problem mit rsync shell-script
X
xmarcusx
Mitglied
problem mit backup shell-script
hallo! ich habe ein script für meine backups im netz gefunden, jedoch kommt immer die fehlermeldung:
/bin/tar:  invalid option -- ?
ich habe mir das script schon mal selbst angeschaut, aber ich kann den fehler einfach nicht finden!
liegt es vielleicht an dieser variable?
NEWER=""                                # For incremental backups
hier das skript:
#!/bin/sh
# full and incremental backup script
# created 07 February 2000
# Based on a script by Daniel O?Callaghan <d?@freebsd.org>
# and modified by Gerhard Mourani <gmour?@videotron.ca>
# and by Kevin Pfeiffer <kevin-pfeif?@gmx.de> - 16 March 2003
# Filename:                     backup.cron
# Script should live in /etc/cron.daily (for example)
#Change the 6 variables below to fit your computer/backup
COMPUTER=luzifer
# name of this computer
DIRECTORIES="/home/amarhe/download /home/amarhe/Documents"
# directories to backup (separate with spaces)
BACKUPDIR=/home/amarhe/mnt/SUN/Ablage/_Backup/Daten
# where to store the backups
TIMEDIR=$BACKUPDIR/last-full
# where to store date of last full backup
TAR=/bin/tar
# name and location of tar
GZIP=/bin/gzip
# name and location of gzip
#You should not have to change anything below here
umask 026                               # Files should only be readable by root
PATH=/usr/local/bin:/usr/bin:/bin
DOW=`date +%a`                          # Day of the week e.g. Mon
DOM=`date +%d`                          # Date of the Month e.g. 27
DM=`date +%d%b`                         # Date and Month e.g. 27Sep
NOW=`date +%d-%b`                       # Today?s date for date file e.g. 27-Sep
# On the 1st of the month a permanent full backup is made.
# Every Sunday a full backup is made - overwriting last Sunday?s backup.
# The rest of the time an incremental backup is made. Each incremental
# backup overwrites last week?s incremental backup of the same name.
# Check for existence of directories, date file, etc and create any that are missing.
[ -d "$BACKUPDIR" ] || mkdir $BACKUPDIR
[ -d "$TIMEDIR" ] || mkdir $TIMEDIR
[ -r "$TIMEDIR/$COMPUTER-full-date" ] || touch $TIMEDIR/$COMPUTER-full-date
# Monthly full backup
if [ "$DOM" = "01" ]; then
        BACKUP=$BACKUPDIR/$COMPUTER-$DM
        $TAR -cf $BACKUP.tar $DIRECTORIES
        # Compress monthly backup and remove original tar
        $GZIP $BACKUP.tar
fi
# Weekly full backup, compress, and overwrite last Sunday?s
if [ "$DOW" = "Sun" ]; then
        # Update full backup date
        echo $NOW > $TIMEDIR/$COMPUTER-full-date
        BACKUP=$BACKUPDIR/$COMPUTER-$DOW
        # Compress weekly full backup
        $GZIP -f $BACKUP.tar
# Make incremental backup - overwrite last week?s
else
        # Get date of last full backup
        FULLDATE="`cat $TIMEDIR/$COMPUTER-full-date`"
        # Do a full backup if none exists
        if [ -z "$FULLDATE" ]; then
                NEWER=""
        else
                NEWER="?newer $FULLDATE"
        fi
        $TAR $NEWER -cf $BACKUPDIR/$COMPUTER-$DOW.tar $DIRECTORIES
fi
### end of script ###
danke schon mal im voraus!
Wenn du schon mit -N, --newer=DATUM arbeitest, dann muss vor die Variable mit dem gültigen Datum auch die Option -N oder --newer=$NEWER.
Wenn du das ohnehin nicht willst, dann lass es einfach weg.
An welcher Stelle bricht das Script denn ab?
Sorry, hab es nur überflogen.
IMHO ist es auch ratsam die Variablen zu quoten.
Bsp. TIMEDIR="$BACKUPDIR/last-full"
Ein set -x hilft dir beim Debuggen, da es dir die Inhalte der Variablen ausgibt.
Gruß Wolfgang
also die fehlermeldung kommt nicht mehr!
danke.
rsync: Problem - Verzeichnisse mit Suffix umbenennen - nach 2.6.9
