Problem mit Bluetooth
R
RedShoe
meine Bluetooth Dienste laufen zwar, aber kbtobexclient findet keine Device und keinen Channel um Daten ans Handy zu übertragen.
Distri ist Kanotix 2006 Easter rcd 4
Handy K 700i
Hier mal die hdic.conf mit der Frage wo was u.U. editiert werden müßte. Mir hat mal jemand gesagt beim Handy sollte die local device class geändert werden. Nur wie hat nicht gesagt.
_______________________________________________________________________________________
CI daemon configuration file.
# HCId options
options {
# Automatically initialize new devices
autoinit yes;
# Security Manager mode
# none - Security manager disabled
# auto - Use local PIN for incoming connections
# user - Always ask user for a PIN
security auto;
# Pairing mode
# none - Pairing disabled
# multi - Allow pairing with already paired devices
# once - Pair once and deny successive attempts
pairing multi;
# PIN helper
pin_helper /usr/bin/bluez-pin;
# D-Bus PIN helper
#dbus_pin_helper;
# Default settings for HCI devices
device {
# Local device name
# %d - device id
# %h - host name
name "%h-%d";
# Local device class
class 0x3e0100;
# Default packet type
#pkt_type DH1,DM1,HV1;
# Inquiry and Page scan
iscan enable; pscan enable;
# Default link mode
# none - no specific policy
# accept - always accept incoming connections
# master - become master on incoming connections,
# deny role switch on outgoing connections
lm accept;
# Default link policy
# rswitch - allow role switch
# hold - allow hold mode
# sniff - allow sniff mode
# park - allow park mode
lp rswitch,hold,sniff,park;
# Authentication and Encryption (Security Mode 3)
#auth enable;
#encrypt enable;
Zur Sicherheit auch noch mal die rfcomm.conf (die nach meinem dafürhalten in Ordnung ist:
_________________________________________________________________________________________
# RFCOMM configuration file.
#rfcomm0 {
# Automatically bind the device at startup
# bind yes;
# Bluetooth address of the device
# device 11:22:33:44:55:66;
# RFCOMM channel for the connection
# channel 1;
# Description of the connection
# comment "Example Bluetooth device";
__________________________________________________________________________________________
Schon mal vielen Dank für die Antworten.
Viele Grüße
RedShoe
NGINX bietet intern abgerufene Seiten nur zum Download an, extern geht's
Debian Routing Problem
