M
MaierCH
Hallo Leute,
derzeit habe ich Probleme mit eine OpenSuse System.
Ich habe nicht die Möglichkeit in das X Window zu springen.
anbei die Fehlermeldung.
This is a pre-release version of the X server from The X.Org Foundation.
It is not supported in any way.
Bugs may be filed in the bugzilla at http://bugs.freedesktop.org/.
Select the "xorg" product for bugs you find in this release.
Before reporting bugs in pre-release versions please check the
latest version in the X.Org Foundation git repository.
See http://wiki.x.org/wiki/GitPage for git access instructions.
X Window System Version 7.1.99.902 (7.2.0 RC 2)
Release Date: 13 November 2006
X Protocol Version 11, Revision 0, Release 7.1.99.902
Build Operating System: openSUSE SUSE LINUX
Current Operating System: Linux NagiosSrv 2.6.18.2-34-default #1 SMP Mon Nov 27 11:46:27 UTC 2006 i686
Build Date: 28 November 2006
Before reporting problems, check http://wiki.x.org
Module Loader present
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Feb 25 17:35:34 2008
(==) Using config file: "/etc/X11/xorg.conf"
(EE) AIGLX: DRI module not loaded
expected keysym, got XF86AudioEject: line 2232 of inet
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Type "ONE_LEVEL" has 1 levels, but <RALT> has 2 symbols
> Ignoring extra symbols
Errors from xkbcomp are not fatal to the X server
Could not init font path element /usr/share/fonts/Speedo, removing from list!
Could not init font path element unix/:7100, removing from list!
/etc/X11/xim: Checking wether an input method should be started.
INPUT_METHOD is not set or empty (no user selected input method).
Trying to start a default input method for the locale de_DE.UTF-8 ...
There is no default input method for the current locale.
/usr/bin/fvwm2: /usr/local/lib/libpng12.so.0: no version information available (required by /usr/bin/fvwm2)
FvwmTheme is obsolete, see the Colorset section of the fvwm(1) man page
Cannot parse color "dtcolor5"
couldn't create gradient
/usr/bin/fvwm2: symbol lookup error: /usr/lib/libXft.so.2: undefined symbol: FT_Library_SetLcdFilter
hoffe irgent jemand kann mir da helfen !!
Danke
MaierCH
Danke
MaierCH
