> Warning: Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols
> Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
Could not init font path element /usr/X11R6/lib/X11/fonts/local, removing from list!
Could not init font path element /usr/X11R6/lib/X11/fonts/CID, removing from list!
X Window System Version 6.9.0
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 6.9
Build Operating System: SuSE Linux [ELF] SuSE
Current Operating System: Linux linux-7x2t 2.6.16.21-0.25-default #1 Tue Sep 19 07:26:15 UTC 2006 i686
Build Date: 13 September 2006
Before reporting problems, check
http://wiki.X.Org
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Nov 27 16:39:01 2007
(==) Using config file: "/etc/X11/xorg.conf"
The XKEYBOARD keymap compiler (xkbcomp) reports:
http://wiki.X.Org
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 28 08:55:24 2007
AUDIT: Wed Nov 28 09:07:14 2007: 2859 X: client 15 rejected from local host
SetGrabKeysState - disabled
SetGrabKeysState - enabled
http://wiki.X.Org
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 28 10:07:32 2007
http://wiki.X.Org
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 28 10:11:29 2007
http://wiki.X.Org
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 28 11:37:57 2007
AUDIT: Wed Nov 28 11:38:00 2007: 17788 X: client 2 rejected from local host
http://wiki.X.Org
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 28 11:39:37 2007
http://wiki.X.Org
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 28 11:40:04 2007
http://wiki.X.Org
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 28 11:40:15 2007
http://wiki.X.Org
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Nov 28 11:41:14 2007
