C
Cracksoldier
Mitglied
Hi, ich hab ein Problem mit den Desklets von gnome-look.org
und zwar wenn ich sie ausführen will erscheint das:
(Habs verglichen ist bei allen die selbe meldung)
MFG
lo
eth1
ppp0
CachingBackend: Loading instances from cache
Traceback (most recent call last):
File "./NetmonitorScreenlet.py", line 286, in ?
screenlets.session.create_session(NetmonitorScreenlet)
File "/usr/lib/python2.4/site-packages/screenlets/session.py", line 389, in create_session
session = ScreenletSession(classobj)
File "/usr/lib/python2.4/site-packages/screenlets/session.py", line 79, in __init__
self.connect_daemon()
File "/usr/lib/python2.4/site-packages/screenlets/session.py", line 84, in connect_daemon
bus = dbus.SessionBus()
File "/var/lib/python-support/python2.4/dbus/_dbus.py", line 217, in __new__
mainloop=mainloop)
File "/var/lib/python-support/python2.4/dbus/_dbus.py", line 106, in __new__
bus = BusConnection.__new__(subclass, bus_type, mainloop=mainloop)
File "/var/lib/python-support/python2.4/dbus/bus.py", line 125, in __new__
bus = cls._new_for_bus(address_or_type, mainloop=mainloop)
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
MFG
