Sarge -> Edge
ChrisMD
ChrisMD
Haudegen
Ja Hallo.
Ach Etch heißt das Ding...
Das ganze Eilt aber niemand kann mir irgendwie helfen also versuch ichs hier nochmal.
Ich möcht einen Rootserver zu dem ich über ssh verbunden bin von Sarge zu Etch updaten.
Das Ding lief jetzt zur Hälfte durch, alle Fragen mit der Standardantwort bejaht.
Dann kam das Ding bei ssh an.
Erstes Problem:
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = "de_DE:de:en_GB:en",
        LC_ALL = (unset),
        LANG = "de_DE@euro"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
Locales hab ich generieren lassen, diese erste Option (exakten Wortlaut vergessen).
Aber das wäre erstmal unwichtig.
In der locale.gen steht de_DE@euro ISO-8859-15. $LANG steht auf de_DE@euro.
Zweites Problem und das was die anderen Updates behindert:
Preconfiguring packages ...
(Reading database ... 35708 files and directories currently installed.)
Unpacking openssh-client (from .../openssh-client_1%3a4.3p2-7_i386.deb) ...
Transferring ownership of conffile /etc/ssh/moduli ...
Transferring ownership of conffile /etc/ssh/ssh_config ...
dpkg: error processing /var/cache/apt/archives/openssh-client_1%3a4.3p2-7_i386.deb (--unpack):
 trying to overwrite `/etc/ssh/ssh_config', which is also in package ssh
Aborting ownership transfer of conffile /etc/ssh/moduli ...
Aborting ownership transfer of conffile /etc/ssh/ssh_config ...
Unpacking openssh-server (from .../openssh-server_1%3a4.3p2-7_i386.deb) ...
        LC_ALL = (unset),
        LANG = "de_DE@euro"
Transferring ownership of conffile /etc/default/ssh ...
Transferring ownership of conffile /etc/init.d/ssh ...
Transferring ownership of conffile /etc/pam.d/ssh ...
dpkg: error processing /var/cache/apt/archives/openssh-server_1%3a4.3p2-7_i386.deb (--unpack):
 trying to overwrite `/etc/init.d/ssh', which is also in package ssh
Aborting ownership transfer of conffile /etc/default/ssh ...
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Aborting ownership transfer of conffile /etc/init.d/ssh ...
Aborting ownership transfer of conffile /etc/pam.d/ssh ...
Errors were encountered while processing:
Und jetzt geht garnichts mehr weiter.
Ich bin mit Debian nicht so befreundet, aber es lief nunmal dort. Eine eigene Distribution installieren lassen kann man nicht. Und hinlaufen und mal die Etch CD einlegen für ne frische Installation ist ja nicht sehr möglich.
Weiß jemand was man da tun könnte?
Poste mal die Datei /etc/locale.gen und /etc//default/locale. Eventuell würde ich mal POSIX eintragen
[COLOR="Red"] trying to overwrite `/etc/ssh/ssh_config', which is also in package ssh[/COLOR]
 [COLOR="Red"]trying to overwrite `/etc/init.d/ssh', which is also in package ssh[/COLOR]
Etch ist halt doch noch nicht ganz stable ;)
Da Du ja auf den SSH-Server angewiesen bist und das alte Paket nicht einfach so kicken kannst ...
Versuch mal
apt-get remove ssh openssh-server+ openssh-client+
und wenn das nicht funktioniert, dann benenn die Files halt um ...
P.S.: Das locale-Problem würde ich ignorieren ... das hat sich bei mir nach dem Upgrade verflüchtigt ...
Das künnte eventuell das Problem lösen. In der /etc/apt/apt.conf Fals die nicht existiert dann anlegen
DPkg::Options{"--force-overwrite"}  ;
Ein Dump der Config sieht dann so aus.
matthias@biljana:~$ apt-config dump
APT "";
APT::Architecture "i386";
APT::Build-Essential "";
APT::Build-Essential:: "build-essential";
APT::Get "";
APT::Get::AllowUnauthenticated "1";
Dir "/";
Dir::State "var/lib/apt/";
Dir::State::lists "lists/";
Dir::State::cdroms "cdroms.list";
Dir::State::userstatus "status.user";
Dir::State::status "/var/lib/dpkg/status";
Dir::Cache "var/cache/apt/";
Dir::Cache::archives "archives/";
Dir::Cache::srcpkgcache "srcpkgcache.bin";
Dir::Cache::pkgcache "pkgcache.bin";
Dir::Etc "etc/apt/";
Dir::Etc::sourcelist "sources.list";
Dir::Etc::sourceparts "sources.list.d";
Dir::Etc::vendorlist "vendors.list";
Dir::Etc::vendorparts "vendors.list.d";
Dir::Etc::main "apt.conf";
Dir::Etc::parts "apt.conf.d";
Dir::Etc::preferences "preferences";
Dir::Bin "";
Dir::Bin::methods "/usr/lib/apt/methods";
Dir::Bin::dpkg "/usr/bin/dpkg";
DPkg "";
DPkg::Pre-Install-Pkgs "";
DPkg::Pre-Install-Pkgs:: "/usr/bin/apt-listchanges --apt || test $? -ne 10";
DPkg::Pre-Install-Pkgs:: "/usr/sbin/dpkg-preconfigure --apt || true";
DPkg::Tools "";
DPkg::Tools::Options "";
DPkg::Tools::Options::/usr/bin/apt-listchanges "";
DPkg::Tools::Options::/usr/bin/apt-listchanges::Version "2";
DPkg::Options "";
DPkg::Options:: "--force-overwrite";
APTITUDE "";
APTITUDE::Install "";
APTITUDE::Install::AllowUnauthenticated "1";
matthias@biljana:~$
Hintergrund ist übrigens die ssh ist in zwei Pakete gespliitet worden openssh-client und openssh-server
http://wiki.debian.org/NewInEtch
Das würde ich haber nur im äußersten Notfall machen, da es schon seinen Grund hat, warum APT/DPKG nicht überschreibt.
dpkg -i --force-overwrite /var/cache/apt/archive/openssh-server /var/cache/apt/archive/openssh-client
hätte den gleichen Effekt, aber halt nur für die 2 Pakete. Aber ich bin mir nicht ganz sicher, ob ein anschließendes entfernen des alten ssh-Pakete nicht ein kaputtes System hinterläßt ...
Ich hatte ein ähnliches Problem beim Update meines Kubuntu von 6.06 auf 6.10. Genauen Wortlaut weiss ich nicht mehr, aber ich habe einfach nach dem ersten Abbruch ein
apt-get -f install
eingeschoben. Das Problem hat sich in Luft aufgelöst, ohne Handarbeit.
Nutzt nur nix wenn er wegen einer Overwrite Warnung stehen bleibt. Dann braucht man schon mal den Holzhammer.
Ja Hallo.
Nö, brauch man nicht ... sieht Post 3
Versuch mal
Bei einem Rootserver halte ich das nicht für eine gute Idee. Da er sperrt sich doch selber aus.
Ja das tut man aber anscheinend schon ohne das ganze...
Naja es hat sich jetzt dahingehend geklärt als das der ssh down ist. Das ist aber dann direkt ne gute Gelegenheit die Typen wieder zu SuSE wechseln zu lassen. Beides ist nicht mein Favorit aber da die weder ein aktuelles SuSE haben noch ein aktuelles Debian ist das SuSE dann doch noch das geringere Übel.
Ich werde dort aber nicht mehr updaten.
Lass ich alles veralten, schreib Configs nurnoch lokal damit ich nen ordentlichen Editor hab (Vim 7 is in den 10.0er Repos ja nicht drin bei SuSE) und dann wirds gut.
Holzhammermethode ala remove hab ich nicht benutzt, trotzdem ist der ssh nicht mehr erreichbar gewesen.
Nochmal zerhauen will ich in den nächsten Tagen nicht. Der Admin von denen wird noch verrückt wenn er jeden Tag ein neues Supportticket von uns findet.
So in 1-2 Wochen dann nochmal mit dem Update probieren... :D
Da passiert ... gar nix. Solang Du die aktuelle SSH-Session nicht "vorzeitig" beendest (was ChrisMD ja leider getan hat), passiert da überhaupt nix, da im gleichen Atemzug wie die Deinstall läuft, auch der neue SSH-Server installiert wird ...
Und nein, dass ist nicht nur Theorie!
Deinstalliert war er ja nich deshalb bin ich davon ausgegangen das er weiter läuft. Schlimmes Zeug...
Naja ... mehr oder weniger schon.
In Etch gibt es statt dem ssh-Paket die 2 openssh-Pakete.
Was ist also passiert?
Während dem dist-upgrade hat der das alte ssh-Paket entfernt und ersetzt es duch das "neue" ssh-Paket, was aber eigentlich keinen Inhalt hat, sondern durch Abhängigkeiten nur dafür sorgt, dass die openssh-Pakete mitinstalliert werden (Metapaket).
Dummerweise ist die Paketbeschreibung des neuen ssh-Paketes nicht korrekt (gibts da schon nen Bug-Report?), so dass APT beim Austausch der Pakete an einigen Dateien scheitert.
Ergebnis: Zu dem Zeitpunkt ist kein ssh mehr installiert, sondern nur noch Reste des alten Paketes und das neue Meta-Paket.
Die aktuelle SSH-Session steht aber noch, da sich die daür benötigten Programmteile noch im Speicher befinden. Nur ein Neuanmelden klappt halt nicht.
P.S.: Bug-Report ist raus ...
Deutsche Tastatur in Debian Wheezy einstellen
Ich mag Dovecot nicht ...
X startet nichtmehr
