Problem mit 1TB Harddisk
Akendo
Akendo
4k3nd0
Moin Moin liebes UB,
hab zur Zeit furchtbares Problem mit einer mein HDD's. Diese gibt immer Fehlermeldung wie diese aus:
Feb 10 02:31:27 m4s73r kernel: [69742.749271] sd 0:0:0:0: [sda] Add. Sense: Unrecovered read error - auto reallocate failed
Feb 10 02:31:27 m4s73r kernel: [69742.749281] sd 0:0:0:0: [sda] CDB: Read(10): 28 00 13 f9 d4 1d 00 00 02 00
Feb 10 02:31:27 m4s73r kernel: [69742.749355] ata1: EH complete
Feb 10 02:31:30 m4s73r kernel: [69746.172405] ata1.00: configured for UDMA/33
Feb 10 02:31:30 m4s73r kernel: [69746.172426] ata1: EH complete
Feb 10 02:31:33 m4s73r kernel: [69749.105183] ata1.00: configured for UDMA/33
Feb 10 02:31:33 m4s73r kernel: [69749.105210] ata1: EH complete
Feb 10 02:31:36 m4s73r kernel: [69752.048993] ata1.00: configured for UDMA/33
Feb 10 02:31:36 m4s73r kernel: [69752.049020] ata1: EH complete
Feb 10 02:31:39 m4s73r kernel: [69755.128909] ata1.00: configured for UDMA/33
Feb 10 02:31:39 m4s73r kernel: [69755.128941] ata1: EH complete
Feb 10 02:31:42 m4s73r kernel: [69758.068721] ata1.00: configured for UDMA/33
Feb 10 02:31:42 m4s73r kernel: [69758.068745] ata1: EH complete
Feb 10 02:31:45 m4s73r kernel: [69761.148607] ata1.00: configured for UDMA/33
Feb 10 02:31:45 m4s73r kernel: [69761.148639] sd 0:0:0:0: [sda] Unhandled sense code
Feb 10 02:31:45 m4s73r kernel: [69761.148644] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
Feb 10 02:31:45 m4s73r kernel: [69761.148651] sd 0:0:0:0: [sda] Sense Key : Medium Error [current] [descriptor]
Feb 10 02:31:45 m4s73r kernel: [69761.148659] Descriptor sense data with sense descriptors (in hex):
Feb 10 02:31:45 m4s73r kernel: [69761.148663]         72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
Feb 10 02:31:45 m4s73r kernel: [69761.148676]         13 fa 15 65
Feb 10 02:31:45 m4s73r kernel: [69761.148683] sd 0:0:0:0: [sda] Add. Sense: Unrecovered read error - auto reallocate failed
Feb 10 02:31:45 m4s73r kernel: [69761.148693] sd 0:0:0:0: [sda] CDB: Read(10): 28 00 13 fa 14 07 00 02 00 00
Ein FS-Check hat es bisher nicht wirklich gebracht, bin ehrlich gesagt etwas ahnungslos.
Jemand eine Lösung Idee?
FS: ext4
OS: Debian 6 Sequeeze
Kernel: 2.6.30-2-686
MFG 4k3nd0
lass mal smart full check laufen ob nicht die platte einen knacks weg hat.
Kann eigentlich nicht sein, die Platte ist gerade mal 3 Monate alt. Waere recht "schlecht' da die Platte zu 95% voll ist und ich gerade kein Backup-Platte habe. :/
Das hat nichts mit dem Alter zu tun :>
Fehlerhafte Charge oder einfach Pech, oder eben die MTTF überschritten ist.
Smart laufen lassen .... passiert ja nix ... gibt dir ja nur aus ob Fehler auftreten oder nicht.
Dauert aber je nach Größe paar Stunden
Mit welchem Kommando kann ich das denn machen? Bzw. welches Paket muss installiert werden? Reicht kein fsck ? (mit -c/k) ?
nein weil ein fsck nur das Filesystem überprüft :> und nicht die Hadware.
Smart checkt die gesamte HDD-Hardware.
Package: smartmontools
Usage: smartctl --all /dev/sdx
Problem mit SATA
X startet nichtmehr
Mein Server versendet SPAM in Massen
Kernel [unknown ASC/ASCQ]
Rollei Mini Wifi Camcorder
