Probleme mit Jdownloader
  • Ersteller friendofgermany
  • Erstellt am
F
friendofgermany
Servus an alle Linuxer,
ich hab ein Problem mit dem Jdonloader unter Fedora 12.
und zwar erscheinen beim starten von der Konsole folgende Fehler
[root@FuchsSrv JDownloader]# java -jar JDownloader.jar
------------------------  Thread: 10  -----------------------
10 07.01.10 17:26:30 - INFO [jd.Main(main)] -> Start JDownloader
JAR
10 07.01.10 17:26:30 - FINEST [jd.utils.JDUtilities(getJDClassLoader)] -> Create Classloader: for: /home/Marc/Downloads/JDownloader
10 07.01.10 17:26:30 - FINEST [jd.JDClassLoader(<init>)] -> rootDir:/home/Marc/Downloads/JDownloader
 file:/home/Marc/Downloads/JDownloader/jd
10 07.01.10 17:26:30 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/schedule.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDRemoteControl.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDHJMerge.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDGrowl.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDTray.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDExternInterface.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDWebinterface.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDHTTPLiveHeaderScripter.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDShutdown.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDLangFileEditor.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDPackageCustomizer.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDUnrar.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDInfoFileWriter.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDChat.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/plugins/JDFolderWatch.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Jar file loaded: /home/Marc/Downloads/JDownloader/JDownloader.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaBlueIce.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/synthetica.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaBlackMoon.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaSimple2D.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/substance-swingx.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/substance.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaBlackStar.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaMauveMetallic.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaSkyMetallic.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaBatik.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaBlueSteel.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaGreenDream.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaSilverMoon.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaWhiteVision.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaBlueMoon.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaBlackEye.jar
10 07.01.10 17:26:31 - FINER [jd.JDClassLoader(<init>)] -> Look and Feel JAR loaded: /home/Marc/Downloads/JDownloader/libs/laf/syntheticaOrangeMetallic.jar
10 07.01.10 17:26:31 - FINER [jd.config.DatabaseConnector(<init>)] -> Loading database
Exception in thread "main" java.lang.UnsatisfiedLinkError: /opt/jre1.6.0_17/lib/i386/xawt/libmawt.so: libXext.so.6: cannot open shared object file: No such file or directory
        at java.lang.ClassLoader$NativeLibrary.load(Native Method)
        at java.lang.ClassLoader.loadLibrary0(Unknown Source)
        at java.lang.ClassLoader.loadLibrary(Unknown Source)
        at java.lang.Runtime.load0(Unknown Source)
        at java.lang.System.load(Unknown Source)
        at java.lang.Runtime.loadLibrary0(Unknown Source)
        at java.lang.System.loadLibrary(Unknown Source)
        at sun.security.action.LoadLibraryAction.run(Unknown Source)
        at java.security.AccessController.doPrivileged(Native Method)
        at java.awt.Toolkit.loadLibraries(Unknown Source)
        at java.awt.Toolkit.<clinit>(Unknown Source)
        at java.awt.AWTEvent.<clinit>(Unknown Source)
        at jd.controlling.JDController.fireControlEvent(Unknown Source)
        at jd.controlling.JDLogHandler.publish(Unknown Source)
        at java.util.logging.Logger.log(Unknown Source)
        at java.util.logging.Logger.doLog(Unknown Source)
        at java.util.logging.Logger.finer(Unknown Source)
        at jd.config.DatabaseConnector.<init>(Unknown Source)
        at jd.utils.JDUtilities.getDatabaseConnector(Unknown Source)
        at jd.config.SubConfiguration.<init>(Unknown Source)
        at jd.config.SubConfiguration.getConfig(Unknown Source)
        at jd.gui.swing.jdgui.GUIUtils.getConfig(GUIUtils.java:59)
        at jd.Main.main(Unknown Source)
Ich hab gerade erst mit Linux angefangen und hoffe dieses Problem mit eurer hilfe lösen zu können.
Danke für alle Antworten.
PS: falls ihr noch infos braucht bitte bescheid sagen.
Hallo.
Die interessante Zeile ist
Du musst eine Bibliothek names libmawt nachinstallieren. Allerdings sucht er sie im Verzeichnis des java runtime environments.
Du solltest erst einmal überprüfen ob /opt/jre1.6.0_17/lib/i386/ überhaupt existiert.
Evtl. musst du das JRE installieren, oder ein entsprechendes "xawt" Paket.
Wie die Pakete etc. unter Fedora organisiert sind hab ich nicht parat. Das findest du allerdings in den entsprechenden Online Dokus
Grüße,
MTS
den pfad /opt/jre1.6.0_17/lib/i386/ gibt es die genannten pakete konnte ich bisher nicht finden aber ic suche weiter
ps: auch die Datei libmawt.so existiert im entsprechenden Pfad?!
Natürlich ist die Datei "/opt/jre1.6.0_17/lib/i386/xawt/libmawt.so" da, und jetzt noch mal _genau_ die Fehlermeldung lesen:
[B]libXext.so.6: cannot open shared object file: No such file or directory[/B]
So herum wird ein Schuh draus.
Wieso man als _root_ mit so einem Java-Downloader rumfummelt, hätte ich auch gerne erklärt.
Geht es dann schneller, weil alle anderen Pakete Platz machen, wenn der Chef kommt?
@Rain_Maker ich habs auch mit normalem account aus probiert, da kommt das gleiche.
<Loriot>
Ach?
</Loriot>
Eine Datei fehlt für den Admin und dann fehlt sie komischerweise auch für alle anderen, das ist aber eine Überraschung.
Aber da Multipost bin ich eh aus dieser Nummer raus.
//edit:
Aber den Tipp meiner Glaskugel
- "Architektur prüfen"
und falls Vermutung richtig, dann
- "Multilibs"
lasse ich trotzdem noch da.
X startet nichtmehr
Akonadi startet nicht mehr
Fedora: selinux Berichtungsproblem mit Apache
