001
Routinier
Hab da ein Problem mit dem Programm.
Installation alles super,
schnell "et" in die Konsole geprügelt und das hat die Konsole dann ausgespuckt:
Wer was weiß bitte posten.
danke
gruß 001
Kann leider relativ wenig damit anfangen.ET 2.55 linux-i386 May 27 2003
----- FS_Startup -----
Current search path:
/root/.etwolf/etmain
/usr/local/games/enemy-territory/etmain/pak0.pk3 (3725 files)
/usr/local/games/enemy-territory/etmain/mp_bin.pk3 (4 files)
3729 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
------- Input Initialization -------
Joystick is not active.
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
...loading libGL.so.1: Initializing OpenGL display
...setting mode 4: 800 600
Using XFree86-VidModeExtension Version 2.2
XF86DGA Mouse (Version 2.0) initialized
XFree86-VidModeExtension Activated at 800x600
Using 4/4/4 Color bits, 16 depth, 0 stencil display.
Xlib: extension "XFree86-DRI" missing on display ":0.0".
GL_RENDERER: Mesa GLX Indirect
You are using software Mesa (no hardware acceleration)!
Driver DLL used: libGL.so.1
If this is intentional, add
"+set r_allowSoftwareGL 1"
to the command line when starting the game.
...WARNING: could not set the given mode (4)
...setting mode 3: 640 480
XFree86-VidModeExtension Activated at 640x480
Received signal 11, exiting...
danke
gruß 001
