obec
Foren As
habe einen USB WLAn Stick mit Railinkchipsatz.
Bei der Installation des Treibers von dieser Website:http://www.ralinktech.com/drivers/Linux/RT73_Linux_STA_Drv1.0.3.6.tar.gz
kamen bei dem Befehl
make
folgende Problem auf:
Hier die Konsolenausgaben:
linux:/home/knex/bin/HAMA/RT73_Linux_STA_Drv1.0.3.6/Module # make
cc -D__KERNEL__ -I/usr/src/linux-2.4.18-3/include -O2 -fomit-frame-pointer -fno-strict-aliasing -fno-common -pipe -mpreferred-stack-boundary=2 -march=i686 -DMODULE -DMODVERSIONS -include /usr/src/linux-2.4.18-3/include/linux/modversions.h -Wall -Wstrict-prototypes -Wno-trigraphs -c -o rtmp_main.o rtmp_main.c
cc1: error: /usr/src/linux-2.4.18-3/include/linux/modversions.h: Datei oder Verzeichnis nicht gefunden
In file included from /usr/include/asm/percpu.h:4,
from /usr/include/asm/processor.h:24,
from /usr/include/asm/thread_info.h:17,
from /usr/include/linux/thread_info.h:21,
from /usr/include/linux/preempt.h:10,
from /usr/include/linux/spinlock.h:52,
from /usr/include/linux/capability.h:45,
from /usr/include/linux/sched.h:7,
from /usr/include/linux/module.h:10,
from rt_config.h:63,
from rtmp_main.c:40:
/usr/include/asm-generic/percpu.h:8: error: ‘CONFIG_NR_CPUS’ undeclared here (not in a function)
In file included from /usr/include/linux/sched.h:12,
/usr/include/linux/jiffies.h:33:3: error: #error You lose.
/usr/include/linux/jiffies.h:204:31: error: division by zero in #if
/usr/include/linux/jiffies.h:248:46: error: division by zero in #if
/usr/include/linux/jiffies.h: In function ‘jiffies_to_msecs’:
/usr/include/linux/jiffies.h:253: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/include/linux/jiffies.h:253: error: (Each undeclared identifier is reported only once
/usr/include/linux/jiffies.h:253: error: for each function it appears in.)
/usr/include/linux/jiffies.h:259:46: error: division by zero in #if
/usr/include/linux/jiffies.h: In function ‘jiffies_to_usecs’:
/usr/include/linux/jiffies.h:264: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/include/linux/jiffies.h:272:46: error: division by zero in #if
/usr/include/linux/jiffies.h: In function ‘msecs_to_jiffies’:
/usr/include/linux/jiffies.h:277: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/include/linux/jiffies.h:285:46: error: division by zero in #if
/usr/include/linux/jiffies.h: In function ‘usecs_to_jiffies’:
/usr/include/linux/jiffies.h:290: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/include/linux/jiffies.h: In function ‘timespec_to_jiffies’:
/usr/include/linux/jiffies.h:309: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/include/linux/jiffies.h:315: error: ‘SHIFT_HZ’ undeclared (first use in this function)
/usr/include/linux/jiffies.h: In function ‘jiffies_to_timespec’:
/usr/include/linux/jiffies.h:328: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/include/linux/jiffies.h: In function ‘timeval_to_jiffies’:
/usr/include/linux/jiffies.h:350: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/include/linux/jiffies.h:354: error: ‘SHIFT_HZ’ undeclared (first use in this function)
/usr/include/linux/jiffies.h: In function ‘jiffies_to_timeval’:
/usr/include/linux/jiffies.h:366: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/include/linux/jiffies.h:379:6: error: division by zero in #if
/usr/include/linux/jiffies.h: In function ‘jiffies_to_clock_t’:
/usr/include/linux/jiffies.h:380: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/include/linux/jiffies.h: In function ‘clock_t_to_jiffies’:
/usr/include/linux/jiffies.h:391: error: ‘CONFIG_HZ’ undeclared (first use in this function)
/usr/include/linux/jiffies.h:410:6: error: division by zero in #if
/usr/include/linux/jiffies.h: In function ‘jiffies_64_to_clock_t’:
/usr/include/linux/jiffies.h:411: error: ‘CONFIG_HZ’ undeclared (first use in this function)
In file included from /usr/include/linux/list.h:7,
from /usr/include/linux/wait.h:23,
from /usr/include/asm/semaphore.h:41,
from /usr/include/linux/sched.h:20,
/usr/include/linux/prefetch.h: In function ‘prefetch_range’:
/usr/include/linux/prefetch.h:64: error: ‘CONFIG_X86_L1_CACHE_SHIFT’ undeclared (first use in this function)
In file included from /usr/include/linux/rwsem.h:27,
from /usr/include/asm/semaphore.h:42,
/usr/include/asm/rwsem.h: In function ‘__down_read’:
/usr/include/asm/rwsem.h:105: error: expected ‘:’ or ‘)’ before ‘KBUILD_BASENAME’
/usr/include/asm/rwsem.h: In function ‘__down_write’:
/usr/include/asm/rwsem.h:157: error: expected ‘:’ or ‘)’ before ‘KBUILD_BASENAME’
/usr/include/asm/rwsem.h: In function ‘__up_read’:
/usr/include/asm/rwsem.h:194: error: expected ‘:’ or ‘)’ before ‘KBUILD_BASENAME’
/usr/include/asm/rwsem.h: In function ‘__up_write’:
/usr/include/asm/rwsem.h:220: error: expected ‘:’ or ‘)’ before ‘KBUILD_BASENAME’
/usr/include/asm/rwsem.h: In function ‘__downgrade_write’:
/usr/include/asm/rwsem.h:245: error: expected ‘:’ or ‘)’ before ‘KBUILD_BASENAME’
In file included from /usr/include/linux/sched.h:20,
/usr/include/asm/semaphore.h: In function ‘down’:
/usr/include/asm/semaphore.h:105: error: expected ‘:’ or ‘)’ before ‘KBUILD_BASENAME’
/usr/include/asm/semaphore.h: In function ‘down_interruptible’:
/usr/include/asm/semaphore.h:130: error: expected ‘:’ or ‘)’ before ‘KBUILD_BASENAME’
/usr/include/asm/semaphore.h: In function ‘down_trylock’:
/usr/include/asm/semaphore.h:155: error: expected ‘:’ or ‘)’ before ‘KBUILD_BASENAME’
/usr/include/asm/semaphore.h: In function ‘up’:
/usr/include/asm/semaphore.h:179: error: expected ‘:’ or ‘)’ before ‘KBUILD_BASENAME’
In file included from /usr/include/linux/gfp.h:4,
from /usr/include/linux/slab.h:15,
from /usr/include/linux/percpu.h:5,
from /usr/include/linux/sched.h:34,
/usr/include/linux/mmzone.h: At top level:
/usr/include/linux/mmzone.h:41: error: ‘CONFIG_X86_L1_CACHE_SHIFT’ undeclared here (not in a function)
/usr/include/linux/mmzone.h:41: error: requested alignment is not a constant
/usr/include/linux/mmzone.h:64: error: requested alignment is not a constant
/usr/include/linux/mmzone.h:249: error: requested alignment is not a constant
In file included from /usr/include/linux/sched.h:37,
/usr/include/linux/rcupdate.h:69: error: requested alignment is not a constant
/usr/include/linux/rcupdate.h:72: error: requested alignment is not a constant
In file included from /usr/include/linux/module.h:23,
/usr/include/asm/module.h:62:2: error: #error unknown processor family
In file included from rt_config.h:64,
/usr/include/linux/version.h:2:2: error: #error "======================================================="
/usr/include/linux/version.h:3:2: error: #error "You should not include /usr/include/{linux,asm}/ header"
/usr/include/linux/version.h:4:2: error: #error "files directly for the compilation of kernel modules."
/usr/include/linux/version.h:5:2: error: #error ""
/usr/include/linux/version.h:6:2: error: #error "glibc now uses kernel header files from a well-defined"
/usr/include/linux/version.h:7:2: error: #error "working kernel version (as recommended by Linus Torvalds)"
/usr/include/linux/version.h:8:2: error: #error "These files are glibc internal and may not match the"
/usr/include/linux/version.h:9:2: error: #error "currently running kernel. They should only be"
/usr/include/linux/version.h:10:2: error: #error "included via other system header files - user space"
/usr/include/linux/version.h:11:2: error: #error "programs should not directly include <linux/*.h> or"
/usr/include/linux/version.h:12:2: error: #error "<asm/*.h> as well."
/usr/include/linux/version.h:13:2: error: #error ""
/usr/include/linux/version.h:14:2: error: #error "To build kernel modules please do the following:"
/usr/include/linux/version.h:15:2: error: #error ""
/usr/include/linux/version.h:16:2: error: #error " o Have the kernel sources installed"
/usr/include/linux/version.h:17:2: error: #error ""
/usr/include/linux/version.h:18:2: error: #error " o Make sure that the symbolic link"
/usr/include/linux/version.h:19:2: error: #error " /lib/modules/`uname -r`/build exists and points to"
/usr/include/linux/version.h:20:2: error: #error " the matching kernel source directory"
/usr/include/linux/version.h:21:2: error: #error ""
/usr/include/linux/version.h:22:2: error: #error " o Configure kernel sources:"
/usr/include/linux/version.h:23:2: error: #error " - cd /usr/src/linux"
/usr/include/linux/version.h:24:2: error: #error " - make mrproper"
/usr/include/linux/version.h:25:2: error: #error " - make cloneconfig"
/usr/include/linux/version.h:26:2: error: #error " - make dep"
/usr/include/linux/version.h:27:2: error: #error ""
/usr/include/linux/version.h:28:2: error: #error " o When compiling, make sure to use the following"
/usr/include/linux/version.h:29:2: error: #error " compiler option to use the correct include files:"
/usr/include/linux/version.h:30:2: error: #error ""
/usr/include/linux/version.h:31:2: error: #error " -I/lib/modules/`uname -r`/build/include"
/usr/include/linux/version.h:32:2: error: #error ""
/usr/include/linux/version.h:33:2: error: #error " instead of"
/usr/include/linux/version.h:34:2: error: #error ""
/usr/include/linux/version.h:35:2: error: #error " -I/usr/include/linux"
/usr/include/linux/version.h:36:2: error: #error ""
/usr/include/linux/version.h:37:2: error: #error " Please adjust the Makefile accordingly."
/usr/include/linux/version.h:38:2: error: #error "======================================================="
In file included from /usr/include/asm/fixmap.h:27,
from /usr/include/asm/pgtable.h:17,
from /usr/include/linux/mm.h:38,
from /usr/include/asm/pci.h:7,
from /usr/include/linux/pci.h:650,
from rt_config.h:73,
/usr/include/asm/acpi.h:31:28: error: acpi/pdc_intel.h: Datei oder Verzeichnis nicht gefunden
In file included from /usr/include/asm/pci.h:7,
/usr/include/linux/mm.h: In function ‘lowmem_page_address’:
/usr/include/linux/mm.h:517: error: ‘CONFIG_PAGE_OFFSET’ undeclared (first use in this function)
In file included from /usr/include/asm/pci.h:42,
/usr/include/asm/io.h: In function ‘virt_to_phys’:
/usr/include/asm/io.h:78: error: ‘CONFIG_PAGE_OFFSET’ undeclared (first use in this function)
/usr/include/asm/io.h: In function ‘phys_to_virt’:
/usr/include/asm/io.h:96: error: ‘CONFIG_PAGE_OFFSET’ undeclared (first use in this function)
In file included from /usr/include/linux/if_ether.h:110,
from /usr/include/linux/netdevice.h:29,
from rt_config.h:74,
/usr/include/linux/skbuff.h:31:26: error: net/checksum.h: Datei oder Verzeichnis nicht gefunden
In file included from rt_config.h:74,
/usr/include/linux/netdevice.h: At top level:
/usr/include/linux/netdevice.h:374: error: requested alignment is not a constant
/usr/include/linux/netdevice.h:391: error: requested alignment is not a constant
/usr/include/linux/netdevice.h:405: error: requested alignment is not a constant
/usr/include/linux/netdevice.h:423: error: requested alignment is not a constant
In file included from /usr/include/linux/irq.h:22,
from /usr/include/asm/hardirq.h:6,
from /usr/include/linux/hardirq.h:7,
from /usr/include/linux/interrupt.h:11,
from /usr/include/linux/netdevice.h:534,
/usr/include/asm/irq.h:16:25: error: irq_vectors.h: Datei oder Verzeichnis nicht gefunden
In file included from /usr/include/asm/hardirq.h:6,
/usr/include/linux/irq.h:83: error: requested alignment is not a constant
/usr/include/linux/irq.h:85: error: ‘NR_IRQS’ undeclared here (not in a function)
In file included from /usr/include/linux/irq.h:94,
/usr/include/asm/hw_irq.h:30: error: ‘NR_IRQ_VECTORS’ undeclared here (not in a function)
In file included from /usr/include/linux/hardirq.h:7,
/usr/include/asm/hardirq.h:13: error: requested alignment is not a constant
In file included from rtmp_main.c:40:
rt_config.h:99:34: error: asm-i386/atomic.h: Datei oder Verzeichnis nicht gefunden
In file included from rt_config.h:189,
rtmp.h:110:41: error: missing binary operator before token "("
rtmp.h:2756:40: error: missing binary operator before token "("
rtmp_main.c:89: warning: initialization from incompatible pointer type
rtmp_main.c:90: warning: initialization from incompatible pointer type
rtmp_main.c: In function ‘MlmeThread’:
rtmp_main.c:1565: error: too few arguments to function ‘daemonize’
rtmp_main.c: In function ‘RTUSBCmdThread’:
rtmp_main.c:1633: error: too few arguments to function ‘daemonize’
rtmp_main.c: In function ‘usb_rtusb_probe’:
rtmp_main.c:1703: error: ‘MOD_DEC_USE_COUNT’ undeclared (first use in this function)
rtmp_main.c:1704: warning: implicit declaration of function ‘usb_dec_dev_use’
rtmp_main.c:1711: warning: assignment from incompatible pointer type
rtmp_main.c:1737: warning: initialization from incompatible pointer type
rtmp_main.c:1768: error: ‘struct usb_interface’ has no member named ‘act_altsetting’
rtmp_main.c:1769: error: ‘struct usb_interface_descriptor’ has no member named ‘endpoint’
rtmp_main.c: In function ‘usb_rtusb_disconnect’:
rtmp_main.c:1816: error: ‘MOD_IN_USE’ undeclared (first use in this function)
rtmp_main.c:1817: error: ‘MOD_DEC_USE_COUNT’ undeclared (first use in this function)
make: *** [rtmp_main.o] Fehler 1
kernel-sources und make, gcc sind installiert.
Ich glaub ich hab noch nie so viele Probleme auf einmal gesehen.
Wäre dankbar für Hilfe
obec
make
obec
