Schlubber
Aurox ,Win XP User
immer wenn ich quake 3 Arena starte bekomme ich den fehler.
OS: Mandriva
Graka: Geforce FX5700
MFG
Schlubber
Q3 1.32b linux-i386 Nov 14 2002
----- FS_Startup -----
Current search path:
/home/aiko/.q3a/baseq3
/usr/local/games/quake3/baseq3/pak8.pk3 (9 files)
/usr/local/games/quake3/baseq3/pak7.pk3 (4 files)
/usr/local/games/quake3/baseq3/pak6.pk3 (64 files)
/usr/local/games/quake3/baseq3/pak5.pk3 (7 files)
/usr/local/games/quake3/baseq3/pak4.pk3 (272 files)
/usr/local/games/quake3/baseq3/pak3.pk3 (4 files)
/usr/local/games/quake3/baseq3/pak2.pk3 (148 files)
/usr/local/games/quake3/baseq3/pak1.pk3 (26 files)
/usr/local/games/quake3/baseq3/pak0.pk3 (3539 files)
./quake3.x86/baseq3
4073 files in pk3 files
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
------- Input Initialization -------
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
...loading libGL.so.1: Initializing OpenGL display
...setting mode 4: 800 600
Using XFree86-VidModeExtension Version 2.2
XF86DGA Mouse (Version 2.0) initialized
XFree86-VidModeExtension Activated at 800x600
Xlib: extension "GLX" missing on display ":0.0".
Couldn't get a visual
...WARNING: could not set the given mode (4)
...setting mode 3: 640 480
XFree86-VidModeExtension Activated at 640x480
...WARNING: could not set the given mode (3)
----- CL_Shutdown -----
RE_Shutdown( 1 )
Sys_Error: GLimp_Init() - could not load OpenGL subsystem
OS: Mandriva
MFG
Schlubber
