Bitte sehr Die Linux Anleitung
Zeig doch mal 'Deine' Anleitung her ....
RAYON PCIPORT
Linux system Installation
1 Driver Installation
• Login with superuser or root.
• Change your directory to root and copy our driver diskette to system.
#cd /
#tar xvf /dev/fd0
• change directory to /etc/rayon and run Install command.
#cd /etc/rayon
#./Install
• You will have following procedure to configure your module.
(1.) choose your card type. (PCIPORT card)
(2.) choose your linux kernel version.
(3.) rebuild your system.
(4.) exit & reboot with new setting.
• Then, you can have extra serial port to be used.
(1.) the device name will be /dev/tty8[1--2][a--h].
(2.) For the card set in first card number (Jumper ON) will be /dev/tty81[a--h].
(3.) For the card set in 2'nd card number (Jumper OFF) will be /dev/tty82[a--h].
