Valve Hammer Editor
habe mal den compilevorg kopiert.
der hammer editor zeigt mir einen fehler an:
** Executing...
** Command: Change Directory
** Parameters: H:\Hannes\Programme\CounterStrike
** Executing...
** Command: Copy File
** Parameters: "H:\Hannes\Programme\CounterStrike\cstrike\maps\arnehilfe.map" "H:\Hannes\Programme\CounterStrike\cstrike\maps\arnehilfe.map"
** Executing...
** Command: H:\Hannes\PROGRA~1\Hammer\tools\qcsg.exe
** Parameters: "H:\Hannes\Programme\CounterStrike\cstrike\maps\arnehilfe"
qcsg.exe v2.8 (Jan 31 2000)
---- qcsg ----
entering H:\Hannes\Programme\CounterStrike\cstrike\maps\arnehilfe.map
************ ERROR ************
Token too large on line 4
** Executing...
** Command: H:\Hannes\PROGRA~1\Hammer\tools\qbsp2.exe
qbsp2.exe v2.2 (Dec 28 1998)
---- qbsp2 ----
Can't open H:\Hannes\Programme\CounterStrike\cstrike\maps\arnehilfe.p0
** Executing...
** Command: H:\Hannes\PROGRA~1\Hammer\tools\vis.exe
vis.exe v1.3 (Dec 30 1998)
---- vis ----
1 thread(s)
Error opening H:\Hannes\Programme\CounterStrike\cstrike\maps\arnehilfe.bsp: No such file or directory
** Executing...
** Command: H:\Hannes\PROGRA~1\Hammer\tools\qrad.exe
qrad.exe v 1.5 (Apr 6 2000)
----- Radiosity ----
1 threads
[Reading texlights from 'H:\Hannes\PROGRA~1\Hammer\tools\lights.rad']
ignoring bad texlight '//lights.rad
' in H:\Hannes\PROGRA~1\Hammer\tools\lights.radignoring bad texlight '//Add any custom "Texture light" Values into the end of this file
' in H:\Hannes\PROGRA~1\Hammer\tools\lights.radignoring bad texlight '//Example -
' in H:\Hannes\PROGRA~1\Hammer\tools\lights.radignoring bad texlight '//This would make the texture "mycustomcomputerscreen" have a yellow light, and emit 1000 brightness
' in H:\Hannes\PROGRA~1\Hammer\tools\lights.radignoring bad texlight '//Texture light bright values also tend to be less powerful then there point light sisters, so keep this in mind
' in H:\Hannes\PROGRA~1\Hammer\tools\lights.radignoring bad texlight '//when you are complieing your map
' in H:\Hannes\PROGRA~1\Hammer\tools\lights.rad[60 texlights parsed from 'H:\Hannes\PROGRA~1\Hammer\tools\lights.rad']
** Executing...
** Command: H:\Hannes\PROGRA~1\COUNTE~2\cstrike.exe
** Parameters: +map "arnehilfe"
Metazeichen auf mehrere Argumente anweden
FreeBSD oder Linux?
Valve Hammer Tutroial
Project X! Was ist machbar
