N
Nobo
Foren As
wird daraus jemand schlau ich versuche nvidia nforce treiber zu intstallieren wegen sound und so, was ist mach ich flasch! und wo bekomme ich gegebenenfalls die richtigen treiber her. danke schon mal!
Das kommt bei mir in der installation.
MfG Michael
Please select packages for installation:
[*] NVIDIA audio driver for Linux-x86 (1.0-7)
[*] NVIDIA network driver for Linux-x86 (1.0-13)
OK
Please read the following LICENSE and then select either "Accept" to accept
the license and continue with the installation, or select "Do Not Accept" to
abort the installation.
Accept Do Not Accept
License For Customer Use of NVIDIA Software
IMPORTANT NOTICE -- READ CAREFULLY: This License For Customer Use of
NVIDIA Software ("LICENSE") is the agreement which governs use of the
software of NVIDIA Corporation and its subsidiaries ("NVIDIA")
downloadable herefrom, including computer software and associated
printed materials ("SOFTWARE"). By downloading, installing, copying,
or otherwise using the SOFTWARE, you agree to be bound by the terms
of this LICENSE. If you do not agree to the terms of this LICENSE,
do not download the SOFTWARE.
No precompiled kernel interface was found to match your kernel; this means
that the installer will need to compile a new kernel interface.
OK
ERROR: The kernel header file
'/lib/modules/2.6.16.13-4-smp/build/include/linux/kernel.h' does not
exist. The most likely reason for this is that the kernel source
path '/lib/modules/2.6.16.13-4-smp/build' is incorrect. Please make
sure you have installed the kernel source files for your kernel; on
Red Hat Linux systems, for example, be sure you have the
'kernel-source' rpm installed. If you know the correct kernel source
files are installed, you may specify the kernel source path with the
'--kernel-source-path' commandline option.
OK
ERROR: Installation of the audio driver has failed. Please see the file
'/var/log/nvidia-nforce-installer.log' for details. You may find
suggestions on fixing installation problems in the README available
on the Linux driver download page at www.nvidia.com.
OK
OK
OK
ERROR: Installation of the network driver has failed. Please see the file
OK
MfG Michael
OK
OK
OK
OK
OK
OK
OK
