Problem beim komplimieren von TiLP2
Hi
Ich möchte TiLP2 installieren, ein Programm um Taschenrechner von Texas Intruments anzusprechen.
Leider bin ich an einem Punkt angekommen an dem es nicht mehr weiter geht alle anderen Abhänigkeitsprobleme hab ich allein lösen können, aber jetzt werde ich nicht mehr schlau drauß.
~/Desktop/tilp2-1.03> ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for something to drink while compiling... err: no fridge found!
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for style of include used by make... GNU
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /usr/bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/x86_64-suse-linux/bin/ld
checking if the linker (/usr/x86_64-suse-linux/bin/ld) is GNU ld... yes
checking for /usr/x86_64-suse-linux/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag  works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/x86_64-suse-linux/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/x86_64-suse-linux/bin/ld -m elf_x86_64
checking if the linker (/usr/x86_64-suse-linux/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the g++ linker (/usr/x86_64-suse-linux/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ANSI C... (cached) none needed
checking dependency style of gcc... (cached) gcc3
checking whether make sets $(MAKE)... (cached) yes
checking for library containing strerror... none required
checking for gawk... (cached) gawk
checking for groff... yes
checking whether NLS is requested... yes
checking for msgfmt... /usr/bin/msgfmt
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking whether we are using the GNU C Library 2 or newer... yes
checking for ranlib... (cached) ranlib
checking for an ANSI C-conforming const... yes
checking for signed... yes
checking for inline... inline
checking for off_t... yes
checking for size_t... yes
checking for long long... yes
checking for long double... yes
checking for wchar_t... yes
checking for wint_t... yes
checking for intmax_t... yes
checking whether printf() supports POSIX/XSI format strings... yes
checking for working alloca.h... yes
checking for alloca... yes
checking for stdlib.h... (cached) yes
checking for unistd.h... (cached) yes
checking for getpagesize... yes
checking for working mmap... yes
checking whether we are using the GNU C Library 2.1 or newer... yes
checking whether integer division by zero raises SIGFPE... yes
checking for unsigned long long... yes
checking whether the inttypes.h PRIxNN macros are broken... no
checking for stdint.h... (cached) yes
checking for SIZE_MAX... yes
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for ld used by GCC... /usr/x86_64-suse-linux/bin/ld -m elf_x86_64
checking for shared library run path origin... done
checking for ptrdiff_t... yes
checking argz.h usability... yes
checking argz.h presence... yes
checking for argz.h... yes
checking limits.h usability... yes
checking limits.h presence... yes
checking for limits.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking nl_types.h usability... yes
checking nl_types.h presence... yes
checking for nl_types.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for string.h... (cached) yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for asprintf... yes
checking for fwprintf... yes
checking for getcwd... yes
checking for getegid... yes
checking for geteuid... yes
checking for getgid... yes
checking for getuid... yes
checking for mempcpy... yes
checking for munmap... yes
checking for putenv... yes
checking for setenv... yes
checking for setlocale... yes
checking for snprintf... yes
checking for stpcpy... yes
checking for strcasecmp... yes
checking for strdup... yes
checking for strtoul... yes
checking for tsearch... yes
checking for wcslen... yes
checking for __argz_count... yes
checking for __argz_stringify... yes
checking for __argz_next... yes
checking for __fsetlocking... yes
checking whether _snprintf is declared... no
checking whether _snwprintf is declared... no
checking whether feof_unlocked is declared... yes
checking whether fgets_unlocked is declared... no
checking whether getc_unlocked is declared... yes
checking for iconv... yes
checking for iconv declaration...
         extern size_t iconv (iconv_t cd, char * *inbuf, size_t *inbytesleft, char * *outbuf, size_t *outbytesleft);
checking for nl_langinfo and CODESET... yes
checking for LC_MESSAGES... yes
checking for bison... bison
checking version of bison... 2.3, ok
checking for CFPreferencesCopyAppValue... (cached) no
checking for CFLocaleCopyCurrent... (cached) no
checking whether included gettext is requested... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for TICABLES_CFLAGS... -I/usr/local/include/tilp2 -I/opt/gnome/include/glib-2.0 -I/opt/gnome/lib64/glib-2.0/include
checking for TICABLES_LIBS... -L/usr/local/lib -L/opt/gnome/lib64 -lticables2 -lglib-2.0
checking for TICALCS_CFLAGS... -I/usr/local/include/tilp2 -I/opt/gnome/include/glib-2.0 -I/opt/gnome/lib64/glib-2.0/include
checking for TICALCS_LIBS... -L/usr/local/lib -L/opt/gnome/lib64 -lticalcs2 -lticables2 -ltifiles2 -lticonv -lglib-2.0
checking for TIFILES_CFLAGS... -I/usr/local/include/tilp2 -I/opt/gnome/include/glib-2.0 -I/opt/gnome/lib64/glib-2.0/include
checking for TIFILES_LIBS... -L/usr/local/lib -L/opt/gnome/lib64 -ltifiles2 -lticonv -lglib-2.0
checking for TICONV_CFLAGS... -I/usr/local/include/tilp2 -I/opt/gnome/include/glib-2.0 -I/opt/gnome/lib64/glib-2.0/include
checking for TICONV_LIBS... -L/usr/local/lib -L/opt/gnome/lib64 -lticonv -lglib-2.0
checking for GLIB_CFLAGS... -I/opt/gnome/include/glib-2.0 -I/opt/gnome/lib64/glib-2.0/include
checking for GLIB_LIBS... -L/opt/gnome/lib64 -lglib-2.0
checking for GTK_CFLAGS... -I/usr/include/cairo -I/usr/include/freetype2 -I/usr/include/libpng12 -I/opt/gnome/include/gtk-2.0 -I/opt/gnome/lib64/gtk-2.0/include -I/opt/gnome/include/atk-1.0 -I/opt/gnome/include/pango-1.0 -I/opt/gnome/include/glib-2.0 -I/opt/gnome/lib64/glib-2.0/include
checking for GTK_LIBS... -L/opt/gnome/lib64 -lgtk-x11-2.0 -lgdk-x11-2.0 -latk-1.0 -lgdk_pixbuf-2.0 -lpangocairo-1.0 -lpango-1.0 -lcairo -lgobject-2.0 -lgmodule-2.0 -ldl -lglib-2.0 -lfreetype -lz -lfontconfig -lexpat -lglitz -lm -lpng12 -lXrender -lX11 -lpthread -lXau -lXdmcp
checking for GLADE_CFLAGS...
checking for GLADE_LIBS...
configure: error: Package requirements (libglade-2.0 >= 1.99.0) were not met.
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively you may set the GLADE_CFLAGS and GLADE_LIBS environment variables
to avoid the need to call pkg-config.  See the pkg-config man page for
more details.
Das Paket libglade2 2.6.0-23 ist aber schon installiert!
Jetzt weiss ich nicht was ich machen soll.
Hat jemand einen Tip?:hilfe2:
Mfg
Edit:
Problem gelöst musste das devel Paket noch installieren
Hallo ******,
ich hab erst mal ein paar Fragen.
- Ist das Paket libglade-devel istalliert?
- Wohin ist es installiert
- Ist der Pfad zur libglade.pc in $PKGPATH angegeben?
Viele Grüße,
CEROG
Hi
Das Problem ist schon gelöst ich musste nur das libglade-devel Packet mit Yast nachinstallieren, wohin es installiert wurde weiss ich nicht.
Mfg
configure schlägt bei X fehl
Dovecot: Geteilte Postfächer (Shared Mailboxes) funktionieren nicht
X startet nichtmehr
Nvidia Hybrid-Grafikkarte: 3D Beschleunigung will nicht
