HP-Notebook:/home/linux # dmesg
Linux version 2.6.18.8-0.3-default (geeko@buildhost) (gcc version 4.1.2 20061115 (prerelease) (SUSE Linux)) #1 SMP Tue Apr 17 08:42:35 UTC 2007
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009dc00 (usable)
BIOS-e820: 000000000009dc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000d2000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000003ff00000 (usable)
BIOS-e820: 000000003ff00000 - 000000003ff17000 (ACPI data)
BIOS-e820: 000000003ff17000 - 000000003ff80000 (ACPI NVS)
BIOS-e820: 000000003ff80000 - 0000000040000000 (reserved)
BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
127MB HIGHMEM available.
896MB LOWMEM available.
found SMP MP-table at 000f8960
On node 0 totalpages: 261888
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 225280 pages, LIFO batch:31
HighMem zone: 32512 pages, LIFO batch:7
DMI present.
Using APIC driver default
IO/L-APIC allowed because system is MP or new enough
ACPI: RSDP (v000 HP ) @ 0x000f8930
ACPI: RSDT (v001 HPQOEM SLIC-MPC 0x06040000 LTP 0x00000000) @ 0x3ff0de48
ACPI: FADT (v001 HP MCP51M 0x06040000 PTL_ 0x000f4240) @ 0x3ff16d10
ACPI: SSDT (v001 HP POWERNOW 0x06040000 LTP 0x00000001) @ 0x3ff16d84
ACPI: MCFG (v001 HP MCFG 0x06040000 LTP 0x00000000) @ 0x3ff16f06
ACPI: HPET (v001 PTLTD HPETTBL 0x06040000 LTP 0x00000001) @ 0x3ff16f42
ACPI: MADT (v001 HP APIC 0x06040000 LTP 0x00000000) @ 0x3ff16f7a
ACPI: BOOT (v001 HP $SBFTBL$ 0x06040000 LTP 0x00000001) @ 0x3ff16fd8
ACPI: DSDT (v001 HP MCP51M 0x06040000 MSFT 0x03000000) @ 0x00000000
ACPI: PM-Timer IO Port: 0x1008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 15:8 APIC version 16
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
Processor #1 15:8 APIC version 16
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
ACPI: HPET id: 0x10de8201 base: 0xfed00000
Using ACPI (MADT) for SMP configuration information
Allocating PCI resources starting at 50000000 (gap: 40000000:a0000000)
Detected 1607.397 MHz processor.
Built 1 zonelists. Total pages: 261888
Kernel command line: root=/dev/sda1 vga=0x317 resume=/dev/sda5 splash=silent
bootsplash: silent mode.
mapped APIC to ffffd000 (fee00000)
mapped IOAPIC to ffffc000 (fec00000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 4096 (order: 12, 16384 bytes)
spurious 8259A interrupt: IRQ7.
Console: colour dummy device 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 1031300k/1047552k available (1697k kernel code, 15560k reserved, 972k data, 196k init, 130048k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
hpet0: at MMIO 0xfed00000 (virtual 0xf8800000), IRQs 2, 8, 31
hpet0: 3 32-bit timers, 25000000 Hz
Using HPET for base-timer
Calibrating delay using timer specific routine.. 3217.56 BogoMIPS (lpj=6435129)
Security Framework v1.0.0 initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 178bfbff ebd3fbff 00000000 00000000 00002001 00000000 0000001f
CPU: After vendor identify, caps: 178bfbff ebd3fbff 00000000 00000000 00002001 00000000 0000001f
CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
CPU: L2 Cache: 256K (64 bytes/line)
CPU 0(2) -> Core 0
CPU: After all inits, caps: 178bfbff ebd3fbff 00000000 00000410 00002001 00000000 0000001f
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
checking if image is initramfs... it is
Freeing initrd memory: 3207k freed
ACPI: Core revision 20060707
CPU0: AMD Turion(tm) 64 X2 Mobile Technology TL-50 stepping 02
SMP alternatives: switching to SMP code
Booting processor 1/1 eip 3000
Initializing CPU#1
Calibrating delay using timer specific routine.. 3214.66 BogoMIPS (lpj=6429324)
CPU: L2 Cache: 512K (64 bytes/line)
CPU 1(2) -> Core 1
Intel machine check reporting enabled on CPU#1.
CPU1: AMD Turion(tm) 64 X2 Mobile Technology TL-52 stepping 02
Total of 2 processors activated (6432.22 BogoMIPS).
ENABLING IO-APIC IRQs
..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
checking TSC synchronization across 2 CPUs:
CPU#0 had -469 usecs TSC skew, fixed it up.
CPU#1 had 469 usecs TSC skew, fixed it up.
Brought up 2 CPUs
migration_cost=90
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: Using MMCONFIG
PCI: No mmconfig possible on 0:18
PCI: No mmconfig possible on 7:5
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [\_SB_.PCI0] bus is 0
Boot video device is 0000:05:00.0
PCI: Transparent bridge - 0000:00:10.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: Embedded Controller [EC0] (gpe 16) interrupt mode.
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2P0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.XVR0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.XVR1._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.XVR2._PRT]
ACPI: PCI Interrupt Link [LNK1] (IRQs 5) *0, disabled.
ACPI: PCI Interrupt Link [LNK2] (IRQs 7) *11
ACPI: PCI Interrupt Link [LNK3] (IRQs 10) *11
ACPI: PCI Interrupt Link [LNK4] (IRQs 11) *0, disabled.
ACPI: PCI Interrupt Link [LK1E] (IRQs 16) *11
ACPI: PCI Interrupt Link [LK2E] (IRQs 17) *0, disabled.
ACPI: PCI Interrupt Link [LK3E] (IRQs 18) *0, disabled.
ACPI: PCI Interrupt Link [LK4E] (IRQs 19) *0, disabled.
ACPI: PCI Interrupt Link [LSMB] (IRQs *10)
ACPI: PCI Interrupt Link [LPMU] (IRQs 11) *10
ACPI: PCI Interrupt Link [LUS0] (IRQs 22) *11
ACPI: PCI Interrupt Link [LUS2] (IRQs 22) *7
ACPI: PCI Interrupt Link [LMAC] (IRQs 20) *10
ACPI: PCI Interrupt Link [LAZA] (IRQs 21) *0, disabled.
ACPI: PCI Interrupt Link [LACI] (IRQs 21) *0, disabled.
ACPI: PCI Interrupt Link [LMCI] (IRQs 21) *0, disabled.
ACPI: PCI Interrupt Link [LPID] (IRQs 21) *0, disabled.
ACPI: PCI Interrupt Link [LTID] (IRQs 23) *5
ACPI: PCI Interrupt Link [LSI1] (IRQs 20) *10, disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 13 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
pnp: 00:04: ioport range 0x1000-0x107f could not be reserved
pnp: 00:04: ioport range 0x1080-0x10ff has been reserved
pnp: 00:04: ioport range 0x1400-0x147f has been reserved
pnp: 00:04: ioport range 0x1480-0x14ff could not be reserved
pnp: 00:04: ioport range 0x1800-0x187f has been reserved
pnp: 00:04: ioport range 0x1880-0x18ff has been reserved
pnp: 00:04: ioport range 0x2000-0x203f has been reserved
PCI: Bridge: 0000:00:02.0
IO window: 4000-4fff
MEM window: c4000000-c7ffffff
PREFETCH window: ce200000-ce3fffff
PCI: Bridge: 0000:00:03.0
IO window: disabled.
MEM window: c8000000-cbffffff
PREFETCH window: disabled.
PCI: Failed to allocate mem resource #6:20000@e0000000 for 0000:05:00.0
PCI: Bridge: 0000:00:04.0
MEM window: cc000000-cdffffff
PREFETCH window: d0000000-dfffffff
PCI: Bridge: 0000:00:10.0
MEM window: ce000000-ce0fffff
PCI: Setting latency timer of device 0000:00:02.0 to 64
PCI: Setting latency timer of device 0000:00:03.0 to 64
PCI: Setting latency timer of device 0000:00:04.0 to 64
PCI: Setting latency timer of device 0000:00:10.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
Simple Boot Flag at 0x36 set to 0x1
Machine check exception polling timer started.
apm: BIOS not found.
audit: initializing netlink socket (disabled)
audit(1179241640.860:1): initialized
highmem bounce pool size: 64 pages
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
pcie_portdrv_probe->Dev[02fc:10de] has invalid IRQ. Check vendor BIOS
assign_interrupt_mode Found MSI capability
Allocate Port Service[0000:00:02.0:pcie00]
Allocate Port Service[0000:00:02.0:pcie03]
pcie_portdrv_probe->Dev[02fd:10de] has invalid IRQ. Check vendor BIOS
Allocate Port Service[0000:00:03.0:pcie00]
Allocate Port Service[0000:00:03.0:pcie03]
pcie_portdrv_probe->Dev[02fb:10de] has invalid IRQ. Check vendor BIOS
Allocate Port Service[0000:00:04.0:pcie00]
Allocate Port Service[0000:00:04.0:pcie03]
vesafb: framebuffer at 0xd0000000, mapped to 0xf8880000, using 6144k, total 65536k
vesafb: mode is 1024x768x16, linelength=2048, pages=1
vesafb: protected mode interface info at c000:d5d0
vesafb: pmi: set display start = c00cd606, set palette = c00cd670
vesafb: pmi: ports = 3b4 3b5 3ba 3c0 3c1 3c4 3c5 3c6 3c7 3c8 3c9 3cc 3ce 3cf 3d0 3d1 3d2 3d3 3d4 3d5 3da
vesafb: scrolling: redraw
vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
bootsplash 3.1.6-2004/03/31: looking for picture...<6> silentjpeg size 81749 bytes,<6>...found (1024x768, 46202 bytes, v3).
Console: switching to colour frame buffer device 124x44
fb0: VESA VGA frame buffer device
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Real Time Clock Driver v1.12ac
hpet_resources: 0xfed00000 is busy
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
floppy0: no floppy controllers found
RAMDISK driver initialized: 16 RAM disks of 64000K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:MSE0] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
input: PC Speaker as /class/input/input0
input: AT Translated Set 2 keyboard as /class/input/input1
md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: bitmap version 4.39
Using IPI No-Shortcut mode
ACPI: (supports S0 S3 S4 S5)
Freeing unused kernel memory: 196k freed
Time: hpet clocksource has been installed.
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
SCSI subsystem initialized
ACPI: Thermal Zone [THRM] (56 C)
NFORCE-MCP51: IDE controller at PCI slot 0000:00:0d.0
NFORCE-MCP51: chipset revision 241
NFORCE-MCP51: not 100% native mode: will probe irqs later
NFORCE-MCP51: BIOS didn't set cable bits correctly. Enabling workaround.
NFORCE-MCP51: 0000:00:0d.0 (rev f1) UDMA133 controller
ide0: BM-DMA at 0x3080-0x3087, BIOS settings: hda:DMA, hdb:pio
Probing IDE interface ide0...
Synaptics Touchpad, model: 1, fw: 6.3, id: 0x1a0b1, caps: 0xa04713/0x200000
input: SynPS/2 Synaptics TouchPad as /class/input/input2
hda: HL-DT-ST DVDRAM GSA-4084N, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
libata version 2.00 loaded.
sata_nv 0000:00:0e.0: version 2.0
PCI: Enabling device 0000:00:0e.0 (0005 -> 0007)
ACPI: PCI Interrupt Link [LTID] enabled at IRQ 23
ACPI: PCI Interrupt 0000:00:0e.0[A] -> Link [LTID] -> GSI 23 (level, high) -> IRQ 201
PCI: Setting latency timer of device 0000:00:0e.0 to 64
ata1: SATA max UDMA/133 cmd 0x30C0 ctl 0x30B6 bmdma 0x3090 irq 201
ata2: SATA max UDMA/133 cmd 0x30B8 ctl 0x30B2 bmdma 0x3098 irq 201
scsi0 : sata_nv
ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata1.00: ATA-7, max UDMA/100, 156301488 sectors: LBA48
ata1.00: ata1: dev 0 multi count 16
ata1.00: configured for UDMA/100
scsi1 : sata_nv
ata2: SATA link down (SStatus 0 SControl 300)
ATA: abnormal status 0x7F on port 0x30BF
Vendor: ATA Model: ST98823AS Rev: 7.24
Type: Direct-Access ANSI SCSI revision: 05
SCSI device sda: 156301488 512-byte hdwr sectors (80026 MB)
sda: Write Protect is off
sda: Mode Sense: 00 3a 00 00
SCSI device sda: drive cache: write back
sda: sda1 sda2 < sda5 sda6 >
sd 0:0:0:0: Attached scsi disk sda
sd 0:0:0:0: Attached scsi generic sg0 type 0
BIOS EDD facility v0.16 2004-Jun-25, 1 devices found
Attempting manual resume
kjournald starting. Commit interval 5 seconds
EXT3 FS on sda1, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
usbcore: registered new driver usbfs
usbcore: registered new driver hub
ndiswrapper version 1.25 loaded (preempt=no,smp=yes)
ndiswrapper: driver bcmwl5 (Broadcom,03/23/2006, 4.40.19.0) loaded
ACPI: PCI Interrupt Link [LK4E] enabled at IRQ 19
ACPI: PCI Interrupt 0000:03:00.0[A] -> Link [LK4E] -> GSI 19 (level, high) -> IRQ 209
PCI: Setting latency timer of device 0000:03:00.0 to 64
ndiswrapper: using IRQ 209
wlan0: vendor: ''
wlan0: ethernet device 00:14:a5:ef:64:ad using NDIS driver bcmwl5, 14E4:4311.5.conf
wlan0: encryption modes supported: WEP; TKIP with WPA, WPA2, WPA2PSK; AES/CCMP with WPA, WPA2, WPA2PSK
usbcore: registered new driver ndiswrapper
ohci_hcd: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
ACPI: PCI Interrupt Link [LUS0] enabled at IRQ 22
ACPI: PCI Interrupt 0000:00:0b.0[A] -> Link [LUS0] -> GSI 22 (level, high) -> IRQ 217
PCI: Setting latency timer of device 0000:00:0b.0 to 64
ohci_hcd 0000:00:0b.0: OHCI Host Controller
ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 1
ohci_hcd 0000:00:0b.0: irq 217, io mem 0xc0004000
usb usb1: new device found, idVendor=0000, idProduct=0000
usb usb1: new device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: OHCI Host Controller
usb usb1: Manufacturer: Linux 2.6.18.8-0.3-default ohci_hcd
usb usb1: SerialNumber: 0000:00:0b.0
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 8 ports detected
forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.56.
i2c_adapter i2c-0: nForce2 SMBus adapter at 0x3040
i2c_adapter i2c-1: nForce2 SMBus adapter at 0x3000
ACPI: PCI Interrupt Link [LUS2] enabled at IRQ 22
ACPI: PCI Interrupt 0000:00:0b.1[B] -> Link [LUS2] -> GSI 22 (level, high) -> IRQ 217
PCI: Setting latency timer of device 0000:00:0b.1 to 64
ehci_hcd 0000:00:0b.1: EHCI Host Controller
ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 2
ehci_hcd 0000:00:0b.1: debug port 1
PCI: cache line size of 64 is not supported by device 0000:00:0b.1
ehci_hcd 0000:00:0b.1: irq 217, io mem 0xc0005000
ehci_hcd 0000:00:0b.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb2: new device found, idVendor=0000, idProduct=0000
usb usb2: new device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: EHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.18.8-0.3-default ehci_hcd
usb usb2: SerialNumber: 0000:00:0b.1
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 8 ports detected
hda: ATAPI 24X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache, DMA
Uniform CD-ROM driver Revision: 3.20
ACPI: PCI Interrupt Link [LAZA] enabled at IRQ 21
ACPI: PCI Interrupt 0000:00:10.1[B] -> Link [LAZA] -> GSI 21 (level, high) -> IRQ 225
PCI: Setting latency timer of device 0000:00:10.1 to 64
sdhci: Secure Digital Host Controller Interface driver, 0.12
sdhci: Copyright(c) Pierre Ossman
ieee1394: Initialized config rom entry `ip1394'
Linux agpgart interface v0.101 (c) Dave Jones
usb 2-4: new high speed USB device using ehci_hcd and address 2
usb 2-4: new device found, idVendor=0c45, idProduct=62c0
usb 2-4: new device strings: Mfr=2, Product=1, SerialNumber=3
usb 2-4: Product: USB 2.0 Camera
usb 2-4: Manufacturer: Sonix Technology Co., Ltd.
usb 2-4: SerialNumber: SN0001
usb 2-4: configuration #1 chosen from 1 choice
sdhci: SDHCI controller found at 0000:07:05.1 [1180:0822] (rev 19)
ACPI: PCI Interrupt Link [LNK2] enabled at IRQ 7
ACPI: PCI Interrupt 0000:07:05.1[B] -> Link [LNK2] -> GSI 7 (level, high) -> IRQ 7
mmc0: SDHCI at 0xce000800 irq 7 DMA
ACPI: PCI Interrupt Link [LMAC] enabled at IRQ 20
ACPI: PCI Interrupt 0000:00:14.0[A] -> Link [LMAC] -> GSI 20 (level, high) -> IRQ 233
ohci_hcd 0000:00:0b.0: wakeup
PCI: Setting latency timer of device 0000:00:14.0 to 64
forcedeth: using HIGHDMA
usb 1-6: new low speed USB device using ohci_hcd and address 2
eth0: forcedeth.c: subsystem: 0103c:30b7 bound to 0000:00:14.0
ACPI: PCI Interrupt Link [LNK1] enabled at IRQ 5
ACPI: PCI Interrupt 0000:07:05.0[A] -> Link [LNK1] -> GSI 5 (level, high) -> IRQ 5
usb 1-6: new device found, idVendor=0458, idProduct=0045
usb 1-6: new device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-6: Product: Wireless Navigator
usb 1-6: Manufacturer: Genius
usb 1-6: configuration #1 chosen from 1 choice
ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[5] MMIO=[ce000000-ce0007ff] Max Packet=[2048] IR/IT contexts=[4/4]
ACPI: PCI Interrupt Link [LK1E] enabled at IRQ 16
ACPI: PCI Interrupt 0000:05:00.0[A] -> Link [LK1E] -> GSI 16 (level, high) -> IRQ 50
PCI: Setting latency timer of device 0000:05:00.0 to 64
NVRM: loading NVIDIA UNIX x86 Kernel Module 1.0-9755 Mon Feb 26 23:21:15 PST 2007
usbcore: registered new driver hiddev
input: Genius Wireless Navigator as /class/input/input3
input: USB HID v1.00 Mouse [Genius Wireless Navigator] on usb-0000:00:0b.0-6
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
Adding 4088500k swap on /dev/sda5. Priority:-1 extents:1 across:4088500k
ieee1394: Host added: ID:BUS[0-00:1023] GUID[009fc00080e0b800]
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
loop: loaded (max 8 devices)
EXT3 FS on sda6, internal journal
AppArmor: AppArmor initialized
audit(1179241658.305:2): AppArmor initialized
ACPI: AC Adapter [ACAD] (on-line)
ACPI: Battery Slot [BAT0] (battery present)
ACPI: Power Button (FF) [PWRF]
ACPI: Power Button (CM) [PWRB]
ACPI: Sleep Button (CM) [SLPB]
ACPI: Lid Switch [LID]
powernow-k8: Found 2 AMD Turion(tm) 64 X2 Mobile Technology TL-50 processors (version 2.00.00)
powernow-k8: 0 : fid 0x8 (1600 MHz), vid 0x13
powernow-k8: 1 : fid 0x0 (800 MHz), vid 0x1e
NET: Registered protocol family 17
ISO 9660 Extensions: Microsoft Joliet Level 3
ISO 9660 Extensions: RRIP_1991A
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
ADDRCONF(NETDEV_UP): wlan0: link is not ready
IPv6 over IPv4 tunneling driver
audit(1179241692.651:3): audit_backlog_limit=256 old=64 by auid=4294967295
audit(1179241692.763:4): audit_pid=4870 old=0 by auid=4294967295
bootsplash: status on console 0 changed to on
eth0: no link during initialization.
ADDRCONF(NETDEV_UP): eth0: link is not ready
ip_tables: (C) 2000-2006 Netfilter Core Team
ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
wlan0: no IPv6 routers present
ACPI: PCI interrupt for device 0000:00:14.0 disabled
PCI: Enabling device 0000:00:14.0 (0000 -> 0003)
