no
checking Carbon/Carbon.h usability... no
checking Carbon/Carbon.h presence... no
checking for Carbon/Carbon.h... no
checking CoreAudio/CoreAudio.h usability... no
checking CoreAudio/CoreAudio.h presence... no
checking for CoreAudio/CoreAudio.h... no
checking if res_init needs -lresolv... yes
checking for res_init... yes
checking if res_init needs custom prototype... no
checking for killpg in -lucb... no
checking for int... yes
checking size of int... 4
checking for short... yes
checking size of short... 2
checking for long... yes
checking size of long... 4
checking for char *... yes
checking size of char *... 4
checking for shl_unload in -ldld... no
checking for size_t... yes
checking size of size_t... 4
checking for unsigned long... yes
checking size of unsigned long... 4
checking sizeof size_t == sizeof unsigned long... yes
checking for PIE support... yes
checking if enabling -pie/fPIE support... yes
checking crt_externs.h usability... no
checking crt_externs.h presence... no
checking for crt_externs.h... no
checking for _NSGetEnviron... no
checking for vsnprintf... yes
checking for snprintf... yes
checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include
checking for IceConnectionNumber in -lICE... yes
checking for libXext... yes
checking for pthread_create in -lpthread... yes
checking for extra includes... no
checking for extra libs... no
checking for libz... -lz
checking for libpng... -lpng -lz -lm
checking for libjpeg6b... no
checking for libjpeg... no
configure: WARNING: libjpeg not found. disable JPEG support.
checking for perl... /usr/bin/perl
checking for Qt... libraries /usr/lib/qt3/lib, headers /usr/lib/qt3/include using -mt
checking for moc... /usr/lib/qt3/bin/moc
checking for uic... /usr/lib/qt3/bin/uic
checking whether uic supports -L ... yes
checking whether uic supports -nounload ... yes
yes
checking for rpath... yes
checking for KDE... configure: error:
in the prefix, you've chosen, are no KDE headers installed. This will fail.
So, check this please and use another prefix!
yes
TUX:/home/trunksen/Desktop/superkaramba-0.39 #
TUX:/home/trunksen/Desktop/superkaramba-0.39 # cd ..
TUX:/home/trunksen/Desktop # cd vlc-0.8.6-rc1/
TUX:/home/trunksen/Desktop/vlc-0.8.6-rc1 # ./configure
checking whether to enable maintainer-specific portions of Makefiles... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc and cc understand -c and -o together... yes
checking whether make sets $(MAKE)... (cached) yes
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for an Objective-C compiler... checking dependency style of g++... gcc3
not implemented yet
checking for ld... ld
checking for ld used by gcc... ld
checking if the linker (ld) is GNU ld... yes
checking for ld option to reload object files... -r
checking for cf77... no
checking for pghpf... no
checking for g95... no
checking for ifort... no
checking for ftn... no
checking for ar... (cached) ar
checking for ranlib... (cached) ranlib
checking for strip... (cached) strip
checking if gcc static flag -static works... yes
checking whether the gcc linker (ld) supports shared libraries... yes
checking dynamic linker characteristics... cat: /etc/ld.so.conf.d/*.conf: No such file or directory
GNU/Linux ld.so
checking whether a statically linked program can dlopen itself... no
checking for ld used by g++... ld
checking whether the g++ linker (ld) supports shared libraries... yes
checking if g++ static flag -static works... yes
GNU/Linux ld.so
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for libs in extras/contrib... no
configure: WARNING: not using the libs in extras/contrib as it is not the same host
checking for xgettext... no
checking for msgmerge... no
checking for strerror in -lcposix... no
checking for off_t... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for stdlib.h... (cached) yes
checking for unistd.h... (cached) yes
checking for getpagesize... yes
checking for working mmap... yes
checking whether we are using the GNU C Library 2.1 or newer... yes
checking whether integer division by zero raises SIGFPE... yes
checking for unsigned long long... yes
checking whether the inttypes.h PRIxNN macros are broken... no
checking for ld used by GCC... ld
checking for shared library run path origin... done
checking argz.h usability... yes
checking argz.h presence... yes
checking for argz.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking nl_types.h usability... yes
checking nl_types.h presence... yes
checking for nl_types.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for string.h... (cached) yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for feof_unlocked... yes
checking for fgets_unlocked... yes
checking for getc_unlocked... yes
checking for getcwd... yes
checking for getegid... yes
checking for geteuid... yes
checking for getgid... yes
checking for getuid... yes
checking for mempcpy... yes
checking for munmap... yes
checking for putenv... yes
checking for setenv... yes
checking for setlocale... yes
checking for stpcpy... yes
checking for strcasecmp... yes
checking for strdup... yes
checking for strtoul... yes
checking for tsearch... yes
checking for __argz_count... yes
checking for __argz_stringify... yes
checking for __argz_next... yes
checking for iconv... yes
checking for iconv declaration...
extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
checking for nl_langinfo and CODESET... yes
checking for LC_MESSAGES... yes
checking for bison... no
checking whether NLS is requested... yes
checking whether included gettext is requested... no
checking for GNU gettext in libc... yes
checking for shared objects suffix... .so
checking for prefix to exported symbols...
checking for gettimeofday... yes
checking for strtod... yes
checking for strtol... yes
checking for strtof... yes
checking for strtoll... yes
checking for strtoull... yes
checking for strsep... yes
checking for isatty... yes
checking for vasprintf... yes
checking for asprintf... yes
checking for swab... yes
checking for sigrelse... yes
checking for getpwuid... yes
checking for memalign... yes
checking for posix_memalign... yes
checking for if_nametoindex... yes
checking for atoll... yes
checking for getenv... yes
checking for putenv... (cached) yes
checking for setenv... (cached) yes
checking for gmtime_r... yes
checking for ctime_r... yes
checking for localtime_r... yes
checking for lrintf... no
checking for daemon... yes
checking for scandir... yes
checking for fork... yes
checking for bsearch... yes
checking for lstat... yes
checking for strdup... (cached) yes
checking for strndup... yes
checking for atof... yes
checking for strcasecmp... (cached) yes
checking for strncasecmp... yes
checking for strcasestr... yes
checking for setlocale... (cached) yes
checking langinfo.h usability... yes
checking langinfo.h presence... yes
checking for langinfo.h... yes
checking for nl_langinfo... yes
checking for send... yes
checking for gethostbyname... yes
checking for struct sockaddr_storage... yes
checking for library containing getaddrinfo... none required
checking for getnameinfo... yes
checking for gai_strerror... yes
checking for struct addrinfo... yes
checking for va_copy... yes
checking for __va_copy... yes
checking for inet_aton... yes
checking for getopt_long... yes
checking return type of signal handlers... void
checking for cos in -lm... yes
checking for pow in -lm... yes
checking for sqrt in -lm... yes
checking for ceil in -lm... yes
checking for sqrtf in -lmx... no
checking mach-o/dyld.h usability... no
checking mach-o/dyld.h presence... no
checking for mach-o/dyld.h... no
checking dl.h usability... no
checking dl.h presence... no
checking for dl.h... no
checking for dld_link in -ldld... no
checking image.h usability... no
checking image.h presence... no
checking for image.h... no
checking for load_add_on... no
checking for dlfcn.h... (cached) yes
checking sys/dl.h usability... no
checking sys/dl.h presence... no
checking for sys/dl.h... no
checking for main in -lpthread... yes
checking for cthread_fork in -lthreads... no
checking for sem_init in -lrt... yes
checking for nanosleep... yes
checking for pthread_cond_t in pthread.h... yes
checking for pthread_once in pthread.h... yes
checking for strncasecmp in strings.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking stdbool.h usability... yes
checking stdbool.h presence... yes
checking for stdbool.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking for strings.h... (cached) yes
checking for inttypes.h... (cached) yes
checking sys/int_types.h usability... no
checking sys/int_types.h presence... no
checking for sys/int_types.h... no
checking wchar.h usability... yes
checking wchar.h presence... yes
checking for wchar.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking sys/times.h usability... yes
checking sys/times.h presence... yes
checking for sys/times.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking for sys/stat.h... (cached) yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking net/if.h usability... yes
checking net/if.h presence... yes
checking for net/if.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking machine/param.h usability... no
checking machine/param.h presence... no
checking for machine/param.h... no
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking linux/version.h usability... yes
checking linux/version.h presence... yes
checking for linux/version.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking whether time.h and sys/time.h may both be included... yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking for nanosleep in time.h... yes
checking for timespec in sys/time.h... yes
checking cthreads.h usability... no
checking cthreads.h presence... no
checking for cthreads.h... no
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking kernel/scheduler.h usability... no
checking kernel/scheduler.h presence... no
checking for kernel/scheduler.h... no
checking kernel/OS.h usability... no
checking kernel/OS.h presence... no
checking for kernel/OS.h... no
checking whether -R must be followed by a space... neither works
checking for gethostbyname... (cached) yes
checking for connect... (cached) yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for HAL... no
configure: WARNING: HAL library not found
checking for ntohl in sys/param.h... no
checking if $CC accepts -Wall... yes
checking if $CC accepts -Wconversion... yes
checking if $CC accepts -Wunreachable-code... yes
checking if $CC accepts -Wsign-compare... yes
checking if $CC accepts -pipe... yes
checking if $CC accepts -Os... yes
checking if $CC accepts -O3... yes
checking if $CC accepts -O2... yes
checking if $CC accepts -ffast-math... yes
checking if $CC accepts -funroll-loops... yes
checking if $CC accepts -fomit-frame-pointer... yes
checking if $CC accepts -mdynamic-no-pic... no
checking if $CC accepts -bundle -undefined error... no
checking if $CC accepts -shared... yes
checking for variadic cpp macros... yes
checking __attribute__ ((aligned ())) support... 64
checking __attribute__ ((format ())) support with function pointers... yes
checking for __attribute__((packed))... yes
checking if $CC groks MMX inline assembly... yes
checking if $CC groks MMX intrinsics... yes
checking if $CC groks MMX EXT inline assembly... yes
checking if $CC groks 3D Now! inline assembly... yes
checking if $CC groks SSE inline assembly... yes
checking if $CC groks AltiVec inline assembly... no
checking if $CC groks AltiVec C extensions... no
checking altivec.h usability... no
checking altivec.h presence... no
checking for altivec.h... no
checking if linker needs -framework vecLib... no
checking whether gcc accepts -mtune=pentium2... yes
checking for NOTIFY... no
checking dvdread/dvd_reader.h usability... no
checking dvdread/dvd_reader.h presence... no
checking for dvdread/dvd_reader.h... no
checking for dvdnav-config... no
checking libsmbclient.h usability... no
checking libsmbclient.h presence... no
checking for libsmbclient.h... no
checking for struct _SMBCCTX.close_fn... no
checking for dvbpsi/dr.h... no
configure: WARNING: cannot find libdvbpsi headers
checking for dvbpsi_GenSDTSections in -ldvbpsi... no
checking for GNOMEVFS... no
configure: WARNING: GnomeVFS support disabled because GnomeVFS development headers not found
checking for LIBCDIO... no
configure: WARNING: CD Reading and information library not found
checking for VCDINFO... no
configure: WARNING: VCD information library not found
checking for cdrom_msf0 in linux/cdrom.h... yes
checking for scsireq in sys/scsiio.h... no
checking for ioc_toc_header in sys/cdio.h... no
checking for LIBCDDB... no
configure: WARNING: new enough libcddb not found. CDDB access disabled
checking X11/Xlib.h usability... yes
checking X11/Xlib.h presence... yes
checking for X11/Xlib.h... yes
checking for inet_pton... yes
checking for sockaddr_in6 in netinet/in.h... yes
checking ogg/ogg.h usability... no
checking ogg/ogg.h presence... no
checking for ogg/ogg.h... no
checking ebml/EbmlVersion.h usability... no
checking ebml/EbmlVersion.h presence... no
checking for ebml/EbmlVersion.h... no
checking libmodplug/modplug.h usability... no
checking libmodplug/modplug.h presence... no
checking for libmodplug/modplug.h... no
checking mpcdec/mpcdec.h usability... no
checking mpcdec/mpcdec.h presence... no
checking for mpcdec/mpcdec.h... no
checking mad.h usability... no
checking mad.h presence... no
checking for mad.h... no
configure: error: Could not find libmad on your system: you may get it from http://www.underbit.com/products/mad/. Alternatively you can use --disable-mad to disable the mad plugin
yes
not implemented yet
GNU/Linux ld.so
GNU/Linux ld.so
configure: error: Could not find libmad on your system: you may get it from http://www.underbit.com/products/mad/. Alternatively you can use --disable-mad to disable the mad plugin.
TUX:/home/trunksen/Desktop/vlc-0.8.6-rc1 # cd ..
TUX:/home/trunksen/Desktop # cd libmad-0.15.1b/
TUX:/home/trunksen/Desktop/libmad-0.15.1b # ./configure
checking whether to build static libraries... yes
checking for ANSI C header files... (cached) yes
checking for sys/wait.h that is POSIX.1 compatible... yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking whether byte ordering is bigendian... no
checking for pid_t... yes
checking for long long... yes
checking size of long long... 8
checking for waitpid... yes
checking for fcntl... yes
checking for pipe... yes
checking whether to optimize for speed or for accuracy... default
checking for architecture-specific fixed-point math routines... INTEL
checking for ISO/IEC interpretation... best accepted practices
checking whether to enable profiling... no
checking whether to enable debugging... default
checking whether to enable experimental code... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating msvc++/Makefile
config.status: creating libmad.list
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
mfg trunksen
