X + Nvidia Problem...
Cool_Overrider
Cool_Overrider
NoOb
Hallo!
Ich hab ein kleines Problem mit meinem Nvidia Treiber... :help: .. und zwar folgendes:
Wenn ich ihn ganz normal, so wie immer starte, komme ich sofort nach dem bootvorgang in den textmodus. Wenn ich aber dann "/usr/bin/nvidia-installer -f " ausführe, wird der treiber heruntergeladen und installiert, dann kann ich mit kdm ganz einfach den X server starten und alles ist wunderbar, aber nach dem neustart ist alles so wie vorher..
Meine Xorg.conf:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 1.0  (buildmeister@builder3)  Wed Dec 14 16:39:22 PST 2005
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
    Identifier     "Default Layout"
    Screen         "Default Screen" 0 0
    InputDevice    "Generic Keyboard"
    InputDevice    "Configured Mouse"
EndSection
Section "Files"
        # paths to defoma fonts
    FontPath        "/usr/share/X11/fonts/misc"
    FontPath        "/usr/share/X11/fonts/cyrillic"
    FontPath        "/usr/share/X11/fonts/100dpi/:unscaled"
    FontPath        "/usr/share/X11/fonts/75dpi/:unscaled"
    FontPath        "/usr/share/X11/fonts/Type1"
    FontPath        "/usr/share/X11/fonts/CID"
    FontPath        "/usr/share/X11/fonts/100dpi"
    FontPath        "/usr/share/X11/fonts/75dpi"
    FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
    FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID"
EndSection
Section "Module"
    Load           "i2c"
    Load           "bitmap"
    Load           "ddc"
    Load           "extmod"
    Load           "freetype"
    Load           "glx"
    Load           "int10"
    Load           "type1"
    Load           "vbe"
EndSection
Section "InputDevice"
    Identifier     "Generic Keyboard"
    Driver         "kbd"
    Option         "CoreKeyboard"
    Option         "XkbRules" "xorg"
    Option         "XkbModel" "pc105"
    Option         "XkbLayout" "de"
    Option         "XkbVariant" "nodeadkeys"
EndSection
    Identifier     "Configured Mouse"
    Driver         "mouse"
    Option         "CorePointer"
    Option         "Device" "/dev/input/mice"
    Option         "Protocol" "ImPS/2"
    Option         "Emulate3Buttons" "true"
    Option         "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
    Identifier     "Generic Monitor"
    HorizSync       28.0 - 64.0
    VertRefresh     43.0 - 60.0
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "NVIDIA Corporation NV11 [GeForce2 MX/MX 400]"
    Driver         "nvidia"
EndSection
Section "Screen"
    Identifier     "Default Screen"
    Device         "NVIDIA Corporation NV11 [GeForce2 MX/MX 400]"
    Monitor        "Generic Monitor"
    DefaultDepth    24
    SubSection     "Display"
        Depth       1
        Modes      "1280x1024" "1280x960" "1024x768" "800x600" "640x480"
    EndSubSection
        Depth       4
    EndSubSection
        Depth       8
    EndSubSection
        Depth       15
    EndSubSection
        Depth       16
    EndSubSection
        Depth       24
    EndSubSection
EndSection
Meine Xorg.0.log:
X Window System Version 6.8.2 (Ubuntu 6.8.2-77 20051010174523 root@vernadsky.buildd)
Release Date: 9 February 2005
X Protocol Version 11, Revision 0, Release 6.8.2
Build Operating System: Linux 2.6.10 i686 [ELF]
Current Operating System: Linux marso 2.6.12-10-386 #1 Mon Jan 16 17:18:08 UTC 2006 i686
Build Date: 10 October 2005
        Before reporting problems, check http://wiki.X.Org
Module Loader present
OS Kernel: Linux version 2.6.12-10-386 (buildd@rothera) (gcc version 3.4.5 20050809 (prerelease) (Ubuntu 3.4.4-6ubuntu8)) #1 Mon Jan 16 17:18:08 UTC 2006 T
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Feb  9 22:18:25 2006
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Default Layout"
(**) |-->Screen "Default Screen" (0)
(**) |   |-->Monitor "Generic Monitor"
(**) |   |-->Device "NVIDIA Corporation NV11 [GeForce2 MX/MX 400]"
(**) |-->Input Device "Generic Keyboard"
(**) |-->Input Device "Configured Mouse"
(WW) The directory "/usr/share/X11/fonts/cyrillic" does not exist.
        Entry deleted from font path.
(WW) The directory "/usr/share/X11/fonts/CID" does not exist.
(WW) `fonts.dir' not found (or not valid) in "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID".
        (Run 'mkfontdir' on "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID").
(**) FontPath set to "/usr/share/X11/fonts/misc,/usr/share/X11/fonts/100dpi/:unscaled,/usr/share/X11/fonts/75dpi/:unscaled,/usr/share/X11/fonts/Type1,/usr/share/X11/fonts/100dpi,/usr/share/X11/fonts/75dpi,/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
(==) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(WW) Open APM failed (/dev/apm_bios) (No such file or directory)
(II) Module ABI versions:
        X.Org ANSI C Emulation: 0.2
        X.Org Video Driver: 0.7
        X.Org XInput driver : 0.4
        X.Org Server Extension : 0.2
        X.Org Font Renderer : 0.4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="X.Org Foundation"
        compiled for 6.8.2, module version = 1.0.0
        Module class: X.Org Font Renderer
        ABI class: X.Org Font Renderer, version 0.4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="X.Org Foundation"
        ABI class: X.Org Video Driver, version 0.7
(--) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,1a30 card 8086,1a30 rev 03 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 8086,1a31 card 0000,0000 rev 03 class 06,04,00 hdr 01
(II) PCI: 00:1e:0: chip 8086,244e card 0000,0000 rev 12 class 06,04,00 hdr 01
(II) PCI: 00:1f:0: chip 8086,2440 card 0000,0000 rev 12 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,244b card 1462,3910 rev 12 class 01,01,80 hdr 00
(II) PCI: 00:1f:2: chip 8086,2442 card 1462,3910 rev 12 class 0c,03,00 hdr 00
(II) PCI: 00:1f:3: chip 8086,2443 card 1462,3910 rev 12 class 0c,05,00 hdr 00
(II) PCI: 00:1f:4: chip 8086,2444 card 1462,3910 rev 12 class 0c,03,00 hdr 00
(II) PCI: 00:1f:5: chip 8086,2445 card 1462,3910 rev 12 class 04,01,00 hdr 00
(II) PCI: 01:00:0: chip 10de,0110 card 1554,1081 rev b2 class 03,00,00 hdr 00
(II) PCI: 02:01:0: chip 10ec,8139 card 10ec,8139 rev 10 class 02,00,00 hdr 00
(II) PCI: 02:05:0: chip 109e,036e card 0070,13eb rev 11 class 04,00,00 hdr 80
(II) PCI: 02:05:1: chip 109e,0878 card 0070,13eb rev 11 class 04,80,00 hdr 80
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
        [0] -1  0       0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
        [0] -1  0       0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:1:0), (0,1,1), BCTRL: 0x000e (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
        [0] -1  0       0xdc000000 - 0xddffffff (0x2000000) MX[B]
(II) Bus 1 prefetchable memory range:
        [0] -1  0       0xd0000000 - 0xd7ffffff (0x8000000) MX[B]
(II) Bus 2: bridge is at (0:30:0), (0,2,2), BCTRL: 0x0006 (VGA_EN is cleared)
(II) Bus 2 I/O range:
        [0] -1  0       0x0000c000 - 0x0000c0ff (0x100) IX[B]
        [1] -1  0       0x0000c400 - 0x0000c4ff (0x100) IX[B]
        [2] -1  0       0x0000c800 - 0x0000c8ff (0x100) IX[B]
        [3] -1  0       0x0000cc00 - 0x0000ccff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
        [0] -1  0       0xde000000 - 0xde0fffff (0x100000) MX[B]
(II) Bus 2 prefetchable memory range:
        [0] -1  0       0xde100000 - 0xde1fffff (0x100000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) nVidia Corporation NV11 [GeForce2 MX/MX 400] rev 178, Mem @ 0xdc000000/24, 0xd0000000/27
(--) PCI: (2:5:0) Brooktree Corporation Bt878 Video Capture rev 17, Mem @ 0xde100000/12
(II) Addressable bus resource ranges are
        [1] -1  0       0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
        [0] -1  0       0xffe00000 - 0xffffffff (0x200000) MX[B](B)
        [1] -1  0       0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
        [2] -1  0       0x000f0000 - 0x000fffff (0x10000) MX[B]
        [3] -1  0       0x000c0000 - 0x000effff (0x30000) MX[B]
        [4] -1  0       0x00000000 - 0x0009ffff (0xa0000) MX[B]
        [5] -1  0       0x0000ffff - 0x0000ffff (0x1) IX[B]
        [6] -1  0       0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xd8000000 from 0xdbffffff to 0xd7ffffff
(II) Active PCI resource ranges:
        [0] -1  0       0xde101000 - 0xde101fff (0x1000) MX[B]
        [1] -1  0       0xde000000 - 0xde0000ff (0x100) MX[B]
        [2] -1  0       0xd8000000 - 0xd7ffffff (0x0) MX[B]O
        [3] -1  0       0xde100000 - 0xde100fff (0x1000) MX[B](B)
        [4] -1  0       0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
        [5] -1  0       0xdc000000 - 0xdcffffff (0x1000000) MX[B](B)
        [6] -1  0       0x0000c000 - 0x0000c0ff (0x100) IX[B]
        [7] -1  0       0x0000e000 - 0x0000e03f (0x40) IX[B]
        [8] -1  0       0x0000dc00 - 0x0000dcff (0x100) IX[B]
        [9] -1  0       0x0000d800 - 0x0000d81f (0x20) IX[B]
        [10] -1 0       0x00005000 - 0x0000500f (0x10) IX[B]
        [11] -1 0       0x0000d000 - 0x0000d01f (0x20) IX[B]
        [12] -1 0       0x0000f000 - 0x0000f00f (0x10) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
        [5] -1  0       0xde101000 - 0xde101fff (0x1000) MX[B]
        [6] -1  0       0xde000000 - 0xde0000ff (0x100) MX[B]
        [7] -1  0       0xd8000000 - 0xd7ffffff (0x0) MX[B]O
        [8] -1  0       0xde100000 - 0xde100fff (0x1000) MX[B](B)
        [9] -1  0       0xd0000000 - 0xd7ffffff (0x8000000) MX[B](B)
        [10] -1 0       0xdc000000 - 0xdcffffff (0x1000000) MX[B](B)
        [11] -1 0       0x0000ffff - 0x0000ffff (0x1) IX[B]
        [12] -1 0       0x00000000 - 0x000000ff (0x100) IX[B]
        [13] -1 0       0x0000c000 - 0x0000c0ff (0x100) IX[B]
        [14] -1 0       0x0000e000 - 0x0000e03f (0x40) IX[B]
        [15] -1 0       0x0000dc00 - 0x0000dcff (0x100) IX[B]
        [16] -1 0       0x0000d800 - 0x0000d81f (0x20) IX[B]
        [17] -1 0       0x00005000 - 0x0000500f (0x10) IX[B]
        [18] -1 0       0x0000d000 - 0x0000d01f (0x20) IX[B]
        [19] -1 0       0x0000f000 - 0x0000f00f (0x10) IX[B]
(II) LoadModule: "i2c"
(II) Loading /usr/X11R6/lib/modules/libi2c.a
(II) Module i2c: vendor="X.Org Foundation"
        compiled for 6.8.2, module version = 1.2.0
(II) Reloading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) LoadModule: "ddc"
(II) Loading /usr/X11R6/lib/modules/libddc.a
(II) Module ddc: vendor="X.Org Foundation"
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="X.Org Foundation"
        Module class: X.Org Server Extension
        ABI class: X.Org Server Extension, version 0.2
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
        compiled for 6.8.2, module version = 2.1.0
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
        compiled for 4.0.2, module version = 1.0.8178
        Module class: XFree86 Server Extension
        ABI class: XFree86 Server Extension, version 0.1
(II) Loading extension GLX
(II) LoadModule: "int10"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="X.Org Foundation"
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="X.Org Foundation"
        compiled for 6.8.2, module version = 1.0.2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "vbe"
(II) Loading /usr/X11R6/lib/modules/libvbe.a
(II) Module vbe: vendor="X.Org Foundation"
        compiled for 6.8.2, module version = 1.1.0
(II) LoadModule: "nvidia"
(II) Loading /usr/X11R6/lib/modules/drivers/nvidia_drv.o
(II) Module nvidia: vendor="NVIDIA Corporation"
        Module class: XFree86 Video Driver
(II) LoadModule: "kbd"
(II) Loading /usr/X11R6/lib/modules/input/kbd_drv.o
(II) Module kbd: vendor="X.Org Foundation"
        Module class: X.Org XInput Driver
        ABI class: X.Org XInput driver, version 0.4
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="X.Org Foundation"
(II) NVIDIA X Driver  1.0-8178  Wed Dec 14 16:25:22 PST 2005
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset NVIDIA GPU found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
        [11] 0  0       0x000a0000 - 0x000affff (0x10000) MS[B]
        [12] 0  0       0x000b0000 - 0x000b7fff (0x8000) MS[B]
        [13] 0  0       0x000b8000 - 0x000bffff (0x8000) MS[B]
        [14] -1 0       0x0000ffff - 0x0000ffff (0x1) IX[B]
        [15] -1 0       0x00000000 - 0x000000ff (0x100) IX[B]
        [16] -1 0       0x0000c000 - 0x0000c0ff (0x100) IX[B]
        [17] -1 0       0x0000e000 - 0x0000e03f (0x40) IX[B]
        [18] -1 0       0x0000dc00 - 0x0000dcff (0x100) IX[B]
        [19] -1 0       0x0000d800 - 0x0000d81f (0x20) IX[B]
        [20] -1 0       0x00005000 - 0x0000500f (0x10) IX[B]
        [21] -1 0       0x0000d000 - 0x0000d01f (0x20) IX[B]
        [22] -1 0       0x0000f000 - 0x0000f00f (0x10) IX[B]
        [23] 0  0       0x000003b0 - 0x000003bb (0xc) IS[B]
        [24] 0  0       0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(EE) NVIDIA(0): Failed to initialize the NVIDIA kernel module! Please ensure
(EE) NVIDIA(0):      that there is a supported NVIDIA GPU in this system, and
(EE) NVIDIA(0):      that the NVIDIA device files have been created properly.
(EE) NVIDIA(0):      Please consult the NVIDIA README for details.
(EE) NVIDIA(0):  *** Aborting ***
(II) UnloadModule: "nvidia"
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
         at http://wiki.X.Org
 for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
Kann mir bitte jemand helfen? :hilfe2:
thx im voraus
Cool_Overrider
mach mal als root
# modprobe nvidia
und poste dann die Ausgabe von
# dmesg
Das Problem klingt nach einen Fehler, den ich auch mal beobachtet habe.
Gib mal aus, was
ls -l /lib/modules/ ausgibt.
Das Nvidiascript hat bei mir mit schöner Regelmäßigkeit die Kernelversion ignoriert, wenn ich es auf einen selbstgebackenen Kernel mit eigener Unterversion installieren wollte.
Der Effekt war genau der gleiche.
Ein simples Kopieren des Modules aus dem vom Installer selbst erzeugten Verzeichnis in das richtige Verzeichnis brachte die Lösung. Ein Softlink geht ebenfalls.
Solltest du bisher nur einen Kernel installiert haben, sollte auch nur ein Unterverzeichnis( deine Kernelversion) im /lib/modules existieren.
Gruß Wolfgang
Vielleicht weil /usr/src/linux nicht dem aktuellen Kernel entsprach?
MFG
Dennis
MFG
Dennis
Nein, das war schon ok.
Wenn ich einen eigenen Kernel baue, lege ich diesen Link an. Obwohl es eigentlich nichtmal nötig ist.
Gruß Wolfgang
Hallo!
@MrFenix
Bei "modprobe nvidia" erschien nichts...
Bei "dmesg" erschien folgendes:
000] Console: colour VGA+ 80x25
[4294669.484000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[4294669.486000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[4294669.507000] Memory: 510852k/524224k available (1416k kernel code, 12744k reserved, 762k data, 224k init, 0k highmem)
[4294669.507000] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[4294669.507000] Calibrating delay loop... 3571.71 BogoMIPS (lpj=1785856)
[4294669.529000] Security Framework v1.0.0 initialized
[4294669.529000] SELinux:  Disabled at boot.
[4294669.529000] Mount-cache hash table entries: 512
[4294669.529000] CPU: After generic identify, caps: 3febfbff 00000000 00000000 00000000 00000000 00000000 00000000
[4294669.529000] CPU: After vendor identify, caps: 3febfbff 00000000 00000000 00000000 00000000 00000000 00000000
[4294669.529000] CPU: Trace cache: 12K uops, L1 D cache: 8K
[4294669.529000] CPU: L2 cache: 256K
[4294669.529000] CPU: After all inits, caps: 3febfbff 00000000 00000000 00000080 00000000 00000000 00000000
[4294669.529000] CPU: Intel(R) Pentium(R) 4 CPU 1.80GHz stepping 02
[4294669.529000] Enabling fast FPU save and restore... done.
[4294669.529000] Enabling unmasked SIMD FPU exception support... done.
[4294669.529000] Checking 'hlt' instruction... OK.
[4294669.533000] Checking for popad bug... OK.
[4294669.533000] checking if image is initramfs... it is
[4294670.207000] Freeing initrd memory: 5174k freed
[4294670.213000] ACPI: Looking for DSDT in initrd... not found!
[4294670.279000]  not found!
[4294670.292000] ENABLING IO-APIC IRQs
[4294670.292000] ..TIMER: vector=0x31 pin1=2 pin2=-1
[4294670.403000] NET: Registered protocol family 16
[4294670.403000] EISA bus registered
[4294670.403000] ACPI: bus type pci registered
[4294670.416000] PCI: PCI BIOS revision 2.10 entry at 0xfb1d0, last bus=2
[4294670.416000] PCI: Using configuration type 1
[4294670.416000] mtrr: v2.0 (20020519)
[4294670.416000] ACPI: Subsystem revision 20050729
[4294670.430000] ACPI: Interpreter enabled
[4294670.430000] ACPI: Using IOAPIC for interrupt routing
[4294670.430000] ACPI: PCI Root Bridge [PCI0] (0000:00)
[4294670.430000] PCI: Probing PCI hardware (bus 00)
[4294670.431000] ACPI: Assume root bridge [\_SB_.PCI0] segment is 0
[4294670.431000] ACPI: Assume root bridge [\_SB_.PCI0] bus is 0
[4294670.434000] Boot video device is 0000:01:00.0
[4294670.434000] PCI: Transparent bridge - 0000:00:1e.0
[4294670.461000] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[4294670.461000] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
[4294670.463000] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[4294670.463000] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[4294670.464000] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[4294670.464000] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[4294670.464000] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[4294670.465000] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[4294670.465000] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[4294670.466000] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
[4294670.470000] Linux Plug and Play Support v0.97 (c) Adam Belay
[4294670.470000] pnp: PnP ACPI init
[4294670.477000] pnp: PnP ACPI: found 15 devices
[4294670.477000] PnPBIOS: Disabled by ACPI PNP
[4294670.477000] PCI: Using ACPI for IRQ routing
[4294670.477000] PCI: If a device doesn't work, try "pci=routeirq".  If it helps, post a report
[4294670.495000] pnp: 00:01: ioport range 0x4000-0x40f7 could not be reserved
[4294670.495000] Simple Boot Flag at 0x39 set to 0x1
[4294670.496000] audit: initializing netlink socket (disabled)
[4294670.496000] audit: initialized
[4294670.496000] VFS: Disk quotas dquot_6.5.1
[4294670.496000] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[4294670.496000] devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
[4294670.496000] devfs: boot_options: 0x0
[4294670.496000] Initializing Cryptographic API
[4294670.496000] isapnp: Scanning for PnP cards...
[4294670.850000] isapnp: No Plug & Play device found
[4294670.882000] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[4294670.884000] serio: i8042 AUX port at 0x60,0x64 irq 12
[4294670.884000] serio: i8042 KBD port at 0x60,0x64 irq 1
[4294670.884000] Serial: 8250/16550 driver $Revision: 1.90 $ 54 ports, IRQ sharing enabled
[4294670.884000] ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[4294670.884000] ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[4294670.887000] ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[4294670.888000] ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[4294670.888000] io scheduler noop registered
[4294670.888000] io scheduler anticipatory registered
[4294670.888000] io scheduler deadline registered
[4294670.888000] io scheduler cfq registered
[4294670.888000] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[4294670.889000] EISA: Probing bus 0 at eisa.0
[4294670.889000] Cannot allocate resource for EISA slot 4
[4294670.889000] Cannot allocate resource for EISA slot 5
[4294670.889000] EISA: Detected 0 cards.
[4294670.889000] NET: Registered protocol family 2
[4294670.898000] IP: routing cache hash table of 4096 buckets, 32Kbytes
[4294670.898000] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[4294670.898000] TCP bind hash table entries: 32768 (order: 5, 131072 bytes)
[4294670.899000] TCP: Hash tables configured (established 32768 bind 32768)
[4294670.899000] NET: Registered protocol family 8
[4294670.899000] NET: Registered protocol family 20
[4294670.899000] ACPI wakeup devices:
[4294670.899000] SLPB PCI0 HUB0 USB0 USB1 MODM UAR1 UAR2
[4294670.899000] ACPI: (supports S0 S1 S4 S5)
[4294670.900000] Freeing unused kernel memory: 224k freed
[4294670.935000] input: AT Translated Set 2 keyboard on isa0060/serio0
[4294670.935000] vga16fb: initializing
[4294670.935000] vga16fb: mapped to 0xc00a0000
[4294671.091000] Console: switching to colour frame buffer device 80x30
[4294671.091000] fb0: VGA16 VGA frame buffer device
[4294672.248000] Capability LSM initialized
[4294672.268000] NET: Registered protocol family 1
[4294672.289000] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
[4294672.289000] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[4294672.289000] ACPI: bus type ide registered
[4294672.304000] ICH2: IDE controller at PCI slot 0000:00:1f.1
[4294672.304000] ICH2: chipset revision 18
[4294672.304000] ICH2: not 100% native mode: will probe irqs later
[4294672.304000]     ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:pio
[4294672.304000]     ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:DMA, hdd:DMA
[4294672.304000] Probing IDE interface ide0...
[4294672.568000] hda: ST3160021A, ATA DISK drive
[4294673.180000] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[4294673.180000] Probing IDE interface ide1...
[4294673.852000] hdc: LITEON DVD-ROM LTD163, ATAPI CD/DVD-ROM drive
[4294674.566000] hdd: PHILIPS DVDR16LS, ATAPI CD/DVD-ROM drive
[4294674.617000] ide1 at 0x170-0x177,0x376 on irq 15
[4294674.617000] Probing IDE interface ide2...
[4294675.130000] Probing IDE interface ide3...
[4294675.642000] Probing IDE interface ide4...
[4294676.154000] Probing IDE interface ide5...
[4294676.673000] hda: max request size: 1024KiB
[4294676.673000] hda: 312581808 sectors (160041 MB) w/2048KiB Cache, CHS=19457/255/63, UDMA(100)
[4294676.673000] hda: cache flushes supported
[4294676.673000]  /dev/ide/host0/bus0/target0/lun0: p1 p2 < p5 >
[4294676.716000] hdc: ATAPI 48X DVD-ROM drive, 512kB Cache
[4294676.716000] Uniform CD-ROM driver Revision: 3.20
[4294676.719000] hdd: ATAPI 40X DVD-ROM DVD-R CD-R/RW drive, 2048kB Cache
[4294677.677000] Attempting manual resume
[4294677.678000] swsusp: Suspend partition has wrong signature?
[4294677.746000] usbcore: registered new driver usbfs
[4294677.746000] usbcore: registered new driver hub
[4294677.748000] USB Universal Host Controller Interface driver v2.2
[4294677.748000] ACPI: PCI Interrupt 0000:00:1f.2[D] -> GSI 19 (level, low) -> IRQ 19
[4294677.748000] PCI: Setting latency timer of device 0000:00:1f.2 to 64
[4294677.748000] uhci_hcd 0000:00:1f.2: Intel Corporation 82801BA/BAM USB (Hub #1)
[4294677.810000] uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 1
[4294677.810000] uhci_hcd 0000:00:1f.2: irq 19, io base 0x0000d000
[4294677.810000] hub 1-0:1.0: USB hub found
[4294677.810000] hub 1-0:1.0: 2 ports detected
[4294677.813000] ACPI: PCI Interrupt 0000:00:1f.4[C] -> GSI 23 (level, low) -> IRQ 23
[4294677.813000] PCI: Setting latency timer of device 0000:00:1f.4 to 64
[4294677.813000] uhci_hcd 0000:00:1f.4: Intel Corporation 82801BA/BAM USB (Hub #2)
[4294677.875000] uhci_hcd 0000:00:1f.4: new USB bus registered, assigned bus number 2
[4294677.875000] uhci_hcd 0000:00:1f.4: irq 23, io base 0x0000d800
[4294677.875000] hub 2-0:1.0: USB hub found
[4294677.875000] hub 2-0:1.0: 2 ports detected
[4294677.936000] 8139cp: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004)
[4294677.936000] 8139cp: pci dev 0000:02:01.0 (id 10ec:8139 rev 10) is not an 8139C+ compatible chip
[4294677.936000] 8139cp: Try the "8139too" driver instead.
[4294677.938000] 8139too Fast Ethernet driver 0.9.27
[4294677.938000] ACPI: PCI Interrupt 0000:02:01.0[A] -> GSI 17 (level, low) -> IRQ 17
[4294677.939000] eth0: RealTek RTL8139 at 0xc000, 00:0e:2e:64:f8:be, IRQ 17
[4294677.939000] eth0:  Identified 8139 chip type 'RTL-8100B/8139D'
[4294681.037000] ACPI: Fan [FAN] (on)
[4294681.042000] ACPI: CPU0 (power states: C1[C1] C2[C2])
[4294681.042000] ACPI: Processor [CPU0] (supports 2 throttling states)
[4294681.045000] ACPI: Thermal Zone [THRM] (22 C)
[4294681.259000] Attempting manual resume
[4294681.259000] swsusp: Suspend partition has wrong signature?
[4294681.281000] kjournald starting.  Commit interval 5 seconds
[4294681.281000] EXT3-fs: mounted filesystem with ordered data mode.
[4294682.619000] md: md driver 0.90.1 MAX_MD_DEVS=256, MD_SB_DISKS=27
[4294687.888000] Adding 1510068k swap on /dev/hda5.  Priority:-1 extents:1
[4294688.216000] EXT3 FS on hda1, internal journal
[4294694.718000] parport: PnPBIOS parport detected.
[4294694.718000] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,EPP,ECP,DMA]
[4294694.805000] lp0: using parport0 (interrupt-driven).
[4294694.856000] mice: PS/2 mouse device common for all mice
[4294694.972000] Non-volatile memory driver v1.2
[4294695.183000] input: ImExPS/2 Generic Explorer Mouse on isa0060/serio1
[4294695.862000] ts: Compaq touchscreen protocol output
[4294698.636000] device-mapper: 4.4.0-ioctl (2005-01-12) initialised: dm-devel@redhat.com
[4294700.784000] cdrom: open failed.
[4294700.791000] cdrom: open failed.
[4294703.446000] Linux agpgart interface v0.101 (c) Dave Jones
[4294703.464000] agpgart: Detected an Intel i845 Chipset.
[4294703.486000] agpgart: AGP aperture is 64M @ 0xd8000000
[4294703.643000] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[4294703.653000] shpchp: acpi_shpchprm:\_SB_.PCI0 evaluate _BBN fail=0x5
[4294703.653000] shpchp: acpi_shpchprm:get_device PCI ROOT HID fail=0x5
[4294703.814000] shpchp: acpi_shpchprm:\_SB_.PCI0 evaluate _BBN fail=0x5
[4294703.814000] shpchp: acpi_shpchprm:get_device PCI ROOT HID fail=0x5
[4294703.920000] hw_random: RNG not detected
[4294704.904000] ACPI: PCI Interrupt 0000:00:1f.5[B] -> GSI 17 (level, low) -> IRQ 17
[4294704.904000] PCI: Setting latency timer of device 0000:00:1f.5 to 64
[4294705.213000] intel8x0_measure_ac97_clock: measured 49599 usecs
[4294705.213000] intel8x0: clocking to 48000
[4294706.080000] Linux video capture interface: v1.00
[4294706.171000] bttv: driver version 0.9.15 loaded
[4294706.171000] bttv: using 8 buffers with 2080k (520 pages) each for capture
[4294706.179000] bttv: Bt8xx card found (0).
[4294706.179000] ACPI: PCI Interrupt 0000:02:05.0[A] -> GSI 17 (level, low) -> IRQ 17
[4294706.179000] bttv0: Bt878 (rev 17) at 0000:02:05.0, irq: 17, latency: 32, mmio: 0xde100000
[4294706.179000] bttv0: detected: Hauppauge WinTV [card=10], PCI subsystem ID is 0070:13eb
[4294706.179000] bttv0: using: Hauppauge (bt878) [card=10,autodetected]
[4294706.179000] bttv0: gpio: en=00000000, out=00000000 in=00ffffdb [init]
[4294706.182000] bttv0: Hauppauge/Voodoo msp34xx: reset line init [5]
[4294706.298000] tveeprom: Hauppauge: model = 44354, rev = C242, serial# = 5044879
[4294706.298000] tveeprom: tuner = Temic 4009FR5 (idx = 42, type = 20)
[4294706.298000] tveeprom: tuner fmt = PAL(B/G) (eeprom = 0x04, v4l2 = 0x00000007)
[4294706.298000] tveeprom: audio_processor = MSP3415 (type = 6)
[4294706.298000] bttv0: using tuner=20
[4294706.298000] bttv0: i2c: checking for MSP34xx @ 0x80... found
[4294706.350000] msp34xx: init: chip=MSP3415G-B8 +nicam +simple +simpler +radio mode=simpler
[4294706.398000] msp34xxg: daemon started
[4294706.423000] bttv0: i2c: checking for TDA9875 @ 0xb0... not found
[4294706.426000] bttv0: i2c: checking for TDA7432 @ 0x8a... not found
[4294706.443000] tvaudio: TV audio decoder + audio/video mux driver
[4294706.443000] tvaudio: known chips: tda9840,tda9873h,tda9874h/a,tda9850,tda9855,tea6300,tea6320,tea6420,tda8425,pic16c54 (PV951),ta8874z
[4294706.473000] bttv0: i2c: checking for TDA9887 @ 0x86... not found
[4294706.501000] tuner 0-0061: chip found @ 0xc2 (bt878 #0 [sw])
[4294706.501000] tuner 0-0061: type set to 20 (Temic PAL_BG (4009 FR5) or PAL_I (4069 FR5))
[4294706.562000] bttv0: registered device video0
[4294706.564000] bttv0: registered device vbi0
[4294706.566000] bttv0: registered device radio0
[4294706.577000] bttv0: PLL: 28636363 => 35468950 .. ok
[4294706.914000] ACPI: PCI Interrupt 0000:02:05.1[A] -> GSI 17 (level, low) -> IRQ 17
[4294707.407000] bt878: AUDIO driver version 0.0.0 loaded
[4294708.755000] Real Time Clock Driver v1.12
[4294708.854000] input: PC Speaker
[4294709.109000] Floppy drive(s): fd0 is 1.44M
[4294709.124000] FDC 0 is a post-1991 82077
[4294711.286000] eth0: link up, 10Mbps, half-duplex, lpa 0x0000
[4294711.303000] NET: Registered protocol family 17
[4294712.735000] NET: Registered protocol family 10
[4294712.735000] Disabled Privacy Extensions on device c02eb280(lo)
[4294712.735000] IPv6 over IPv4 tunneling driver
[4294714.340000] ACPI: Power Button (FF) [PWRF]
[4294714.340000] ACPI: Power Button (CM) [PWRB]
[4294714.340000] ACPI: Sleep Button (CM) [SLPB]
[4294714.515000] ibm_acpi: ec object not found
[4294720.306000] apm: BIOS version 1.2 Flags 0x07 (Driver version 1.16ac)
[4294720.306000] apm: overridden by ACPI.
[4294722.609000] Bluetooth: Core ver 2.7
[4294722.609000] NET: Registered protocol family 31
[4294722.609000] Bluetooth: HCI device and connection manager initialized
[4294722.609000] Bluetooth: HCI socket layer initialized
[4294722.726000] Bluetooth: L2CAP ver 2.7
[4294722.726000] Bluetooth: L2CAP socket layer initialized
[4294722.753000] Bluetooth: RFCOMM ver 1.5
[4294722.753000] Bluetooth: RFCOMM socket layer initialized
[4294722.753000] Bluetooth: RFCOMM TTY layer initialized
[4294723.462000] eth0: no IPv6 routers present
[4294723.978000] nvidia: module license 'NVIDIA' taints kernel.
[4294724.028000] ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 16 (level, low) -> IRQ 16
[4294724.029000] NVRM: loading NVIDIA Linux x86 NVIDIA Kernel Module  1.0-7667  Fri Jun 17 07:01:04 PDT 2005
[4294724.031000] NVRM: RM/client version mismatch!!
[4294724.031000] NVRM:    aborting to avoid catastrophe!
@ Wolfgang
Bei "ls -l /lib/modules/" bekam ich folgendes:
total 8
drwxr-xr-x  6 root root 4096 2006-02-11 12:24 2.6.12-10-386
drwxr-xr-x  6 root root 4096 2006-02-04 15:22 2.6.12-9-386
Was kann das nur sein? :think:
thx für alle antworten..
Cool_Overrider
Benutzt du Ubuntu oder Debian?
Ich habe hier nur Debian.
Welchen Kernel bootest du denn? uname -r
Ich habe hier etwas gefunden, wo es um Versionskonflikte ging.
Ob das bei dir zutrifft kann ich nicht sagen, aber schau es dir selbst mal an:
http://forum.ubuntuusers.de/topic/6192/#41940
Die Ausgabe von lsmod könnte auch interessant sein.
- Nachdem du das installscript wieder angeworfen hast und alles läuft!
Gruß Wolfgang
Hallo!
Also ich benutze Kubuntu.
Die kernel version ist 2.6.12-10-386
Die ausgaben von lsmod:
Module                  Size  Used by
nvidia               4085552  12
rfcomm                 34972  0
l2cap                  22404  5 rfcomm
bluetooth              43012  4 rfcomm,l2cap
speedstep_lib           4228  0
cpufreq_userspace       4444  0
cpufreq_stats           5124  0
freq_table              4484  1 cpufreq_stats
cpufreq_powersave       1920  0
cpufreq_ondemand        5916  0
cpufreq_conservative     6820  0
video                  16004  0
tc1100_wmi              6916  0
sony_acpi               5516  0
pcc_acpi               11392  0
hotkey                  9508  0
dev_acpi               11396  0
i2c_acpi_ec             5760  0
button                  6672  0
battery                 9604  0
container               4608  0
ac                      4996  0
ipv6                  217408  6
af_packet              20232  2
snd_mpu401              6344  0
snd_mpu401_uart         6784  1 snd_mpu401
snd_rawmidi            22816  1 snd_mpu401_uart
snd_seq_device          8204  1 snd_rawmidi
analog                 10528  0
gameport               14472  1 analog
floppy                 52692  0
pcspkr                  3652  0
rtc                    11832  0
bt878                   9912  0
snd_bt87x              13768  1
tuner                  24488  0
tvaudio                21668  0
msp3400                23336  0
bttv                  141456  1 bt878
video_buf              19844  1 bttv
firmware_class          9472  1 bttv
i2c_algo_bit            8584  1 bttv
v4l2_common             5888  1 bttv
btcx_risc               4872  1 bttv
tveeprom               12568  1 bttv
i2c_core               19728  7 i2c_acpi_ec,tuner,tvaudio,msp3400,bttv,i2c_algo_bit,tveeprom
videodev                9344  1 bttv
snd_intel8x0           30144  1
snd_ac97_codec         72188  1 snd_intel8x0
snd_pcm_oss            46368  0
snd_mixer_oss          16128  1 snd_pcm_oss
snd_pcm                78344  4 snd_bt87x,snd_intel8x0,snd_ac97_codec,snd_pcm_oss
snd_timer              21764  1 snd_pcm
snd                    48644  15 snd_mpu401,snd_mpu401_uart,snd_rawmidi,snd_seq_device,snd_bt87x,snd_intel8x0,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_timer
soundcore               9184  1 snd
snd_page_alloc         10120  3 snd_bt87x,snd_intel8x0,snd_pcm
tpm_atmel               5504  0
tpm_nsc                 6528  0
tpm                     9504  2 tpm_atmel,tpm_nsc
pci_hotplug            24628  0
intel_agp              21276  1
agpgart                32328  2 nvidia,intel_agp
dm_mod                 50364  1
tsdev                   7616  0
evdev                   9088  0
nvram                   8200  0
psmouse                26116  0
mousedev               10912  1
parport_pc             31812  1
lp                     11460  0
parport                32072  2 parport_pc,lp
md                     40656  0
ext3                  115976  1
jbd                    48536  1 ext3
thermal                13192  0
processor              23100  1 thermal
fan                     4740  0
8139too                23552  0
8139cp                 18432  0
mii                     5248  2 8139too,8139cp
uhci_hcd               28048  0
usbcore               104316  2 uhci_hcd
ide_cd                 36996  0
cdrom                  33952  1 ide_cd
ide_disk               16128  3
ide_generic             1664  0
piix                    9476  1
ide_core              125268  4 ide_cd,ide_disk,ide_generic,piix
unix                   24624  371
vesafb                  8088  0
capability              5000  0
commoncap               6784  1 capability
vga16fb                12232  1
vgastate                8320  1 vga16fb
softcursor              2432  2 vesafb,vga16fb
cfbimgblt               2944  2 vesafb,vga16fb
cfbfillrect             3840  2 vesafb,vga16fb
cfbcopyarea             4480  2 vesafb,vga16fb
fbcon                  34176  72
tileblit                2560  1 fbcon
font                    8448  1 fbcon
bitblit                 5248  1 fbcon
Ich werd mir das jetzt durchlesen, thx für den Link!!!
Cool_Overrider
Edit:
DANKE DANKE DANKE DANKE DANKE!!!!!!!!!!!!!!!!!
Jetzt gehts!!!!
Cool_Overrider
(Ein überglücklicher Linux User)
X startet nichtmehr
Nvidia Hybrid-Grafikkarte: 3D Beschleunigung will nicht
xserver startet nicht: no screens
xrandr: cant open display
