Linux version 2.6.18-4-686 (Debian 2.6.18.dfsg.1-12etch2) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Wed May 9 23:03:12 UTC 2007
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000007fd0000 (usable)
BIOS-e820: 0000000007fd0000 - 0000000007fdf000 (ACPI data)
BIOS-e820: 0000000007fdf000 - 0000000007fe0000 (ACPI NVS)
BIOS-e820: 0000000007fe0000 - 0000000008000000 (reserved)
BIOS-e820: 00000000fffe0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
127MB LOWMEM available.
On node 0 totalpages: 32720
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 28624 pages, LIFO batch:7
DMI 2.0 present.
ACPI: RSDP (v000 IBM ) @ 0x000fd6e0
ACPI: RSDT (v001 IBM TP560Z 0x00000001 0x00000000) @ 0x07fd0000
ACPI: FADT (v001 IBM TP560Z 0x00000001 0x00000000) @ 0x07fd0100
ACPI: BOOT (v001 IBM TP560Z 0x00000001 0x00000000) @ 0x07fd0040
ACPI: DSDT (v001 IBM TP560Z 0x0000000a MSFT 0x0100000a) @ 0x00000000
ACPI: PM-Timer IO Port: 0xef08
Allocating PCI resources starting at 10000000 (gap: 08000000:f7fe0000)
Detected 232.074 MHz processor.
Built 1 zonelists. Total pages: 32720
Kernel command line: root=/dev/hda1 ro
Local APIC disabled by BIOS -- you can enable it with "lapic"
mapped APIC to ffffd000 (01109000)
Enabling fast FPU save and restore... done.
Initializing CPU#0
PID hash table entries: 512 (order: 9, 2048 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 121788k/130880k available (1544k kernel code, 8556k reserved, 577k data, 196k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 200.21 BogoMIPS (lpj=400434)
Security Framework v1.0.0 initialized
SELinux: Disabled at boot.
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0183f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: After vendor identify, caps: 0183f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 512K
CPU: After all inits, caps: 0183f9ff 00000000 00000000 00000040 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 16k freed
ACPI: Core revision 20060707
ACPI: setting ELCR to 0200 (from 0800)
CPU0: Intel Pentium II (Deschutes) stepping 02
SMP motherboard not detected.
Local APIC not detected. Using dummy APIC emulation.
Brought up 1 CPUs
migration_cost=0
checking if image is initramfs... it is
Freeing initrd memory: 4746k freed
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfd880, last bus=0
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [\_SB_.PCI0] bus is 0
Boot video device is 0000:00:03.0
* Found PM-Timer Bug on the chipset. Due to workarounds for a bug,
* this clock source is slow. Consider trying other clock sources
PCI quirk: region ef00-ef3f claimed by PIIX4 ACPI
PCI quirk: region efa0-efaf claimed by PIIX4 SMB
PIIX4 devres I PIO at 002e-002f
PIIX4 devres J PIO at 15e8-15ef
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: Power Resource [PSIO] (on)
ACPI: Embedded Controller [EC0] (gpe 9) interrupt mode.
ACPI: Power Resource [PFN0] (off)
ACPI: Power Resource [PFN1] (off)
ACPI: Power Resource [PVID] (on)
ACPI: Power Resource [PRSD] (off)
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 17 devices
PnPBIOS: Disabled by ACPI PNP
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
pnp: 00:0c: ioport range 0x15e0-0x15ef has been reserved
pnp: 00:0c: ioport range 0xef00-0xef3f could not be reserved
pnp: 00:0c: ioport range 0xefa0-0xefaf has been reserved
PCI: Ignore bogus resource 6 [0:0] of 0000:00:03.0
PCI: Bus 1, cardbus bridge: 0000:00:02.0
IO window: 00001000-000010ff
IO window: 00001400-000014ff
PREFETCH window: 10000000-11ffffff
MEM window: 12000000-13ffffff
PCI: Bus 5, cardbus bridge: 0000:00:02.1
IO window: 00001800-000018ff
IO window: 00001c00-00001cff
PREFETCH window: 14000000-15ffffff
MEM window: 16000000-17ffffff
ACPI: PCI Interrupt Link [LNKA] disabled and referenced, BIOS bug
ACPI: PCI Interrupt Link [LNKA] BIOS reported IRQ 0, using IRQ 10
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 10
PCI: setting IRQ 10 as level-triggered
ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LNKA] -> GSI 10 (level, low) -> IRQ 10
ACPI: PCI Interrupt Link [LNKB] disabled and referenced, BIOS bug
ACPI: PCI Interrupt Link [LNKB] BIOS reported IRQ 0, using IRQ 11
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 2048)
TCP reno registered
Simple Boot Flag at 0x33 set to 0x1
audit: initializing netlink socket (disabled)
audit(1190802951.936:1): initialized
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Limiting direct PCI/PCI transfers.
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
pnp: Device 00:03 activated.
00:03: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
PNP: PS/2 Controller [PNP0303:KBD0,PNP0f13:MOU0] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
Using IPI No-Shortcut mode
ACPI: (supports S0 S1 S2<6>Time: tsc clocksource has been installed.
S3 S4 S5)
Freeing unused kernel memory: 196k freed
input: AT Translated Set 2 keyboard as /class/input/input0
ACPI: Transitioning device [FN00] to D3
ACPI: Fan [FN00] (off)
ACPI: Transitioning device [FN01] to D3
ACPI: Fan [FN01] (off)
ACPI: Transitioning device [FN60] to D3
ACPI: Fan [FN60] (off)
ACPI: Transitioning device [FN61] to D3
ACPI: Fan [FN61] (off)
ACPI: CPU0 (power states: C1[C1] C2[C2])
ACPI: Processor [CPU0] (supports 8 throttling states)
ACPI: Thermal Zone [THM0] (30 C)
ACPI: Thermal Zone [THM6] (26 C)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
PIIX4: IDE controller at PCI slot 0000:00:06.1
PIIX4: chipset revision 1
PIIX4: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xfcf0-0xfcf7, BIOS settings: hda:DMA, hdb:pio
Probing IDE interface ide0...
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v3.0
hda: IBM-DJSA-210, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
ACPI: PCI Interrupt Link [LNKD] disabled and referenced, BIOS bug
ACPI: PCI Interrupt Link [LNKD] BIOS reported IRQ 0, using IRQ 10
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 10
ACPI: PCI Interrupt 0000:00:06.2[D] -> Link [LNKD] -> GSI 10 (level, low) -> IRQ 10
uhci_hcd 0000:00:06.2: UHCI Host Controller
uhci_hcd 0000:00:06.2: new USB bus registered, assigned bus number 1
irq 10: nobody cared (try booting with the "irqpoll" option)
[<c0140353>] __report_bad_irq+0x2b/0x69
[<c0140540>] note_interrupt+0x1af/0x1e7
[<c013fb4b>] handle_IRQ_event+0x17/0x49
[<c013fb57>] handle_IRQ_event+0x23/0x49
[<c013fc30>] __do_IRQ+0xb3/0xe8
[<c01050e5>] do_IRQ+0x43/0x52
[<c01036b6>] common_interrupt+0x1a/0x20
[<c012182f>] __do_softirq+0x51/0xbb
[<c01218cf>] do_softirq+0x36/0x3a
[<c01050ea>] do_IRQ+0x48/0x52
[<c0281470>] _spin_unlock_irqrestore+0x8/0x9
[<c01401b0>] setup_irq+0x12b/0x184
[<c889747b>] usb_hcd_irq+0x0/0x50 [usbcore]
[<c0140285>] request_irq+0x7c/0x98
[<c889714e>] usb_add_hcd+0x240/0x4dc [usbcore]
[<c889e2ad>] usb_hcd_pci_probe+0x1d9/0x260 [usbcore]
[<c0210b68>] __driver_attach+0x0/0x5d
[<c01c18a8>] pci_device_probe+0x36/0x57
[<c0210ac9>] driver_probe_device+0x42/0x8b
[<c0210ba0>] __driver_attach+0x38/0x5d
[<c02105ea>] bus_for_each_dev+0x33/0x55
[<c0210a33>] driver_attach+0x11/0x13
[<c0210303>] bus_add_driver+0x64/0xfd
[<c01c19e4>] __pci_register_driver+0x47/0x63
[<c881f04e>] uhci_hcd_init+0x4e/0x8b [uhci_hcd]
[<c01358c1>] sys_init_module+0x16c3/0x1846
[<c0161b4c>] cp_new_stat64+0xfd/0x10f
[<c0102c7b>] syscall_call+0x7/0xb
handlers:
[<c889747b>] (usb_hcd_irq+0x0/0x50 [usbcore])
Disabling IRQ #10
uhci_hcd 0000:00:06.2: irq 10, io base 0x00008000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
hda: max request size: 128KiB
hda: 19640880 sectors (10056 MB) w/384KiB Cache, CHS=19485/16/63, UDMA(33)
hda: cache flushes not supported
hda: hda1 hda2 hda3
Time: acpi_pm clocksource has been installed.
Attempting manual resume
ACPI: PCI Interrupt 0000:00:03.0[A] -> Link [LNKA] -> GSI 10 (level, low) -> IRQ 10
neofb: mapped io at c8900000
Autodetected internal display
Panel is a 800x600 color TFT display
neofb: mapped framebuffer at c8b80000
neofb v0.4.2: 2048kB VRAM, using 800x600, 37.878kHz, 60Hz
Console: switching to colour frame buffer device 100x37
fb0: MagicGraph 128XD frame buffer device
Yenta: CardBus bridge found at 0000:00:02.0 [1014:0092]
Yenta: Enabling burst memory read transactions
Yenta: Using CSCINT to route CSC interrupts to PCI
Yenta: Routing CardBus interrupts to PCI
Yenta TI: socket 0000:00:02.0, mfunc 0xfba97543, devctl 0x62
Yenta TI: socket 0000:00:02.0 probing PCI interrupt failed, trying to fix
Yenta TI: socket 0000:00:02.0 no PCI interrupts. Fish. Please report.
Yenta: no PCI IRQ, CardBus support disabled for this socket.
Yenta: check your BIOS CardBus, BIOS IRQ or ACPI settings.
Yenta: ISA IRQ mask 0x00b8, PCI irq 0
Socket status: 30000006
Yenta: CardBus bridge found at 0000:00:02.1 [1014:0092]
Yenta TI: socket 0000:00:02.1, mfunc 0xfba97543, devctl 0x62
Yenta: ISA IRQ mask 0x00b8, PCI irq 11
Socket status: 30000020
piix4_smbus 0000:00:06.3: Found 0000:00:06.3 device
piix4_smbus 0000:00:06.3: IBM system detected; this module may corrupt your serial eeprom! Refusing to load module!
piix4_smbus: probe of 0000:00:06.3 failed with error -1
pccard: CardBus card inserted into slot 1
input: PC Speaker as /class/input/input1
irda_init()
NET: Registered protocol family 23
pnp: Device 00:04 activated.
parport: PnPBIOS parport detected.
parport0: PC-style at 0x3bc, irq 7 [PCSPP,TRISTATE]
pnp: Device 00:08 activated.
gameport: NS558 PnP Gameport is pnp00:08/gameport0, io 0x200, speed 670kHz
ad1848/cs4248 codec driver Copyright (C) by Hannu Savolainen 1993-1996
ad1848: No ISAPnP cards found, trying standard ones...
ACPI: Fatal opcode executed
pnp: Device 00:07 activated.
cs4232.c: ISA PnP configured, but not detected?
cs4232: ISA PnP card found, but not detected?
pnp: Device 00:07 disabled.
cs4232: Must set io, irq and dma.
IBM TrackPoint firmware: 0x0b, buttons: 2/3
cs: IO port probe 0x100-0x3af: clean.
cs: IO port probe 0x3e0-0x4ff: excluding 0x4d0-0x4d7
cs: IO port probe 0x820-0x8ff: clean.
cs: IO port probe 0xc00-0xcf7: clean.
cs: IO port probe 0xa00-0xaff: clean.
input: TPPS/2 IBM TrackPoint as /class/input/input2
pnp: Device 00:05 activated.
nsc_ircc_pnp_probe() : From PnP, found firbase 0x2F8 ; irq 3 ; dma 1.
nsc-ircc, chip->init
nsc-ircc, Found chip at base=0x02e
nsc-ircc, driver loaded (Dag Brattli)
IrDA: Registered device irda0
nsc-ircc, Found dongle: Reserved
nsc_ircc_init_dongle_interface(), Reserved not defined by irda yet
CS4232 WSS PnP manual resources are invalid, using auto config
CS4232 WSS PnP configure failed for WSS (out of resources?)
PnP BIOS detection failed for CS4232
cs4232-pnpbios: probe of 00:07 failed with error -16
CS4232 soundcard not found or device busy
ts: Compaq touchscreen protocol output
Adding 144576k swap on /dev/hda3. Priority:-1 extents:1 across:144576k
loop: loaded (max 8 devices)
ieee1394: Initialized config rom entry `ip1394'
SCSI subsystem initialized
ieee1394: sbp2: Driver forced to serialize I/O (serialize_io=1)
ieee1394: sbp2: Try serialize_io=0 for better performance
device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: [email]dm-devel@redhat.com[/email]
ACPI: Battery Slot [BAT0] (battery present)
ACPI: AC Adapter [AC] (off-line)
ACPI: Power Button (FF) [PWRF]
ACPI: Lid Switch [LID0]
ACPI: Sleep Button (CM) [SLPB]
Non-volatile memory driver v1.2
input: /usr/sbin/thinkpad-keys as /class/input/input3
Bluetooth: Core ver 2.10
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.8
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
